Question about InFocus ScreenPlay 7200 Multimedia Projector
Greenish dark, with multible lines across top to bottom of the screen.
I recently installed a new bulb. Thats when new problems started. I Have a 1080i component hook up. I reset by accident the factory reset button. My pitcher is grainy and ghosty. the settings have all changed. The Screen that has the gamma ray setting not sure of the setting. The screen with Film 1&2 and Video source check marks not sure which one to check. Can u help me here ? Otherwise i will need to get a tech out here to look it over.
Thanks for any help u might offer me .
Tom Hagen 714/529/0453)- Apophis2037@gmail.com
  • 2 more comments
  • Apophis2037 Jun 23, 2008
    i get the infocus start up display ,blue screen ,then goes into search mode, then screen goes into a dark screen. after changing the presets to user 1 ,lost picture .now i,ve shut it down twice and picture does not return.
    I still have the problem and out of warranty. So I help. I get the infocus start up display ,blue screen ,then goes into search mode, then screen goes into a dark screen. after changing the presets to user 1 ,lost picture .now i,ve shut it down twice and picture does not return.
    I have the Infocus 7200, no pots or filters on any menus. I still have the problem and out of warranty. So I help. I get the infocus start up display ,blue screen ,then goes into search mode, then screen goes into a dark screen. after changing the presets to user 1 ,lost picture .now i,ve shut it down twice and picture does not return.
    I am going to let the system cool down for awhile then I will need your assistance.
    Sergeant:
    Champion:
  • 230 Answers
Try to adjust the colour ,brightness, contrast and tint in the main menu and also try by adjusting the screen pots this help you .Otherwise try the hard reset method , that is turn of the projector and unplug all the cables and wait for half an hour and then replug all the cables and try .....you can see change
Posted on Jun 23, 2008
    Sergeant:
  • 260 Answers
Tom,
There are many changes to your device that you have done here. Even if you go through all of the normal set up procedures, it looks like somethings else happened. Before calling a technician, remember you have a 2 year warranty. Let us know if you need more information about that.
Ken
  • 4,472 Answers
1. Adjust color, tint, color temperature,brightness, or contrast in the menus.
2. Pick another gamma setting
3. Pick another color space
Keep me posted,
Lee
    Master:
  • 848 Answers
That looks like retrace lines. Anyway, you should try to adjust screen pot not focus pot. Make sure you are turning blue screen pot (there are 3 focus pots and 3 screen pots) and do it slowly. If you turn it too much, it will affect your grayscale
  • gopinath pasupathy Jun 23, 2008
    check your filters they do wear down due to the heat/light. may need replacing
Dark spot
These bulbs are very sensitive to contamination. When installing a bulb, do not touch it with your fingers, as this will leave your natural oils on it and that will become a hot spot and burn out the lamp.
Use a clean piece of toilet tissue when installing the new lamp to eliminate the above.
Jan 11, 2014 | Sharp XR-10X Multimedia Projector
My projector has worked fine for a while now, but for some reason it now has a greenish glow in the bottom left to about the middle. i it was 4 squares, it'd be the bottom left square. The cable has
Hello!
Any picture imperfection in any LCD projectors is caused by light engine's damage. It could be due to constant overheating, dust accumulation, etc.
In any occasion, the light engine must be replaced or repaired(if possible).
If that glow is not substantial yet and you can live with that, just ignore it. It will get worse, eventually, then you will think over: to repair this projector or replace it with a new one.
good luck,
thanks,
Alex.
Dec 20, 2011 | Panasonic PT-LB60NTU LCD Projector
With my old bulb I recently had black vertical lines. I just put in a new bulb and now the lines multi-colored. How do I get rid of the lines? This problem shows up from my TV and DVD feeds.
reset the settings to factory default. if you don't get the lines on the splash screen when you first start it up, try swapping cables. if that doesn't work or you do get the lines on the splash screen, you have a video processor chip issue. replace the main board.
Mar 18, 2010 | InFocus ScreenPlay 7205 Multimedia...
I have a faint rolling line moving from the bottom of the screen to the top. It's very noticable with dark screens. I have a new bulb in and have checked to make sure it wasn't the cable box. Any ideas?
Typically this problem is caused by line noise or interference, such as an appliance such as a fan, AC unit, or other motorized device on the same electrical circuit or electrical ground that your projector is connected to.
In a worse case scenario,like what happened to me, is that it may be that your neighbor has some device like an air conditioning unit that is poorly grounded and it sends a rolling line through the round and through to the cable tv's coax cable and back to the junction box. If this is the case, your neighbors probably have similar problems. For this type of problem, you can report it to the cable company for line quality problems, they can send a tech out and try to isolate the problem and where it is originating from. In my case, the third cable tech that came out traced it to a grounding problem on my neighbors house, but the cable company can't fix the problem unless the home owner grants them access to their property to investigate further.
Sep 28, 2009 | Mitsubishi HC1600 Projector
IN72 psychedelic traces
have the same problem took mine apart for cleaning and inspected the bulb looks like bubbles in the bulb that will hold disorted images on the screen so im going to replace bulb
Feb 04, 2008 | InFocus IN72 Multimedia Projector
Color bleeding - blue colors always on the screen
just came across this same prob on my projector. Any ideas?
Dec 11, 2007 | Canon LV X2 Multimedia Projector
My picture brightness is uneven - there is a persistant bright field on my screen.
I have the exact same problem with my AE700. It a started about the same time, around 2500 hours for me. I lived with it untill I could afford a new bulb which arrived yesterday. The old bulb was still working at a 3603 hours when I installed the new one. But the new bulb didn't fix the problem for me either. I may try to take it apart this weekend and give it a good cleaning. Andy
Jan 07, 2007 | Panasonic PT-AE700U Multimedia Projector
InFocus ScreenPlay 7200 Multimedia Projector Logo
206 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Juan Carlos Pacheco
Level 1 Expert
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
