Question about Canon Rebel XT / EOS 350D Digital Camera
Broken MIrror? well your sub-mirror is broken inside of the camera, i had the same problem, it just happens by itself after extended use of the camera, and it is not a means for recall by canon so you have to deal with it yourself.  this website can fix it for $130 and they will replace it with a metal piece so it doesn't happen again(original piece is weak plastic) I just read the above solution.  It looks like I may have the same problem - I have easily taken 50,000 pictures with my Canon Rebel, love it!  A few weeks ago, I was in the middle of a big event when I noticed that 1/2-3/4 of each shot was black - all of a sudden, would never have noticed if I hadn't seen it pop up (ie everything else in the process seemed normal).  I took over 40 pictures, they all had the same result. So, the person mentions that "this site" can fix it for $130 - true?  Is that the FixYa site and if yes, how do i go about it? Do you recommend fixing a camera that "old" (6 1/2 years old)?  Thank You!
    Problem Solver:
  • 8 Answers
Teresalemair persenaly I would not fix a camera that old that has had alot of use, unforteneterly we live in a throw away society. If its possibly to upgrade the camera.
Rather I would put that money into a camera upgrade, this will in the long term allow you to obtain even better photos, as colour and contrast that the new cmos can capture is fair better then the older tecknology. This is what makes the newer camera's better not the amount of megapixels, unless printing bigger 20' x 30' or or doing alot of extreme croping. As the glass in the budget lens does not allow even a 6mb camera to get the best pictures it possibly can as far as sharpness goes.
Posted on Jul 06, 2008
Linkage problem,
Make sure lens is set on AF and not M. Clean body and lens contacts with a Q-tip dipped in alcohol. Try multiple lenses to make sure it is not a problem with just one lens. Put the lens on M and turn the front and make sure it turns freely and is not stuck by impact/spillage etc. Push down on the release button and make sure you have two distinct 'pops' (release switch may be broken). Gently lift up mirror and make sure that the AF sub mirror also comes up properly. Impact can break the little plastic guide pin for the sub mirror so that it is not in the right position and the AF will not work. Also make sure that the spring that makes the sub mirror come up is in position (they come off). Can be on either the right or left side of the mirror depending upon the model.
These are the steps I would take if you brought your camera into the shop I work at.
Apr 28, 2013 | Canon Rebel Cameras
My auto focus will not work.
lens af unit gear is broken, or lens af saft if broken, or lens af flex is broken.
or could be camera sub mirror spring is come out from mirror unit.
take it to canon repaire centre to estimate
Jul 05, 2010 | Canon EOS Rebel XSi Digital Camera
The passanger mirror was broken and has fallen from the car. It is still hooked up to the power moter but I will need to by and install a new mirror because the bracket is broken. Please describe how to...
REMOVE THE MIRROR TRIM PANEL.THEN UNPLUG THE ELECTRICAL CONNECTOR FROM THE POWER MIRROR SWITCH.THEN REMOVE THE 3 RETAINING NUTS AND DETACH THE MIRROR FROM THE VECHICLE.
Feb 27, 2010 | 1998 Oldsmobile Eighty Eight
Canon EOS 5D Autofocus will not work.
ho.....ho...
I have this prob in my canon EOS kiss SLR.
CHECK THAT>>>>>>>
Hold the camera vertically.Switch on the AF and let the camera to auto focus.!!!!!!!!!!!!!!!!
Don't wondering....Check ur camera's sub mirror in the in side of the sub mirror.The spring that push back sub mirror from the main mirror is broken.......!
How to repair this? Follow this link....
http://www.facebook.com/home.php?#/album.php?aid=2042115&id=1359757176
Nov 02, 2009 | Canon EOS-5D 12.8 Megapixel SLR Digital...
Bottom 3/4 of photos are black
Check out this website http://www.lotek.nu/misc/EOS_300D_sub-mirror_repair/
I had the same problem. You can check to make for sure by removing your lens, and carefully lifting your mirror. Does the sub mirror underneath flatten against the other one when you lift it? That's probably what is in the way creating your 3/4 "black" picture. I just repaired mine as in this website, and the mirror moves great now! Of course, I'm used to taking apart laptops and such. If you have a warranty yet, contact Canon. It is a defective issue on there part.
Mar 12, 2009 | Canon Digital Rebel / EOS-300D Digital...
How to replace broken mirror
Remove the door panel, then remove the speaker inside the door opposite the mirror itself.Then it is usually an allen key bolt or 3 depending on the year. It will come off as one big unit.
Jul 28, 2008 | 1999 Volkswagen Golf
I have a Canon Rebel EOS digital. When I take a picture, the bottom two thirds of the picture is black.
Take the lens off and carefully lift the mirror - if the sub-mirror underneath the main mirror doesn't follow the main mirror up, the stop-pin has broken off and has to be repaired by a camera shop. A common problem.
Jul 13, 2008 | Cameras
Only half the image apears other half is black
Oct 23, 2007 | Canon Rebel XT / EOS 350D Digital Camera
LCD/Recording Picture
This is becoming a common problem on the Digital Rebel. The pin that activates the sub-mirror ( for autofocus ) has broken off and the mirror box will have to be removed to replace it. It's about a $150 repair.
Dec 03, 2006 | Canon Digital Rebel / EOS-300D Digital...
Canon Rebel XT / EOS 350D Digital Camera Logo
57 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
