Question about HP GF939ATABA Notebook
Presario 900 display faults
Hi
I have a laptop with a dim display.I get the Compaq flash screen as normal but when windows takes over it gose dim and stays dim.
I have checked the cover switch and replaced the inverter without a fix.any clues
    Novelist:
  • 148 Answers
Try to increase its brightness from Power options/Control panel..
hope it works u out
Posted on Sep 04, 2009
Compaq Presario CQ56-115DX shows a blank screen on boot, but runs perfect on external display
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Mar 24, 2012 | Compaq Presario CQ56-115DX Laptop
My compaq presario 1200xl310's monitor remains black. I just purchased a new ac adapter for it. It had been unused for about a month. When I inserted the new adapter and powered it up---no screenlight-up....
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Sep 30, 2009 | Compaq Presario 1200 Notebook
I have a Compaq Presario V2000 and am on it right now but the screen is black and I am using it by pluging it in to a diffrent screen
www.lcdparts.net
Sep 28, 2009 | HP Compaq Presario V2000 Notebook
Presario 700 has a blank screen. Started occasionally going to a blank screen, now it stay blank. Will replacing the hard drive correct this problem?
If the laptop appears to boot up and the hard disk is spinning and the hard disk LED is flashing then the hard disk is OK.
Then the fault could be a faulty video cable or connector or CCFL lamp or inverter.
Try reseating the video cable/connector that connects to the motherboard first.
If this doesn't work then to determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 16, 2009 | Compaq Presario 700 470024-192 Notebook
Problem with my screen
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 11, 2009 | Compaq Presario R3000 Notebook
My hp compaq laptop is pink where it should be white?
  • Picture flickering with dim display.
Apr 30, 2009 | HP Compaq Presario V2000z Notebook
Screen stays black
Apr 30, 2009 | Compaq Computers & Internet
Screen Flickers
Hi I've recently fixed 2 laptops with a very similar error, neither of which were Hewlett Packard Compaq's. That aside its a fairly common error and that is a loose connection. Unless you've a lot of experience in dismantling and reassembling laptops, I strongly reccomend taking it to an experienced technician.
I hope this helps
Apr 07, 2009 | HP Compaq Presario CQ50-110US Laptop
No screen
The backlight in your LCD most likely needs to be replaced.if you are not familiar with it's removal and installation I suggest you take it in to a repair shop.
Hope this helps you..
Nov 21, 2007 | Compaq Presario M2000 Notebook
HP GF939ATABA Notebook Logo
88 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
