Question about LG BG8000ER Air Conditioner
AC not producing cool air
LG wall AC unit is not producing cool air, also it appears it may be freezing as well. I am not familiar with freon type a/c systems, but I do know that other types of ac systems have a 35 degree sensor that will shut the compressor off if it senses the temp is too low. Is there something similar on the home AC units?
Thanks,
Greg
  • Anonymous Mar 19, 2014
    wall unit lights on,wont cool remote wont work
    Novelist:
    Champion:
  • 230 Answers
If this is a newer system there will be a freeze sensor. It may be low on refrigerant. I would check the obvious things first. Are the filters and coils free of debris? Finally only set the temperature to your comfortable temp not lower as this can cause freezing too (generally not below 70 degrees)
Posted on Jun 23, 2008
LG ac unit not blowing cold air
check if you still have Freon.
Jul 13, 2014 | Heating & Cooling
Room temp 78 degrees with unit setting at 68 degrees. The unit is running (i.e. compressor) but unit not pumping out cold air. To be specific the unit is pushing out cool air just not cold with such a...
Sounds like it could be low on freon I believe these units have about 1.5 pounds of freon in them and are critical in not undercharging or overcharging them if it is a freon 410 ac unit the pressures should be about 135 and both lines cold if is low on freon a service tec will need to be called to try to repair the leak if possiable
Jul 21, 2013 | LG LAN240HSV2-LAU240HSV2 24000 BTU 20 SEER...
My new LG mini split 24,000 BTU unit is Freezing up on the small tube side. Not cooling properly. I thought freezing up (low on freon) but wouldnt it be on the larger tube. Is it running the fluid...
The larger tube is the return tube for the hot freon gas from the evaporator. The small tube is the cold freon after is has gone through the condenser where gas is condensed to a liquid when the heat is removed. So I would say your system is low on freon.
Jun 09, 2011 | LG LM-2430H2L 24000 BTU Heat and Cool Dual...
My Amanda wall unit keeps freezing up. Cleaned filter and coils, please advise. Thanks, Gilbert
If a AC unit starts to freeze up, then that is a sure sign that it is low on freon. A wall unit is harder to add freon to since those units generally do not have Shrader valves to purge or add freon. It is sort of like your refridgerator in that the freon is sealed in the factory and to add , a technician has to cut the evaporator tube and add a valve, then add freon, pinch the tube off and seal it once the correct pressure is adjusted.
I would say that somehow your unit has developed a leak, and will get worse.
see:http://real-estate-agents.com/tips/hvac/maintain-air-conditioner/
Jan 23, 2011 | Amana PTC123B35AE Air Conditioner
Ice fallingfrom split ac
Try turning off the ac unit for about an hour.(Your might have too small of ac unit or just have the ac set too low..Causing the coils to freeze.
May 27, 2010 | LG Art Cool LA121CNP wall/window Air...
Ice is forming on coil fins
Either your coil is dirty or filter is dirty. Worst case your low on freon which would make a coil freeze.But freon doesn't evaporate if your low there must be a slow leak.
May 19, 2010 | LG Heat cool Window Air Conditioner
After 4-5 hrs of running it ice particals drop out of AC and fall out.
MAKE SURE THE FILTER IS CLEAN AND COLD COIL IS CLEAN . JUST REMEMBER 70 OUT SIDE AND 70 OR LOWER INSIDE AND YOU HAVE A ICE CONDITION. 75 INSIDE AND 75 OR HIGHER OUTSIDE KEEPS UNIT FROM ICING UP. IF ITS LOW ON FREON IT WILL ALSO ICE UP. MOST OF THE TIME THEY DONT LEAK FREON BECAUSE THEY ARE SEALED SYSTEMS
Apr 23, 2010 | LG Art Cool LA121CNP wall/window Air...
What is the function of dry mode in ac, when to use dry mode, and when to use cool mode and what about heat mode.
Dry Mode in AC is to dehumidify the room the fan cycles on and off and the indoor unit temperature drops below freezing which causes condensate to collect on the coil and as a result the humidity level of the indoor air is reduced
Jul 13, 2009 | LG L1204R Air Conditioner
Split ac not cooling
cak split in door unit 1st watar lavel and in sait watar tra blok paip.
Apr 07, 2009 | LG Heating & Cooling
My ac unit
air conditioners freeze up for one of 2 reasons, #1 restricted air flow, is the filter, /orthe evaporator (cool) coil clean?
#2 it is low on freon, causing the coils to be colder than they should be.
Nov 13, 2007 | Heating & Cooling
LG BG8000ER Air Conditioner Logo
377 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
