Question about U-Line Icemaker
U-line bi15 i have notice the ice maker is only dropping the first four ice cubes at a time there is nothing coming out of the last six slots
    Problem Solver:
  • 27 Answers
Check the hot line solenoid valve is problem
Posted on Jun 24, 2008
2 Suggested Answers
  • 286 Answers
SOURCE: U-LINE BI15 ICE MAKER
This is usually a sign of a week water pressure
Posted on Aug 24, 2009
Ice maker stopped working water coming out of front of door. what to do?
There are two sides to a water control valve Cindy. One side for the dispenser and one side for the ice maker. Feel inside the ice maker slots for any remaining ice cubes. If the ice maker has no ice fill with tap water and if after the water freezes and drops the ice into the ice container and then does not refill with water the problem points to the dual water control valve. If the ice just sits in the ice maker and does nothing then this points to a defective ice maker. What is the model number of the refrigerator?
APPLIANCE 911
Dec 06, 2015 | Refrigerators
Not making ice. Have water at fridge?? Please help?
If the ice slots are not filled with ice from the last time water filled the slots then it points to the=> Water Inlet Valve DA97-07827B If you fill the ice slots with water and allow it to freeze it should dump or drop the cubes into the ice bucket. If nothing happens then this points to the=> DA97-07365G Ice Maker Assembly List of=> RF4287HARS Parts I'm here should you have question, Thanks, Sea Breeze
Oct 10, 2015 | Samsung RF4287HARS French Door...
WHY DOES MY ICE MAKER ONLY MAKES ICE SOMETIME
Are the cubes normal - the right size, not hollow? Once frozen and the harvest cycle begins, does it take longer than a couple minutes for the cubes to drop? After the ice drops does it fill with water each time?
If everything checks OK the last thing is very important. The rate at which an ice maker produces cubes depends on the temperature of the freezer - the colder it is the quicker the cycle. Try nudging the controls up a bit and wait 24 hours.
May 31, 2014 | Frigidaire 20.6 cu. ft. Top Freezer...
Ice maker is not working properly. I noticed that it dumped water into the ice catcher and fused all the ice cubes together. Now it fills but is not producing any ice. We have the freezer temperature...
Feel under Ice maker to see if it is warm. This is a heater that comes on to loosen the ice cubes just long enough to allow the cubes to slide out of their ice slots. The only remedy is to replace the Ice maker model=> D7824706Q Ice Maker Assembly
Please let me kow if this is helpful or if something different may be happing, Thanks, Sea Breeze
Feb 27, 2011 | Maytag PBF1951KEW (19.0 cu. ft.) Bottom...
Ice Maker frost and freeze where ice drops into refrigerator door
You need a service guy to look at it. It could be water leaking or a simple case that the flap isnt sealing and the ice melts and then freezes the flap open
May 14, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Ice maker stopped making ice
hi there,
sounds like the i/m is making ice. if you have ice in the bucket, it means that the only problem is the dispensor. if you have frost anywhere, the problem is with the actuator, which is the ice pladdle. you may have a broken spring or just the ice paddle need to be replaced.
Oct 03, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Jun 20, 2008 | U-Line Icemaker
The water supply line had gotten chewed by the dog. Now the we have the line repaired its up and running. But its got the same noise and not ice is dropping. The noise I am talking about is the same noise...
IF THE ICE MAKER IS TRYING TO DUMP ICE, IT MAY HAVE A PARTIAL CUBE JAMMING THE EJECTOR BLADES, KEEPING THEM FROM COMPLETING THEIR CYCLE. FEEL THE EJECTOR BLADES, ONE AT A TIME TO SEE IF THERE IS SOMETHING WEDGED BETWEEN THEM AND THE ICE MAKER MOLD. THERE SHOULD ALSO BE ICE CUBES IN ALL THE SLOTS, ALL THE WAY UP TO THE FRONT. IF NOT, THERE IS INSUFFICIENT SUPPLY OF WATER TO THE ICE MAKER.
Apr 10, 2008 | Refrigerators
Kltchen aide icemaker
check controls make sure no one has changed settiings should be around middle setting
Is your freezer keeping the right temps?? If freezer temp has changed it will affect ice production, stick themomator and check freezer temp
Look at ice maker make sure theres no blockage of pieces of ice slowing ice maker
Oct 23, 2007 | KitchenAid KSRS25IL Side by Side...
U-Line Icemaker Logo
167 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
