Question about SanDisk Sansa e200 MP3 Player
Mp3 acting strange when hooked to charger...
Okay, so yesterday I hooked up my mp3 in MTP mode, as always, and it started acting weird. It showed the Sandisk screen, then the connected screen. Normal. But then it repeated the process. Over and over agian. It's still doing it now. I used MSC mode, it works fine with that, but I can't acess my files, probably because I always used MTP mode. And also: I did the thing that deletes everthing, and it still did the repeating thing.
Please help.
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jul 06, 2008
How do you take music off your mp3 player
The Sansa c140 can be operated in MSC and MTP mode for transferring and deleting music files.
See also setting USB mode for autodetect or MSC mode on page 16 of the manual: link to the Sansa c100 series manual.
  • For deleting files a connection to a computer has to be made in either MSC or MTP mode, see page 10 of the manual.
MSC mode means that a computer will see the player as a removable disk when connected.
It's like exploring the computer detecting the player as an external memory, showing up as a drive letter with about 1 GB of memory.
Before disconnecting the player, always safely remove hardware, the icon in the bottom taskbar on the right.
MTP mode means that a computer has software installed like Windows Media Player 10 and in this software, when started, the player is being recognized as Sansa c140.
Before disconnecting the player, wait for the message that it is allowed to disconnect the device.
How to use Windows Media Player 10 ? See the site of Microsoft:
http://www.microsoft.com/windows/windowsmedia/player/10/using.aspx
Need more help ? Just post a comment.
Dec 27, 2009 | SanDisk Sansa c140 MP3 Player
How do i dowload music to my opal M4208GR
Manual for RCA Opal M4208GR:
http://www.voxxsupport.com/images/manuals/M4208GR/media/M4208GR_DOC_OM.pdf
This player has default setup MSC mode, seeing the player as a flash drive also called a removable disk.
MSC = Mass Storage Class
When seeing the player as a removable disk in Windows Explorer:
Drag and drop the song, with mp3 or wma format, into the Music folder on the player.
Note: some wma files may have DRM = Digital Rights Management. These files might be copied or transferred onto the player but cannot be started for playback.
Important: in MSC mode always safely remove hardware, the players' removable disk, at the bottom right corner of the task bar.
Transfers to the player can also be done with software like Windows Media Player 11, RCA easyRip or other software from music stores.
This can be done in MTP mode. MTP = Media Transfer Protocol.
How to switch to MTP mode, seeing the player as Media device:
In the players Menu go to Settings. Go to Protocol. Select MTP mode / switch from MSC mode to MTP mode.
Oct 01, 2009 | RCA OPAL M4001 MP3 Player
Change MP3 from USB to MSC mode
Usb mode is in settings push center button choose between msc or mtp.... MSC will allow you to see the expansion card mtp won't.....MTP shows you your music folder in the media folder thats where you put your music plus expansion.....If no usb mode the player is manufactored to be in msc mode make sure your usb 2.0 driver is installed
Jun 27, 2009 | SanDisk Sansa e260 MP3 Player
Copied files, not to be found once mp3 player is turned off.
Plug in your mp3 player and remove any music or what ever you have on it then open explorer and click on tools and then folder options and then view click on don't show hidden files hit okay... Then check your mp3 player for a USB mode make it mtp or msc...Mtp makes it a mp3 player Msc makes it a disk drive it doesn't matter which now start Dragging and dropping your music in to your mp3 player.................When you put files which are hidden in the player the can't be seen by the player
Feb 28, 2009 | SanDisk Sansa e260 MP3 Player
Cant find mp3 player
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
Sansa Recovery Tool
PDF how to use recovery tool
Answer The power may be depleted fully or the Connect might be hung during boot. Charge the Connect for at least 20 minutes using the AC charger. If the Connect will not turn on after 20 minutes charging with the AC charger, you can then try using the Connect Recovery Tool.
The recovery tool will reformat and reload the latest firmware to the Connect. The tool and instructions are located here.
Note: Ensure the Connect is turned off by holding the power button 8-10 seconds before initiating the recovery sequence.
Answer ID: 450 Created: 05/14/2007 Updated: 11/08/2007
For Products: MP3 -> All Sansa Connect
Category(s): Audio Player
Explanation:
The e200 can operated under two different modes, MTP (Media Transfer Protocol) mode and MSC (Mass Storage Class) mode.
To see the MicroSD card as a Removable Disk, the e200 must be in MSC mode. The following screen shots show how the "My Computer" screen will look when the device is plugged in under each mode.
MTP Mode
MSC Mode
Solution:
To change the mode from MTP to MSC go to the Main Menu of the e200.
If you're e200 is plugged into your computer, please unplug it first.
1) Scroll to the "Settings" > "USB Mode" > "MSC Mode" and push the select button.
2) Connect the e200 to the computer using the USB cable provided.
3) Go to "My Computer" and there will now be two Removable Disk drives similar to the MSC Mode image on top.
Answer ID: 356 Created: 03/23/2006 Updated: 03/24/2006
For Products: MP3 -> All Sansa e200 Series , Mobile Memory Cards -> All microSD and microSDHC
Category(s): Audio Player , Computer Only-> Windows XP
Apr 01, 2008 | SanDisk Sansa e260 MP3 Player
No files found
Switch it to MTP or auto mode in settings menu
Mar 27, 2008 | iLO (2 GB) MP3 Player
My damn sandisk is dumb
well what mode did you transfer the songs to the player there are actually two modes of transfer on the device the 1st is called MSC and the other is MTP. If you have transfer them to the player in MSC there should be a music folder try changing your settings to Show Hidden FIles and Folder and also try it on MTP mode.
Dec 07, 2007 | SanDisk Sansa e250 MP3 Player
Deleted songs still appear in the player when using the player
most of the problem is id3 tags if this happens try using other low formats like wma or download the mp3's again to delete them go to msc mode show hidden files and delete
(for some strange reason i just switch it to msc mode plug it in unplug it and they are gone ?)
Nov 15, 2007 | SanDisk Sansa e250 MP3 Player
Broken
hi try formating the mp3 then check if it still has the music.
Jun 30, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
24 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
