Question about Pentax ZX-60 35mm SLR Camera
Av is flashing
When I turn the camera on the Av starts blinking and the camera won't do anything. I don't find this problem in the troubleshooting part of the manual and can't seem to get it to do anything.
Help please!
  • 1 more comment
  • scwhitings Jun 23, 2008
    yes, I have and the only thing it shows it the av flashing and that it is on the first picture. I have the apeture set on A and even when I try to push down on Mode and move the dial the screen is blank except for the Av flashing
  • Anonymous Feb 03, 2009
    i have the same camera doing exactly the same thing, it happened when i was playing around with the lense and may have damaged the autofocus, but why av?
  • Tim Babcock
    Tim Babcock May 11, 2010
    Have you tried taking the batteries out and putting them back in to reset the camera?
Make sure the aperture setting on the lens is set to "A". Solved the problem.
Posted on Dec 19, 2009
  • 2,794 Answers
I cant find a book on Pentax support website for this camera. It is http://www.pentax.jp/english
I have a feeling the the camera is in the wrong mode for viewing. Does this camera have an option to plug an AV cable into it and display the image on a monitor rather than the screen? It could be a cable that controls it or a setting on the camera that needs to be turned off.
You could take into a camera shop and they can get the camera out of that mode and show you how it works.
Posted on Jun 23, 2008
Error why coming
Can you hear any fan or drive sounds? If you don't hear anything at all when you try to turn the laptop on, no little LED's light up, the problem almost certainly isn't related to the hard drive. So if you don't have a live screen, start with the LCD troubleshooting flowchart, and if you don't have any activity at all, start with the power troubleshooting flowchart. Even if the hard drive has failed at the electro/mechanical level and won't spin up, this wont prevent the LED's on the laptop from lighting up, or the LCD from displaying the BIOS information and complaining about the lack of a boot device.
Ford F150 Body Kits
Jun 07, 2012 | Computers & Internet
My sb-200 flash won't work with my d200
Go to menu then shooting and turn on ttl
Jan 17, 2012 | Nikon SB-400 Flash
Y olsdmobile lss 98 is on security light flashing and won t star how to fixed
put key in ignition and turn all the way like your'e going to start it but don't start it. the security light is going to be flashing. leave it for ten minutes like that until the security light turns solid(not blinking). Turn the key to off and then start it. The tumblers in the ignition lock cylinder are no good any more and the ignition switch needs to be replaced and reprogrammed.
Aug 15, 2011 | 1997 Oldsmobile Achieva
My Nikon Coolpix s230 flash won't work. It just blinks red in the lower right hand corner. I've tried all the settings and they all won't flash.
If there is a problem with the flash itself or the mainboard connection to the flash it will not charge. If the flash won't charge then it won't go off when you take a picture. The only way to fix the problem is to replace the flash with a good used one and see if that fixes it. If not, then you need to replace the mainboard. Good used parts can usually be found online for cheap; that auction website doesn't pay me to type their name, so I don't, sorry. Hope this helps!
Thomas Drayton
Owner, www.darntoothysam.com
Affordable Digital Camera Repair
Jul 24, 2011 | Nikon COOLPIX S230 Digital Camera
My camera won't flash no matter how many new batteries I put in it. It will take pictures that don't require a flash. I've reset everything twice and nothing has worked. Contacts are clean. ...
Some Canon cameras use some of the screws around the perimeter of the camera to serve as a safety switch to prevent activation of the flash if the case is opened. See this article for more info.
Jul 20, 2011 | Canon PowerShot A720 IS Digital Camera
2001 Dodge Ram 1500 2WD truck. From time to time the turn signals won't blink. They light up but do not flash. They will sometimes begin to blink and then stop blinking. Sometimes they blink,...
check the earths on the lights and the bulb wattage ,it should be 21watt ,but if its the weird funny system on a american car then who knows ,where the stop light is the indicator and it flashes red and cuts out ??
May 25, 2011 | 2001 Dodge Ram 1500 Truck 2WD
JVC AV-F29MX3 I was watching a film on my DVD connected to the TV, when suddenly the screen turns black with no sound heard. Also the front light indicating 'ON TIMER' and 'ECO' started blinking in red...
usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound ..but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective .................. so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective.......... price of EHT will be between Rs.250 (US$ 5) to Rs.600 ( US$ 12) ........iam from bangalore ( 09986222774, sathyavijayasarathibabu@ymail.com ) .....i don't have any idea about EHT component's price & service charge in your area........this problem cannot be solved by user unless user is a technical person having idea about components (resistors, transistors,diodes,...etc..), having multimeter , soldering iron & other tools...so my suggestion call TV service engineer or contact jvc service centre.........
Apr 21, 2011 | JVC AV-F29MX3U 29" TV
Pentax ZX-60 35mm SLR Camera Logo
300 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
