Question about Lands Phones
Siemens Digital Multiline DM25 Phone - programming help needed!
Hopefully someone in the world can help me out! I have been given one of these telephones as part of my new job (everything in our office is recycled from other offices). No instructions came with it, and while it seems to work fine (I can get get incoming and outgoing calls) I can't programme it! I need to know how to programme call divert, add speed dial numbers, mute calls, transfer calls and switch on the answering machine (if there is one!)
PLEASE help me out! I've searched the internet to no avail!
  • 14 Answers
SOURCE: Transferring incoming calls
Press transfer then dial 9 plus the phone # you want to transfer to. If this does not work , you may be restricted in software from trunk to trunk transfer.
Posted on Apr 01, 2008
bbtoast
  • 319 Answers
SOURCE: I can't find the instruction manual and forgot how to program a greeting
HERE is the manual!
Posted on Jun 17, 2008
SOURCE: NEC Topaz Office Phone - How to program phone to call forward off premise
i need to fix the date and time in our telephone NEC Topaz IP2AP-6TXD Tel (WH)
Posted on Oct 21, 2008
SOURCE: Storing Speed Dial Phone Nmbers
Emergency/quick dial numbers: Pick up handset, push store, enter the phone number (it will not call the number), push store again, Push A,B or C. hand up handset. Frequently called numbers, pick up the handset, push store, enter the phone number, push store again, push key pad 1, or 2, etc. for memory location. Hang up handset. How to change a stored number. just repeat the sequence. How to clear a stored number, repeat the storage skip step 3 (do not enter the phone number). How to correct an error while storing, just hang up and repeat.
Posted on Jun 06, 2009
  • 149 Answers
SOURCE: DTU16D-2 Multiline issues
You need to enter program mode. go into MB 4-12 for your port number and remove line keys 3 and 4 from your phone. You should also remove the 2 dead lines from the trunk group so no one can access them. 3-03.
ldtsnj.com
Posted on Jun 13, 2009
Connected to ISDN2 but only allowing one inbound call at a time
there is a setting in most ip phone configurations for max simultaneous calls. or make sure your provider is allowing more then one.
May 27, 2015 | Siemens DX800A Gigaset DX800A Multiline...
I lose the pin code for my Siemens gigaset DX800, how i can reset the pin?
My dear:
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
But:
Don't try to enter a PUK code without knowing the right one.
You need to call your service provider to get this code.
It can be as many as 8 digits, and it is random. If you enter too many wrong codes,
you can permanently damage the device. So Please You Go to Service office
and Get the Duplicate Sim From Office Oprater Same Your No Problem will Solved
Jul 28, 2012 | Siemens DX800A Gigaset DX800A Multiline...
Siemens M55 Phone code locked
please send unlock code:
imei: 352027003723159
email: giangnh1004@gmail.com
thanks
Jul 25, 2012 | Siemens m55- world...
I Need i driver for Siemens SX56 Pocket PC
This application helps you to synchronize your pocket pc to your computer
download this link : SYNC MY PHONE TO PC
And here is the procedure
1. Install the given application
2. run the program
3. connect your phone to the computer using usb cable
4. some driver will install and wait until the phone recognize by computer.
Now your phone is synchronize on your computer,you can transfer file from it vice-versa.
Thank you for visiting FixYa.
Jul 19, 2011 | Siemens SX56 Pocket PC
Inherited this system, but have been unable to program. It is business multiline system, and at pesent we cant answer it. I have tried several online solutions to no avail. HELP. At one point the sd...
With any luck, if you catch the SD card right, you can corrupt the data and have to totally reprogram the system.
The TDA/TDE/NCP systems can be programmed from a phone connected to the system if it has the right Class of Service and you know the passwords. I don't recommend it.
You may be the smartest person in the world, but without the software, your inherited system is somewhat of a paperweight and if you aren't careful, you'll break it.
Here's the part where I suggest you call a Panasonic dealer.
If you're in the US, try http://www.kxt411.austintele.com/
Carl
Mar 08, 2011 | Panasonic KX-T7630 Corded Phone
My siemens sx66 cingular has alphanumeric password on, someone tried entering wrong password severally and the phone is not accepting my original password any longer, i tried hard reset and its not...
Hello Sambicho.
The a1b2c3 may be the 'password reset' code after which you must enter YOUR original password, which it hopefully still has stored in it's memory.
Otherwise the 'someone' may have changed the user password.
Hope this is helpful.
FYI: passwords are case-sensitive.
Oct 11, 2017 | Siemens SX66
If someone is using a headset with a TS-200 multiline system, will incoming calls be picked up by the phone in headset mode first?
That should be a configurable setting. Speaker, Headset, Speaker then headset or Headset then Speaker.
Jun 25, 2010 | TalkSwitch TS-200 Phone
PUK code for my old siemens M65 phone please as my sim card supplier has changed hands and they dont have it.
Dont contact simcard supplier.Contact the sim card customer service centre directly just through phone... PUK code can be given only by your service provider which is specific for each and every mobile number.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no. If you cant contact through your phone get some other phone and contact them.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider cangive it nobody else in this world nor any software.
Go to the below link and you can confirm that the above procedure works and there is a testimonial given by the customer too. http://www.fixya.com/support/t3582685-phome_lg_ke670_put_security_code_phone
Mar 18, 2010 | Siemens M65
Nortel t316e phone only rings 2 times
You could have a CICS, and MICS or a Nortel BCM. Which do you have?
You will need to access admin programming, do you know how?
Jun 26, 2009 | Nortel T7316E 2-Line Corded Phone
ldtsnj.com
Jun 09, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
Lands Phones Logo
427 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
