My printer MP 460 is telling me that I have a paper jam. I did have a slight paper jam but removed it as instructed. Now I cannot reset the message. I even reinstalled the software. The message is still there.
  • jeff495 Apr 14, 2009
    My MP460 is now saying "Paper Jam" even when I don't have any paper in it. Not sure what is going on.
    Problem Solver:
  • 7 Answers
This problem can ONLY be cleared by a Canon Service Representitive. Contact your Canon Service Representitive.
Posted on Jun 23, 2008
How do I clear a scanner jam for a MFC 8480
Hi Judy,
Please follow the steps posted below:
1. Remove the paper from the MP tray
2. Remove any jammed paper from in and
around the MP tray
3. Close the MP tray. Then open the front
cover and close it to reset the machine.
4. Open the MP tray again
5. Fan the paper stack, and then put it back
in the MP tray
6. When loading paper in the MP tray,
make sure that the paper stays under
the maximum paper height guides on
both sides of the tray
Let me know if this resolves the issue,
Hunter Quinn
IBM Help Desk
Dec 04, 2014 | Brother MFC Office Equipment & Supplies
My Brother HL 4040cn showes a Jam MP Tray. There are no papers jambed but it will not reset.
Hi James,
Remove the paper from the MP tray.
Remove any jammed paper from in and around the MP tray.
Fan the paper stack, and then put it back in the MP tray.
When loading paper in the MP tray, make sure that the paper stays under the maximum paper height guides (1) on both sides of the tray.
Press Black (Mono) Start or Color (Colour) Start to resume printing.
Still having Problem Then follow Us For
Brother Printer Support
Feb 20, 2014 | Brother HL-4040CN Laser Printer
Kyocera 2020d WONT PRINT Load Mp Tray
load a4 paper in bypass or the mp tray as it is also called
Jun 08, 2017 | Kyocera FS-2020D ECOSYS Monochrome Laser -...
MP 640 paper jam message that wont clear
door. 3 Push down on the green lever. 24x Paper Jam, Check Tray 1 Gently open the ... Jam, Check MP Feeder Gently pull the jam straight out of the multipurpose feeder. 202 Paper Jam, Open Rear Door 1 Open the ... side to locate a green lever. Note: To clear the Paper Jam error message, you must remove ... above Tray 1 when the duplex function is in use. To clear this type of jam, follow the instructions under the appropriate paper jam message. Lever 4 Gently pull the jam toward you. 5 Insert the tray. Note: Make sure... under the print media is locked down. 23x Paper Jam, Remove Tray1, Pull Down ...
Jul 29, 2012 | Canon MP640 All-In-One InkJet Printer
Canon MP830 will not print Error code 5C10, And 5100
5C10 seems to indicate a paper jam. 5100 indicates either a paper jam or ink tanks not seated properly.
A) Paper jam: There is a rear cover on this model. Many paper jams cannot be seen from the outside. Sometimes even a scrap of paper from a previous jam will disrupt the paper path.
B) Follow your manual for installation of the ink tanks. Remove and replace the ink tanks carefully following the instructions.
C) Should these remedies not fix the problem, you can try resetting the device:
1) Press and hold the <On/Off> button until the display on the machine goes blank. (If this is unsuccessful, unplug the power cord).
2) Wait approx. 10 seconds and power back on. Wait until the printer completes its startup routine before trying another print job.
3) If solution fails, your MP 830 may require repair
Dec 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My canon mp 830 all-in-one printer says 6A00,
no need to reset your printer, the things your should do is you just open the over at the back of your printer, then you can see a paper hang on, then please remove it, then try to print, if it does not work open also the tray which is your bond paper stored, just see if there is also a bond paper hang, then remove it, then print again, that the cause of paper jam
 Good Luck!!
Jul 01, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Hi I get this 250.07 paper jam check mp feeder on Lexmark t644
Please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Lexmark T644 Laser Printer
Canon pixma mp 160
After you remove the paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 28, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon mp 830 getting error 5000
Canon site if the link does not work just go to -> support-> select Multifinction --> Inkjet --> Pixma MP830
Then type in - error code 5000 - (Leave off the " - "
Select #3 - ERROR LCD: Error code (5xxx through 9xxx) appears on the display -
1. Press ON/OFF switch to reset the multifunction device
2. Press Stop/Reset and ON/OFF to reset the printer
3. Removing paper jams MP800R / MP830 / MP530
4. The MP830 may require repair
5. Unlock the scanner lock switch (MP800R / MP830)
The links above detail each instruction. If they do not work here then got directly to the Canon Site.
Basically at one point there was a paper jam so clear it and then reset the machine.
Worked for me. Good luck to you :)
Oct 24, 2008 | Office Equipment & Supplies
Error 391: paper jam
See below for Error 391:
Clean the feed roller and the pad when [391: Paper Jam] appears frequently.
(1) Remove the paper cassette.
(2) Clean the feed rollers (large and small) with tightly wrung wet cloth or an LED lens cleaner.
Note! An LED lens cleaner is enclosed in an optional replacement toner cartridge.
Feed roller (large)
Feed roller (small)
(3) Clean the pad on the paper cassette with tightly wrung wet cloth or an LED lens cleaner.
Note! • If [392: Paper Jam] appears frequently, clean the second tray (option) in the same way.
• If [390: Check MP Tray] appears frequently, clean the feed roller of the multi-purpose
tray in the same way.
Apr 04, 2008 | OKI C5200n Laser Printer
101 people viewed this question
