SOURCE: LG DR275 Initialize problem
hello..Carol..please refer to your user manual and look in the chapter that includes "how to" maybe you don't have to manually initialize the disks..this will be done automatically...keep it easy...please tell me how it went !...good luck...Ron
SOURCE: liteon lvw-5045
it maybe the spindle motor that rotates the disc thats why there is no information read by the laser or the laser itself is the problem. if it is only the motor it can be replace but the laser it should be compatible or the same model. one simple thing to do open and try to clean the optical lens by a cotton buds gently rub around the lens and close and try.
SOURCE: Samsung DVD Camcorder SC-DX103 stops
I found this for data recovery. I don't have the problem you guys have, but came across this site.
http://www.cdroller.com/?gclid=CMC_iqihoZgCFQrFGgodwnf7mQ
SOURCE: DVD+R stuck in logik ldvr808 recorder
Pull out the power cable and leave for a few minutes then plug it back in. Now before the DVD player tries to play the disk press EJECT or OPEN/CLOSE button continously until it releases the disk.
SOURCE: when I put in a new a recordable dvd disc in my
There are three things you can do that will eventually give you a working solution. Depending on the level of problem. Start with 1 progress to 3 until it works.
1. Use a cleaning disc. (one that use an alcohol based liquid)
2. If the cleaning disc does not solve it, you can use an ear bud, with some iso-propyl alcohol to clean the DVD lens on the drive directly. (you have to open the player and the drive)
3. The guaranteed working solution is to replace the DVD drive inside the player. This is quite a simple process, as most players use a standard IDE DVD-ROM or DVD writer.
You simply remove the face plate, (apply power to the drive, and press eject first) the tray will open. Unclip the tray face, and then with the tray open you can unclip the plastic face plate too.
Remove the old drive, and fit the new drive by reversing the removal procedure.
Once everything is assembled you should be able to watch DVD's again. If you can't find a cheap DVD drive locally, try ebay.
I have done this on over 50 players for my clients in the past. I use LG IDE DVD roms and IDE DVD writers for the DVD recorders, irrespective of brand.
Let me know how it goes.
