Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
My power supply is fault
Power supply for me camera
    Scholar:
  • 46 Answers
Hi
If you could tell me the model number and make of your camera I can locate the site for you to buy a new power supply. As it is, all I can reccomend is that you do a google product search or search on sites such as amazon for "(your camera name) power supply"
There will almost definately be somewhere that sells replacement power supplies.
Hope this helps
Philip
Posted on Jul 13, 2008
I bought a pro-series 960H from Sam's finally got it installed. It worked fine for about 5 month one camera started to looks like snow.Sam wont take it back said over 1 year what to do
If it is the camera at fault get it repaired. Probably a wiring issue I would think, check the cabling and power supply.
Aug 17, 2017 | Cameras
Tip
Ducati Fault Codes
Engine Fault Codes - Ducati 749/999
To see the fault codes, with the ignition off hold both dash buttons down and turn ignition on.
1.1 TPS Disconnected
1.2 TPS short circuit to earth
2.1 Pressure Sensor short circuit to power supply
2.2 Pressure Sensor shorted to earth
3.1 Water Temp Sensor shorted to power supply
3.2 Water Temp Sensor shorted to earth
4.1 Air Temp Sensor shorted to power supply
4.2 Air Temp Sensor Shorted to earth
5.1 Battery Hi
5.2 Battery Low
10.1 Hor. Coil shorted to power supply
10.2 Hor. Coil shorted to earth
11.1 Ver. Coil shorted to power supply
11.2 Ver. Coil shorted to earth
12.1 Inj1 shorted to power supply
12.2 Inj1 shorted to earth
13.1 Inj2 shorted to power supply
13.2 Inj2 shorted to earth
14.1 Inj3 shorted to power supply
14.2 Inj3 shorted to earth
15.1 Inj4 shorted to power supply
15.2 Inj4 shorted to earth
16.0 Pump Relay
17.1 LH Fan shorted to power supply
17.2 LH Fan shorted to earth
18.1 RH Fan shorted to power supply
18.2 RH Fan shorted to earth
19.1 Starter Solenoid shorted to power supply
19.2 Starter Solenoid shorted to earth
30.0 ROM/Eprom error
34.0 Signal Panel Sensor
36.0 Speed sensor
37.0 Immobiliser (transponder)
37.1 Immobiliser (antenna)
37.2 Immobiliser (instrument panel serial driver)
37.3 Immobiliser (serial cable disconnected)
37.4 Immobiliser (ccm serial drive)
37.5 Immobiliser (key not recognised)
37.6 Immobiliser (ccm program)
38.0 Can Line error
Source http://moto-files.weebly.com/ducati-fault-codes.html
on Dec 20, 2016 | Motorcycles
Power supply units on SWDVR 83425H keep failing and have to be replaced. We are unable to use 4 of our 8 cameras
If power supplies consistently fail there is either a fault on the appliance or the power supply is not sufficient for the work, most likely the latter.
I suggest you look at the specifications and add up the current required for the DVR and all the cameras and compare it with the output current of the power supply.
The power supply should be able to provide at least 40% more current than the installation requires. For cool running and reliable long life double is more realistic, but basically the bigger the better. Because a DVR and camera installation tends to cost more than pocket money the power supply should be a good quality unit with as much built-in regulation and protection as possible.
I hope this helps.
Apr 12, 2016 | Televison & Video
I need help sony dcr-sr78 shutdown itself i need solution
hi,
I understand that the power supply is not working in your camera if you tested with both battery and charger, then there must be fault in side, must open it, measure the dc power from the primary point to the mother board up to where the power supply goes, on the mother board several fuses lays, if any of it open should replace with the same ampere fuse, voltage regulator SMD could be faulty, if you don't get fault in these all, then check the processor chip.
Dec 16, 2015 | Sony Video Cameras
Camera will not switch on
power supply unit fault if the news battery not even able to turning on the camera. Need service.
Dec 12, 2012 | Canon PowerShot S3 IS Digital Camera
It turns on and then turns it self off
Turn the camera on with out inserting the battery and see. f you face same problem then its a camera internal power supply unit fault. You need to visit service center for repair.
Aug 06, 2012 | Samsung Digimax S500 Digital Camera
When i take pictures my flash doesn't go off,why?
if the camera is set correctly to use the flash while taking pictures then the flash bulb is possibly blown or there is a fault with the power supply line to the bulb
Nov 30, 2010 | Kodak EasyShare M530 Digital Camera
I tried to connect a power supply to my Canon Powershot A560. (wont ever do THAT again.) I am getting the "lens error, Restart camera" message. The lens ill not close either. How do I restart?
Unfortunately I fear that you have plugged a wrong power supply and possibily damaged the camera mainboard. Since these boards are very delicate just a momentary power can damge these circuits.Hence I request that since the fault occured due to a forced problem it is important that you take help from a camera service centre or preferably Canon to look into the seriousness of the fault. take estimate and decide if resonable. Good day
Aug 16, 2010 | Canon PowerShot A560 Digital Camera
Possible software problem?
I don't remember a little camera light on the control panel of my 6110 (though there is a little telephone light on the left side that usually indicates the fax/modem line is in use), but it sounds more like an electrical fault. I suppose you could try to replace the power cord and power supply, but my guess is that the fault is intermal. You're most likely looking at taking the printer in for service. Good luck.
Sep 01, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
