Question about Motorola Mobility HS850 Consumer Headset
Cannot hear anything with HS850.
When it is paired and "connected" the far end can hear me but I cannot hear them.
  • Anonymous Jun 28, 2008
    I cannot hear them.
  • nshauck13 Jul 01, 2008
    i used my hs850 with my ps3 and it worked fine for awhile but then the voices on the end started coming out really bad and now i cant even hear them can some one please help me i realy need this to work
Throw it away and get something else.
Posted on Oct 30, 2008
Can hear caller but they can not here me.
Posted on Jun 30, 2008
Samsung HM700 Bluetooth Headset's light keeps flashing red and blue and can't hear anything, the person on the other end can't hear anything either. Tried re-pairing, but it doesn't work.
Pairing is not the same thing as connecting. The LED will go solid when you complete the next step which is connecting. With headsets that is usually done via the audio source device.
Mar 07, 2014 | Google Samsung HM7000 Bluetooth Headset
Dropped calls
Probably dropping because of the crappy twisted pair service at the far end micro-breaking the connection. Not enough to blow an analogue line, but digital scrambles at line static.
May 31, 2013 | SKYPE Computers & Internet
There is not a subwoofer input jack on the back of this subwoofer. There are a set of input (negative and positive) terminals and a set of output (negative positive) terminals like would hook speaker wires...
On the back of the sub woofer you have two sets of binding post / some have spring clip terminals ( red & black ) labeled Speaker In ( sometimes High Level In ) and Speaker out.
Take 2 pairs of speaker cables and connect one end to the speaker out socket of your amplifier ( left & right ) . The other end of the cable should be connected to the sub woofer's Speaker In socket , Red to red and black to black. Now on the Speaker Out socket of the sub woofer connect your existing pair of speakers using another pair of speaker cables. If your sub woofer has a Hi Pass filter built in , you may not hear bass coming from your existing speakers with this kind of connection. Good if you have small satellite speakers.
Mar 12, 2011 | Audio Players & Recorders
How do i pair my hfs001
Hello, Press and hold the "Answer/End" button for about five seconds. When you hear "Pairing Mode," the speaker is now discoverable by other Bluetooth devices. Turn on your cell phone;s bluetooth connectivity. Once your cell phone has found the HFS001 it will ask for a pairing code the code is "0000". The phone will then connect to the HFS001. Enjoy your hands free experience!
Mar 05, 2011 | Jabra Bluetooth Car Kit with Night Driving...
Begin with your headset turned off. Then, press and hold the answer/end button until the indicator light is solid lit in blue. It is in paring mode. Now, make your phone's bluetooth application search for new devices. After a while, the BT-350 should appear on-screen. Select it and make the application proceed. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing proces is successful, the headset should enter stand-by mode. The pairing process is timed.If you fail to complete it, you'll have to start it over, from the phone turned off phase. Once paired, whenever both your headset and your phone's bluetooth radios are turned on, they should connect to each other automatically. Otherwise, just press the answer/end button, and the link should be done again. In this case, it might be prudent to place the headset in your ear and check if the voice channel has been actevated (you can actually hear it). If so, either press the answer/end button again, or turn your phone off (i.e. just put it in stand-by), and make sure the voice channel has been cut off. The bluetooth connection will still be in stand-by.
Hope you are able to sort your problems out.
Cheers! Carlos
May 28, 2010 | Jabra BT350 Bluetooth Headset Headset
IPhone and bluetooth - volume is too low on the other end????
make sure volume on your phone is all the way up as well as volume on your bluetooth
Jan 11, 2010 | Apple iPhone 3G
Just came across your question while searching for the same answer - Here's what I found out:
When it's off, press and hold the on button for 5 seconds - it'll turn on, but keep holding until you hear the short beep - the light's on and you're where you want to be. Here's the full text that I found from the manual:
-With the HBM-710 off, press and hold the PWR/END button for 5 seconds
(You will hear a short beep and the LED indicator will stay red, when the device enters pairing mode)
-Using your handset, find the "Bluetooth menu" and "search for" or "add" new devices
- Select "LG HBM-710" from the list of devices and pair it with your headset
- When asked for the Pass/PIN code during the pairing procedure, please enter "0000" (4 zeros)
- Once pairing has been completed successfully, you will hear a beep
- After pairing successfully, be sure to "connect" to the LF HBM-710
- If you want to pair with other devices in the future, the headset must be in "Pairing mode"
- If it will be not connected the "Pairing" for three minutes, it will be turned off.
Apr 03, 2009 | LG HBM-710 Wireless Headset
Could not connect to our VSX 700 polycom over ASDL
for VC over IP, both end should have a dedicated bandwidth with PUBLIC IP.
this solves most of the problems that are faced in a vpn or shared network like situation!!!!
Nov 22, 2008 | Polycom VSX 7000 Video Conference
Well my user manual for HBM-550 says:
Prior to using the Headset for the first time, you must pair it with a Bluetooth enabled handset.
With the HBM-550 off, press and hold the Pwr/End button for 5 seconds,
You will hear two short beeps and the LED indicator will flicker in red and blue alternately, when the divice enters Paring Mode.
Using your Handset, find the Bluetooth Menu and "search for" or "add" new devices.
Select "LG HBM-550" from the list of devices and pair it with your handset.
When asked for the pass/PIN code during the paring procedure, please enter "0000" (4zeros).
Once paring has completed successfully, you will hear a beep.
After paring successfully, be sure to "Connect" to the HBM-550.
If you want to pair with other devices in the future, the headset must be placed in pairing Mode.
If the HBM 550 is in "Paring Mode" for 3 minutes, without being paired to a device, the Headset will automatically turn off.
Aug 13, 2008 | LG HBM-550 Wireless Headset
Motorola Mobility HS850 Consumer Headset Logo
107 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
