Question about SanDisk Sansa c240 MP3 Player
Tried the solution you offered for c240....
Hi there, thank you for your response. I held down the volume + button and plugged it into my computer like you said, and the computer did start to recognize it. However, instead of the new hardware wizard I got a "USB device not recognized" window saying that "one of the USB devices attached to this computer has malfunctioned, and Windows does not recognize it.....try reconnecting the device. If Windows still does not recognize it, replace the device." How should I proceed? Thanks!!
  • 8,596 Answers
Go to Start --> Control Panel --> Printers and Other Hardware --> System --> hardware --> device manager --> right click on the usb port that is malfunctioning (should have a red or yellow exclamation by it), right-click it and click on Update Driver
If that fails, try another USB port on the computer to see if you have more success
Posted on Jun 24, 2008
Can not get volume to lower
On my player you have to push the A-B button first then use the button your describing to adjust the volume.
Dec 04, 2009 | Jensen SMP-115 MP3 Player
Help please
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Jun 29, 2008 | SanDisk Sansa e260 MP3 Player
My sandisk c240 charges when plugged in but fails to be recognized on the computer
There is quite possibly a problem with the USB cable or the USB port on the computer, but try this shortcut force to force the computer to recognize the Mp3 player: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Jun 23, 2008 | SanDisk Sansa c240 MP3 Player
Computer won't recognize it, won't turn on
-Tha Mp3 Doctor
Jun 20, 2008 | SanDisk Sansa c240 MP3 Player
Zen V Plus Help Needed
Hi, I had the same problem with my Zen V Plus. I held the volume + button in and connected the Zen to the computer using the USB cable and the Zen came back to life ! Try it - it might just work like it did for me.
Jun 15, 2008 | Creative Labs ZEN V Plus MP3 Player
Zen stone mp3 player not switching on
Mine was also completely dead, with the reset doing nothing! I held the vol+ and the Play button at the same time and it was good to go. Holding just the play button or the vol+ button didnt acheive anything. But as I held both together, It came back to life instantly and I havent had any problems with it (for a week so far).
May 08, 2008 | Creative Labs ZEN V Plus MP3 Player
Sansa c240 isn't being recognized by the computer...but...
-Tha Mp3 Doctor
Mar 23, 2008 | SanDisk Sansa c240 MP3 Player
Mp3 c240
Not vista compatible, not Mac compatible
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
Sep 21, 2007 | SanDisk Sansa m250 MP3 Player
Frozen !!!
Press and hold the volume up + key and the select button to perform a "hard reset" Best of Luck.
Aug 22, 2007 | SanDisk Sansa c150 MP3 Player
Sansa won't power up
May 28, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa c240 MP3 Player Logo
254 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
