Question about GPS
Garmin NUVI There are no external cables on my NUVI.
    Genius:
  • 1,036 Answers
I think your request is still live, but you may not be able to view all the answers.
I only suggested lifting any antenna it may have, and warranty information.
If all attempts fail, it can be returned for repair rather than voiding the warranty at this stage.
Garmin Warranty information is Here for you.
Posted on Jun 24, 2008
My garmin in nuvi 1350 will not charge it keeps saying the battery is low
Nuvi 1350 charges in 4 to 8 hours. If your Nuvi is not accepting a charge, you may have a loose or bad USB cable. Note that the Nuvi can be charged with a phone charger. Charging it with a connection to a computer moves charging time toward 8 hours and more towards infinity if you don't have the driver installed on the computer. Turn the Garmin off. If the driver ins installed in the coputer, plug the Garmin into the computer and then hold down the power button on the Garmin for 30 seconds.
Sep 10, 2017 | Garmin GPS
Garmin nuvi will not acqire satellites
Please indicate what Nuvi model you have. Some Nuvi models have an external antenna port while others do not.
Feb 12, 2015 | Garmin GPS
My garmin nuvi 660 is frozen . how can I do?
Reset the nuvi 660:
1 Disconnect from external power.
2 Flip antenna up.
3 Locate and press small button labeled "RESET" in the antenna recess on rear of nuvi 660.
4 Connect to external power source.
The nuvi will reset, power up and operate normally. If this was helpful, please rate it 4 thumbs up - thanks & good luck!
Sep 20, 2011 | Garmin Nuvi 660 GPS Receiver
HOw do you charge it?
This unit comes with a charger (AC). There is alxo a car charger. Both have a USB connecter that plugs into the side of your unit.
Sep 20, 2011 | Garmin nuvi 350 GPS Receiver
How can I update my Garmin 255 I do not have a USB
You can not update your garmin nuvi without a mini USB cable. You may have one for some other device e.g. an external hard drive, camera, camcorder or other appliance that connects to a computer. If not your only option is to buy one.
Feb 13, 2011 | Garmin nuvi 255W GPS Receiver
Garmin 205 how to charge on computer?
follow the steps below:
1st: make sure your NUVI is OFF then plug in the usb cable from the computer to the NUVI, after you hear your computer ding from new device connected, and the NUVI displays the computer icon move to step 2
step 2: if you have xp go to START and MY COMPUTER. with vista its START then COMPUTER button on the right side
step 3: with MY COMPUTER window open hold the NUVI power switch to the ON position and RIGHT CLICK the NUVI device logo (blue triangle) and select EJECT .. ( DON;T HIT SAFiLY REMOVE)
step 4: when you see GARMIN display on the screen you can letgo of the power button on the NUVI ****** if you unplugthe usb it will display message stating EXTERNAL POWER LOST SWITCHING TO BATTERY POWER***** while it is plugged to the computer the battery meter will disappear.
Good luck.
May 27, 2010 | Garmin nuvi 205W GPS Receiver
When connects to power in the car, it thinks it is connecting to the computer.
if your charger not original garmin you should make this modification on mini usb port. tested works with non original chargers (min 500mA).
Nov 14, 2009 | Garmin nuvi 260W GPS Receiver
I cant get my garmin 200series to accept pictures
Actually you do not need to use an external memory...
Just plug in the Unit using a mini-USB to USB cable to the computer where you have the pictures on.
Give it a moment for the computer to recognize and load the drivers for it, once it's done you go to "My Computer" then find the Garmin Unit there and double click on it.
Find a folder called JPEG and double click on it, you will find all the default pictures Garmin loaded on there at the factory. Drag and drop the pictures you want on your Nuvi and that's it! No need for external memory, unless you want to load several and don't want to use up the internal memory.
Nov 29, 2008 | Garmin nuvi 200W GPS Receiver
How do i charge garmin nuvi 250 on my computer
HI,
I have the problem solved I at first had this problem after about 5 minutes of messing with my GARMIN NUVI and having many electronic gadget I thought about diffrent buttons to hit at the same time heres how you charge your NUVI with a computer and a usb cable
step 4: when you see GARMIN display on the screen you can letgo of the power button on the NUVI ****** if you unplugthe usb it will display message stating EXTERNAL POWER LOST SWITCHING TO BATTERY POWER***** while it is plugged to the computer the battery meter will disaper
Nov 09, 2008 | Garmin nuvi 250 GPS Receiver
GPS Logo
43 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
