Question about Xerox Phaser 8400 Laser Printer
Printing error Hi, I keep getting an error 09,007.42:3104, but can't find what that means. Can you help?
    President:
  • 2,072 Answers
That is an ink loading problem. No ink is getting to the print head.
Normally one of the ink sticks is stuck and not advancing forward. Check and see if one is sideways, cracked or otherwise stuck in the ink loader. That is most likely the problem.
far less likely is a bad ink loader.
Posted on Jun 23, 2008
What is code 1683
Hi
I believe code 1683 means 'ink out'. To keep using the printer, either replace the empty ink tank, or to keep printing, press & hold STOP button for 6 seconds or until the error clears. The printer will then work, but you'll still have to replace/refill the ink tank soon.
good luck
Sep 18, 2014 | Canon Pixma MX922
I kept getting service error 5200 when I tried printing something. How do I fix this problem?
Hi there
Service error code 5200 is the print head error. Rub the print head into a plain paper with rubbing alcohol until ink flows and then after that remove all the USB cable connection and power cord and plug it again. Then run the print head cleaning maintenance like print nozzle or print alignment.
It should be fine right now. Please let me know if you need more help
Mar 07, 2011 | Canon PIXMA MP240 All-In-One InkJet...
WILL NOT PRINT CODE E000002-0000
this means that there abnormal readings of temperature in fixing assy.
To get rid of the error you can do two things:
First:
Press * ( add. function key )
press 2
press 8
Press *
This will allow you to enter service mode.
Choose COPIER
Under FUNCTION tab, choose CLEAR and choose ERR
This will clear E002 error.
Turn off and on.
If it works, that means that because of i.e. blocked vent cover, or too much of a/c,... had influence on temperature readings in fix. assy.
If that doesnt help, you need to replace fixing film assy.
Hope that helped
Jun 04, 2010 | Canon (6981A002AA) for imagerunner 2200,...
My printer has stop printing on my brother mfc 5100c
Hi there
Error 41 means there is a major problem with the printhead, usually
requires a print head replacement.
My advice is to take it to a
Brother service centre while if it is under warranty.
If it's out of warranty they are usually a throw away job, the heads cost as much as the printer.
Sorry I know what it feels like, just have a go and see what you can do, clean the heads and so on.
All the Best and good luck: Pineworks
Apr 24, 2010 | Brother MFC 5100c InkJet Printer
Service error 5100
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 22, 2010 | Canon Pixma iP4500 InkJet Printer
Print error page Bizhub C351
Google the full error.
this sounds like a font realted postscript error.
Jan 05, 2010 | Konica Minolta bizhub C351 All-In-One...
I keep getting print errors.
hi,
I have ever get same problem with same printer model.
I have change the usb cable.
May be this can help
Dec 14, 2009 | Samsung ML 2010 Laser Printer
Error 6A00 - I'm not sure what this means. Before this error, the printer was printing only certain lines of text and skipping others - then this error came up and I'm stuck completely - help!
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Oct 21, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My printer wont print
the only solution I can give you is run to the nearest trash can and slam that **** in there. hope solution helps.
Oct 30, 2007 | Cannon Canon i960 Photo Printer
Xerox Phaser 8400 Laser Printer Logo
99 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
