Question about Garmin GPS
I have a Garmin NUVI 200 that is less than six months old. It suddenly has been unable to find satellites although all other functions seem to be working. I have tried the reset button, but that doesn't help.
  • djmckittrick Jun 23, 2008
    There are not external antenna cables on my NUVI, so your solution is irrelevant.
    Master:
  • 638 Answers
Do a reset that will erase all your data and should reset the GPS settings too.
Turn the unit off. Now, while holding you thumb on the bottom right corner of the screen, turn it back on, keeping your thumb on the screen. After a few seconds you'll be asked if its ok to erase data, say yes. You'll now have to put your language preferences back in.
Now go outside and keep the unit still and let it get a lock. Make sure you're away from buildings and trees for this initial set-up. It could take about 5 minutes. Once it knows where it is, give it a test in the car.
Tell me how you get on.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
Posted on Jun 23, 2008
    Master:
  • 848 Answers
Try this to reset to factory settings
1- Turn off unit. 2- press and hold the bottom right corner of the screen. 3-While still pressing and holding bottom right corner, press and hold power button and continue holding both until a white screen appears with a black dot. 4- follow the on screen directions and your unit will be back to the day you first got it.
  • gopinath pasupathy Jun 23, 2008
    this may be the problem for not receiving proper signal
    Some modern cars are fitted with a special windscreen that cuts down the amount of UV (Ultra Violet) rays that will be transferred through the windscreen which help cut down on glare. These windscreens are called Athermic, or UV Coated and will dampen/reduce GPS signals coming through the windscreen, so if you have an Athermic windscreen, it means you will not receive the same quality of signal as you would do by taking the GPS device outside of the car
    Genius:
  • 1,036 Answers
Check the cabling to any external aerials.
  • Richard Perkins
    Richard Perkins Jun 23, 2008
    Some nuvi units require that an antenna be lifted before they will acquire satellites.
  • Richard Perkins
    If there is a serious defect, it can still be returned free to Garmin for repair or exchange.
    It will still be under warranty - Click for a link to the information.
How to update map on garmin nuvi 205
if it is less than six months old you get it for free from garmin, if older you have to buy it, one time is $69 life time $119
Jun 30, 2010 | Garmin nuvi 205W GPS Receiver
Hellio, my garmin nuvi 200 cant find a satellite,
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Mar 24, 2010 | Garmin nuvi 200W GPS Receiver
I have a nuvi 200, less than 2 yrs old. Has probkems acquiring satelite. Has GPS sw 2.50b and audio 2.20. Also, where and how much is usb adaptor that fits to left side of unit (special plug in to unit
Acquisition of satellites has been addressed in new firmware / system software updates for the Garmin Nuvi 200W.
The usb cable you require is a standard USB to mini-USB cable. MP3 or camera cables will work.
I hope that helps.
___________________
Oct 14, 2009 | Garmin nuvi 255W GPS Receiver
Garin nuvi 200 cannot aqcuire sattelite
Acquisition of satellite speed has been addressed in new firmware / system software updates for the Garmin Nuvi 200W .
I hope that helps.
___________________
Oct 08, 2009 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi Unable to calculate route No roads near starting poin
Its a problem you need to address with Garmin on this model before warranty runs out
Please rate our help to keep the FREE service onlinew++++Thank you for using FIXYA
Sep 11, 2009 | Garmin nuvi 350 GPS Receiver
Id the Garmin Nuvi 200 supposed to function when plugged in?
Are you using the factory supplied Power cord or a standard Sony-type plug?
Mar 01, 2009 | Garmin nuvi 200 Car GPS Receiver
Garmin nuvi 200 appears dead
hit the reset button on the bottom
Nov 29, 2008 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 660 GPS Can't find Satellites
Try this and see if it fixes your problem...first disable bluetooth then follow these steps....
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from the problem.
Jul 05, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi Firmaware Update Complete, Unable to catch satellite signal
my garmin nuvi200 keeps on searches for satellite,but it couldnt able to pick up signal. A question mark over a map is always im seeing througout
Apr 06, 2008 | Garmin nuvi 350 GPS Receiver
GPS Logo
44 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
