Question about Minolta bizhub 200 All-In-One Printer
Changing Mode? My bizhub 200 seems to be stuck in copier mode, so that when I turn it on & off it says "ready to copy" and when I try to print from my computer I get an error. How do I get it back into print mode??
    President:
  • Minolta Expert
  • 347 Answers
There is no way to change your machine into printer mode only. machine works in dual mode copier/printer.whenever you send a print from the computer, machine automatically receive the document and print it at the same time without changing the mode.like SCAN MODE AND HARD DISK MODE. So if you are facing a problem regarding printing then please check the paper size of the machine, and also check the paper size from the "PRINTING PREFERENCES" by taking the properties of printer icon in printer and faxes menu.(where installed printers shows) right click on the bizhub 200 printer icon and clickj on "properties". now click on "printing preferences" tab and then click on "size" tab, now from here check the paper size.its A4 or not if its not A4 then please change it to A4 then again give a print command.machine will start printing.
Posted on Jul 06, 2010
Scan bizhub 751
have a tech come out service mode and clear memory
Apr 16, 2014 | Konica Minolta Office Equipment & Supplies
Need to replace the drum on a minolta bizhub 350 copier
First get into service mode. Utility/Counter then meter count then check details. Then Stop 00 stop 01. Counters. Clear Drum and Developer. Then touch end do not exit all the way out of service mode. Turn off the machine using the main on/off rear of machine left hand side. Then remove the image cart. and replace the drum and developer. then turn machine on reenter service mode. Run F-8 found under Function. Do not print copy or allow fax to print before this is done. Or you will have to replace the developer again. So remove network cable and fax line if machine is as printer and FAX. after powering off
Jan 15, 2014 | Minolta bizhub 350 Black and White Copier
Flaherty@nbhealth.org I am trying to print on 110 lb cardstock and It keeps geeting stuck. I can't seem to find where I should change the paper type. Please advise.
Use the hand feed tray on the right side. When you put paper in this tray it usually will ask you to set the paper type. 110 lb. card stock is EXTREMELY difficult to copy onto. It might be better to bring this particular job to a copy center. This type of stock will put serious wear on your machines drum. Drums cost big money. Good luck.
Jul 15, 2011 | Minolta bizhub 200 Copier
My bizhub c250 is printing smudged copies. It seems to have print a lite image from a previous copy. Im left with a streak along the top of what Im trying to print out. Any suggestions? The smudge is...
Hi Mike13660,
Usually the fault you are describing is caused by the fuser section being left in envelope mode.
Open the right hand side door, then lift the grey fuser cover up. Look at the levers on the fuser unit, make sure they aren't pointing at the envelope symbol. If they are, push them upwards. then close everything and try again.
Regards
M-PRESS.BIZ
Feb 09, 2011 | Konica Minolta bizhub C250 All-In-One...
Black line appears in copying from Konica Bizhub 200
If the black line appears ONLY when copying and NOT when printing then you need to clean the adf strip glass. This is the thin strip of glass that is just to the left of the large original glass. Clean this glass very well with a soft cloth and glass cleaner. The line is caused by a small particle stuck to this strip of glass.
Good Luck and Thank You for using Fixya.
Jul 06, 2010 | Minolta Di3510f Bizhub Copier
Konica minolta bizhub 200 c2557. Help please!
c-2557= ATDC Sensor abnormality to reset go to service mode, to enter service mode perform these steps, 1-press utility/counter button from the panel, 2-press check details, and press "STOP" 0,0, STOP 0,1 3-now you are in service mode, 4-click on tech rep mode,or Adjustment 5-now click on "Printer" 6-here increase the value, suppose you have 150, make it 170, press the clear button to clear it and enter new value which should be more than the previous one. press enter and exit from the service mode.
Jan 14, 2010 | Konica Minolta Bizhub-200 Minolta Printer
The printer has stopped functioning all together.
C3851: Abnormal Low Temp. (Heater)
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Mar 31, 2009 | Konica Minolta bizhub C250 All-In-One...
Printer stuck in copy mode--can I reset the printer? Have tried everything.
Hi
Try to turn it off and unplug it for a few minutes, turn it back on and leave it to copy mode. try printing from the computer then/ keep us posted.
Thanks
Nov 01, 2008 | Epson CX8400 All-In-One InkJet Printer
X6150 Copy problems
Had exactly the same problem. Solved by turning copier on, then unplugging it for 30 seconds..plug back in...Problem solved.
Mar 21, 2008 | Lexmark X6150 All-In-One InkJet Printer
Minolta bizhub 200 All-In-One Printer Logo
404 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
