Question about Gateway FPD2275W LCD Monitor
My pc monitor not working after i setup my bios after clicking save and exit what would i do?
After that monitor not working
the light on stand by.
but the cpu still working
    Champion:
  • 214 Answers
Hi, let me know what u changed in the BIOS
thank you
Posted on Jun 23, 2008
After clicking f2 and entering setup, what is the process of disabling the CMOS. After doing that, how do you save and exit and return to the operating system?
Were you locked out of windows? Clearing the CMOS will not fix that, it will only set your motherboard to standard factory settings. It is possible that in clearing the CMOS you have lost settings that are required to have the system start and until you reset those you may not be able to exit the bios.
Aug 12, 2015 | Dell Dimension C521 PC Desktop
My ASUS Z99E laptop cannot access winXP
Try to access the BIOS "F2" Key, Go to the BOOT Section, set the 1st Boot device to DVD / CD Rom. Press "F10" Save and Exit. If it fails again, re-enter the BIOS. Then make sure the drive is set to IDE and not ACHI. press "F10" save and exit the BIOS. If that fails then select in the BIOS Load Setup Defaults, and re-select the boot device to DVD/ CD Rom.
If all fails, you have to open the side or bottom cover to remove the HDD - Hard Disk Drive, Connect it to a Stand alone pc via the SATA Cable or External Device (Works as USB) then you can either do an emergencey back-up, Format the drive through windows.
Hope it helps
Mar 23, 2014 | ASUS Z99E COMPATIBLE LAPTOP LCD SCREEN 141...
My computer screen went completely white. I have a Dell flatscreen monitor
This issue occurs due to various reasons. However, in this case it might be due to corrupt BIOS settings. To resolve this issue I recommend you to visit the following website to download and install the BIOS Update:
===Installation Instructions ===
1. Download the BIOS update. (from Dell website)
2. Double-click the BIOS update icon, and then click NEXT.
3. Accept the license terms, and then click NEXT.
4. If an Overwrite Protection message appears, click YES TO ALL.
5. Click OK at the Windows Based BIOS Update window.
6. Click YES at the next Windows Based BIOS Update window, and then wait for the update to complete.
7. At the Windows Based BIOS Update window, click YES to restart your PC.
8. If you see the following message during the restart of your PC, continue with the remaining steps; otherwise you are done with the update.
Default BIOS settings have been loaded due to BIOS update or checksum issue.
Press to enter Setup. Otherwise, allow the PC to continue.
9. Press and hold F1 for a few seconds to open the BIOS Setup.
10. Press F5 for a few seconds, choose YES, and then press Enter to load the BIOS defaults. (Use the arrow keys to choose YES, if necessary.)
11. Press F10 for a few seconds, choose YES, and then press Enter to exit the BIOS Setup and save your changes. (Use the arrow keys to choose YES, if necessary.)
12. Press Enter to confirm the save.
13. If you see a System Settings Change message prompting you to restart your PC, click YES to restart the PC again.
Also use a sytem utility software RegInOut -- a System Utilities program that includes several features which allows the PC users to speedup their computer performance. It improves system performance by removing junk files and fixing registry errors. Its additional feature of
Internet Optimizer enhance users web browsing experience.
Dec 19, 2011 | Dell Computers & Internet
Hi, I hope you can help as Acer can't!! I have an Acer Veriton M221 about 15 months old and recently on boot up I get error message Case Opened press F1 to continue or Del to enter Bios. I have not...
Have you tried this:
1) Reboot your computer and Enter Setup.
2) Click on the tab labeled PC Health Status.
3) Find the feature labeled Chassis Intrusion Detect, and change the status to RESET
4) Press the Esc key to access the main menu and then use the arrow keys to choose Save & Exit from the menu.
Do NOT use the F10 key. If you use F10 key to Save & Exit, it does not properly reset this feature!!!!
If you wish to set the Chassis Intrusion Detect feature so it never generates a warning message at boot, follow these instructions
A) Reboot your computer a 2nd time and Enter Setup.
B) Click on the tab labeled PC Health Status again..
C) Find the feature labeled Chassis Intrusion Detect, and this time change the status to DISABLED
D) Press the Esc key to access the main menu and then use the arrow keys to choose Save & Exit from the menu.
Jan 29, 2011 | Acer Aspire 2100 (91.AB675.D02) PC Desktop
Installed new bios for windows 7, not working,on start up, computer locks up, able to unlock- but didn't happen with original bios. Looking for old bios to re install sholder012001@yahoo.com
o open the BIOS Setup screen: Reloading the BIOS default settings To reload the factory BIOS settings to the setup default:
  1. Press the F5 function key.
  2. Select Yes or OK.
  3. Press the Enter key.
  4. Press the F10 function key.
  5. Select Yes or OK to save the defaults.
You can also complete the following steps to reload the factory BIOS settings using the menu:
  1. In the BIOS Setup utility, select the Exit tab.
  2. Select Load Setup Defaults.
  3. The system prompts you to load the optimized setup defaults. Select Yes or OK and press the Enter key.
  4. Select Exit Saving Changes.
  5. Press Esc and then press Enter to exit Setup.
Please don't forget to rate this if it fixed your problem. Four thumbs up is basically what means your problem was solved. Anything less means your problem was not solved. Not sure people here understand that as far as how we get rated.
Jan 15, 2011 | HP DT PAVILION ELITE E9120f DESKTOP PC
Reset the BIOS on a Compaq server 740 jumpers settings
Don,t do that insatead:
Entering the BIOS Setup menu Entering the BIOS Setup menu requires pressing a specific key at a specific time. If you fail to enter the Setup menu on your first try, repeat the following steps until you are successful:
  1. Close all applications that are currently running and restart the computer by clicking Start , Shut Down , Restart the Computer , and then OK .
  2. When the red Compaq logo or blue HP logo screen appears, press the F10 key on the keyboard to enter the Setup menu.
NOTE: An alternate to the above steps, especially if the logo screen disappears too quickly to enter BIOS, is to shut down (turn off) the computer. Wait 30 seconds, turn the power on and press F10 or F1 at the logo screen. Reloading the default settings Complete the following steps to reload the factory installed BIOS Setup settings:
  2. Select Load Setup Defaults .
  3. Select Save Changes and Exit (pressing F5 and the Enter key will also load the Setup Defaults).
  4. Press Esc and then Enter to exit Setup.
Nov 13, 2010 | Computers & Internet
When I Boot up it Dosent display the screen Any
What you've plug ?
if what you mean is a socket monitor to VGA port,
i think you have a problem with your monitor.
try to use another monitor if U have one.
boot up doesn't display ?
go into BIOS setup,look for "load BIOS SetUp Default or Load For Best Performance".
Choose it,Save and Exit.
Sep 25, 2009 | Dell Dimension 2350 PC Desktop
Problem:Monitor problem and Dvd drive problem
open your cpu and clean all dust from it.reattch all power connection and harddisk connection .also clean dust form RAM and refix it.
ten enter i bios setup.
then load optimal defaults settings.ten save and exit.
Feb 02, 2009 | HP Compaq Presario SR5612F-B Desktop PC &...
Motherboard graphics card not working, trying to install MicroStar G4MX420D nividia
Can you get into the BIOS setup? Usually, it will say "For Setup Press Fn" when you start booting up. When you get into the setup, look for a menu item that deals with "onboard video". Set it to disable. Then "Save and Exit" the BIOS. The new video board should allow you to view the screen, at a reduced resolution, until you load the new software.
Oct 15, 2008 | Computers & Internet
Auto image adjust
This problem has existed for 4 or 5 years, and I've seen various solutions posted with inconsistent results. Did the problem begin
after a power failure or surge, by any chance? In my experience, this can be related to a setting in the BIOS (Basic Input/Output System) of your motherboard, which can sometimes be affected by power glitches. Try this:
Access the Setup menu of your BIOS. This can only be done during the first few seconds after starting or re-starting your PC. Usually there will be an instruction on the logo screen telling you what key(s) to press to get into Setup (usually F2, F12, or a key-combination, depending on the manufacturer). This screen goes by pretty quickly, so you have to be fast. Once you're in the BIOS setup menu, use the arrow keys to navigate to a category called "Video" or "Display" or "Graphics", etc. (again, depending on the brand). Press "Enter" to view the screen adjustsments for that category. If the graphics controller is set to "Auto", change it to "Onboard/PEG" or some similar term. (If you don't have an alternate graphics controller, you're out of luck.) Follow on-screen instructions for changing and saving settings. When you exit the BIOS, be sure to select "Exit and Save", not simply "Exit." See if that works.
Jun 26, 2008 | Computers & Internet
Gateway FPD2275W LCD Monitor Logo
27 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
