Question about Fisher Dishwashers
Loud Dry Bearing sound - Fisher Dishwashers
  • 525 Answers
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
If your dryer is noisy, check these:
Idler pulley
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 23, 2008
What makes my mountaineer make a really loud noise after i drive it a couple miles and it warms up
Liz; worn,dry, faulty wheel bearing noise usually get worse as you drive.
link below may help diagnose noise, press the helpful button
Symptoms of Worn Wheel Hub Bearing KnowYourParts
Jan 22, 2016 | 2006 Mercury Mountaineer
GE Top Load Washer Loud Squealing Noise
Would check belt for tightness and it is also possible you have a dry bearing in pulley, motor etc.
Nov 21, 2017 | GE Profile WPRE6100G Top Load Washer
Noise in clutch when in neautral
What you're hearing is a "dry" throw out bearing. They're internally lubricated from factory and after a while they will dry out (especially if you off road and submerge occasionally) Even with normal driving they will dry out. Unfortunately, you can lube them. If it's really loud, just replace the bearing.
Mar 14, 2011 | 1999 Jeep Wrangler
Loud noise on spin cycle only clothes dry good
Sounds like your bearings and seal need replaced... See Neptune Bearing for information on the Maytag Neptune bearing and 12002022 seal kit. You can also rent a special tool kit that includes the bearings, 12002022 seal kit, bearing spacer, step by step DVD, etc.
I would not run neptune with bad bearings too prevent more damage to the Neptune spinner support, Motor drive system...
I hope this helps you...
Feb 01, 2011 | Maytag Neptune MLE2000A Front Load Stacked...
Extremely loud noise when spinning. Sounds like dry bearing
If you have loud noises on spin it is quite possibly bearings.
You may also find that the inner drum becomes loose and may contact and wear the outer drum..
Replacing the bearings and possibly the shaft going through them is quite a big job. Best left to an experienced tech..
Get quotes before getting the job done. Check new prices also...
Good luck....Nomess
Aug 03, 2010 | Washing Machines
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Mar 04, 2010 | Whirlpool LER5636P Electric Dryer
Beko DRCS68 condensor dryer is making loud vibration noises
hi there......when you replaced the drive belt you most likley disturbed the drum on its bearing seats (small plastic curved units) or indeed knocked 1 out altogeathrer...this would account for the loud bearing or metallic may also be the rear bearing these tend to eventually rund dry and fail..
regards Sir GalAHAD
Apr 17, 2009 | Frigidaire GLER331A Electric Dryer
Very loud when spinning.....
the rear bearing is bad. its a sealed bearing and cant be regreased. it has to be replaced. very difficult job
Nov 26, 2007 | Frigidaire GLTR1670A Front Load Washer
Dishwashers Logo
150 people viewed this question
Top Fisher Dishwashers Experts
Tony Houde
Tony Houde
George Merkley
George Merkley
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Fisher Dishwasher Expert? Answer questions, earn points and help others
