Question about Electrolux ERN2820 Bottom Freezer Refrigerator
Fridge freezer I have an electrolux ERN2820 Frost Free fridge freezer. The fridge part is not cooling - everything else i.e. freezer seems ok. What can be wrong? Thank you.
  • 5 more comments
  • bosslady1 Jun 23, 2008
    No, I dont think I have ever noticed sound of fan - everything sounds normal though - the usual noises it has always made - I suppose the fridge does sound quieter than normal!
  • jojuwilk Jul 06, 2008
    Hi, I have an electrolux frost free fridge freezer also and the freezer is working fine but the fridge is not cooling. We noticed quite a loud clicking noise coming from it a few days ago. I have switched it off to allow for any ice build up around the fan to defrost. Do you think that this may fix it? The appliance is only 4 years old.
    Regards
    Jo
  • frozone Oct 21, 2008
    Same problem again. Started with freezer door not shutting for a few weeks due to frost build up on supposedly "frost free" product. Kept taking out all the drawers and cleaning out all the ice built up. Now, fridge is not cooling at all but freezer seems ok. Going to empty freezer drawers again and try to remove the back panel to assess whether fan is covered in frost. I'm hoping this does the trick.
    Is removing the back panel easy enough? or do I require any tools? I cant find my instruction manual anywhere. thanks folks
  • douglas smith May 11, 2010
    can you hear fan inside freezer?
  • Anonymous Mar 16, 2014
    control panel stuck in off postion in blue
  • Anonymous Mar 20, 2014
    not working it the fridge has now gone to +12
  • Ajith Paliath
    Ajith Paliath May 18, 2014
    thanks... i removed the panel. there was ice buildup on pipes. switched off to defrost.it worked...
There is a fan inside freezer behind back panel. if pipework behind panel is covered with ice, it will prevent air circulation and the fridge is affected first
take back panel off and check for ice build-up and that the fan is working
Posted on Jun 23, 2008
  • Ajith Paliath
    it worked. the pipe was buildup with ice. switched off to defrosted. thanks for the advice.
My electrolux ERN2820 is not working the light is on the moter is running but the freezer is defrosting and the fridge has lost it temp
Have you cleaned out the coils lately? Sometimes they become full with dust and will not cool properly. If the coils are clean, check that the fan is running. If the fan is running, maybe the compressor isn't. If the compressor is running and all else looks good it is probably low on freon.
Feb 03, 2012 | Electrolux ERN2820 Bottom Freezer...
Electrolux frost free fridge freezer. Warm fridge and ice in the frost free freezer?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 22, 2010 | Heating & Cooling
We have a lg gr-s592gt and we noticed the frezer is working fine but the fridge wasnt cold. i noticed that the two fans that controller the temp in the fridge arnt working but everything seems fine , this...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Ice build up and stops the fans...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Sep 11, 2010 | Refrigerators
Lower door not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
gdkjgk
May 23, 2010 | Electrolux ERN2820 Bottom Freezer...
Hi, i have a fridge freezer and both dont seem to
Its a broken Thermostat. Its behind the temerature control dial. Pop up the dial, remove the plastic cover and you can see it. Remove the thermostat and bring to your local electronic shop and ask for a replacement, the same as you have if they have. Put it back together. make sure you remember where all the wires/plug goes. hope this helps
Nov 19, 2009 | Electrolux ERN2820 Bottom Freezer...
I have an electrolux Aeg santo fridge freezer. Frost free. There seems to be water leaking from the bottom.
remove back plate inside freezer. there is a drain tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely. check drain tray heater is ok as well
Oct 08, 2008 | Electrolux Refrigerators
Electrolux ERN2820 Bottom Freezer Refrigerator Logo
2,167 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
