Question about Sony DSC-T7 Digital Camera
Dsc-t7 when i open or close the front slider or turn on manuely the camera says lens cover closed. i opened up the camera and found a little metal part . I started to miss with it and now the camea wont even turn on. Any solutions? out of warranty! 2 years old
  • McMax Sep 02, 2008
    I move  front lens cover up and down and does not turn camera on. However, when I power camera with ON button, it turns on but says LENS COVER CLOSED even though I open the lens cover. HELP! What can I do to fix it without opening up the camera? Can I take off the metal cover from the lens only? If so, do what once I open metal lens cover? HELP!
  • 3 Answers
Hey guys. I came looking for a solution to my problem as my camera was doing the same thing after being dropped. Unfortunately, I could not find a service guide with any pictures of the inside components, so I had no idea what the insides should look like. I decided to tinker with it since it was doing me no good without photo capability. If I didn't fix it, I was going to have to replace it anyways, so really nothing to lose for me.
This is what I did and maybe it will help you as well. Grab some slim tipped tweezers and a good desk lamp. I took out the screws from the case(you might try an eyeglass repair kit screwdriver or check Dollar Tree--I found and excellent little set of teeny screwdrivers that worked perfectly on these ***** screws. Be warned--mine were in there tighly and I had to put the screwdriver in pliers to put enough pressure to loosen them up. Just be careful you don't strip them.). Ok, once you remove those and set aside someplace safe, remove the battery. Now, very carefully work the front cover (lenscover side) off the body. Work over a table and be very gentle in case you have any loose parts inside. You will NOT want to lose any if possible! In the middle of the circuit board there is a tiny box that may or may not have a little black plastic *switch* inside. When I opened my camera I found: a tiny black switch, a tiny coil of copper wire (spring) and a silver metal bracket looking thing all rolling around. If you have these, then you need to put them back in place in the small box looking thing (it will line up with the back of the lenscover where you see a copper tab). To do that, you need to get the switch and coil together. I found you can do it two ways--one may be easier for you than the other. You can
A: Grab the copper coil by one of the ends sticking out with the tweezers and setting it into the underside of the switch. Use the lamp to examine the black plastic switch and you will notice on one side it has a little groove where the coiled side sits inside. As far as I could tell it doesn't matter which way you put the coil in or where the ends stick out. Then pick up the assembly with the tweezers (by the switch's little tab) and set it gently into the notches at the back of the box. If you examine the box under the light you will see (faintly) the notches where the little nubs sit. Once you get it in the box, the switch should easily be pushed in the down position (not all the way, though, or you will cause the spring to pop the whole thing out!).
B. You can grab the spring with tweezers and set it into the box at the back. Then grab the switch with the tweezers and position it over the spring and into the notches.
Either way, it DOES take some time so be patient. I was dropping the thing all over before I finally got them to work!
Now, with that back in the box, you need to attach the silver metal cover. Examine the cover and see if it is bent in the middle or if the little bent sides are flattened. You can use the tweezers to bend them back into a [ shape. This will fit over the switch and clip onto the box to hold it all in place. Now, once you get the metal bent as it should be, notice the **** opening and align that with the switch. The switch that springs up (not the end the spring is IN) needs to fit right inside that slot. Don't worry--it takes a bit to get it in there. Once it is lined up you will need to work the switch into it and push down. You may need two tweezers to hold both ends down so one doesn't spring up and out..or use a tiny flathead screwdriver to hold one end down. Keep working it until it clips back into place. Once it is fastened you will see only a tiny portion of the switch jutting through. You can test it by running a fingernail (or tweezers) over the switch to push it down and make sure it springs back up.
This part is needed because the lenscover, when opened, pushes the copper plate (found on the back of the lens case you removed) out which makes contact with the switch pushing it down, which in turn causes the camera to come on. All you need to do now is replace the front cover--carefully, lining it up and clicking back into place. Hold it together, add in the battery and try opening the lenscover to see if it works. Hopefully, it does! If not, something else may be wrong. If all is good, screw back in the screws and viola! I wish I could have taken pictures of the process as I know it would have helped me, but this is my only digital so I couldn't. If anyone needs help I can try to draw the parts if needed.
There is another option that might help if the above is not your problem. I found it while doing my search, but it was not what happened to my camera. I hope each of you find a solution. These things are pricey and I was near tears when mine wouldn't work. Best wishes!!
http://www.fixya.com/support/t154913-lens_cover_closed
Posted on Oct 03, 2008
I dont know what switch you're referring to...
Posted on Sep 21, 2008
  • 10,594 Answers
There is one solution, give a close look at camera board at front side, you will find a tiny/ micro switch there, this was being pressed by that little metal lost part, now cut a small piece of adhasiv tape and paste it over that switch to make it enable. Fix the front cover and push power button, camera will work.
2nd solution is you need "complete front cover" because little metal part is not available individually.
Posted on Jun 23, 2008
My camera turns on by itself even with the slide in front in the closed position. The screen then shows the warning that the lens cover is closed. When I open and reclose the lens cover in 10 or so...
Most likely some dirt, dust, or other particle is jamming the lens opening gears. You can try to spray some compressed air into the lens assembly, hopefully dislodging whatever is obstructing the lens cover. If this doesn't work, the camera will have to be serviced, which can be expensive. If the compressed air doesn't work, and you decide to have it fixed, get an estimate first. Often the cost of repair justifies going ahead and purchasing another camera.
Good luck, thanks for using FixYa, and hope this helps!
Aug 05, 2010 | Sony Cyber-shot DSC-T77 Digital Camera
Sony cybershot dsc - t7. the display says ''lens cover closed''
It appears that you have already tried what I'd have suggested as a last resort. Apart from cleaning the contacts and removing the battery for 15 minutes there is not much that can be done.
In my opinion it is better to purchase new camera than to spend so much on this one. Note that sony may also charge you a checking fee if you decide to send the camera in hope for less costly repair than they estimated.
And yes, it would be fruitless to dismantle the camera if you are not qualified for this stuff. There are no user serviceable parts inside and also there are timed mechanical switches which can be difficult to reassemble without a proper schematic.
PS. Please do not use Vodka for cleaning electronic components as it contains small amount of moisture. Use Isopropyl alcohol.
Nov 28, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Opening and closing 3 times and then saying turn off and then back on
So 2 weeks ago my Sony DSC-W80 stopped working. Our friends dog ran into the camera (in my girlfriends hand) full speed. It started opening and closing a few times, and then giving the "turn the camera off and back on" message. I read about tapping around the lens, etc. None of this worked.
I took off the camera body and carefully examined the interior of the camera. Turning in on and watching closely, I discovered the problem. Looking at the camera from the front, I saw a slider on the top right side of the lens that appeared to be jammed. I then saw a spring that was attached to the slider and free on the other end. Apparently when the dog rammed the camera, the other mount for the spring broke off (they are very fragile). The purpose of the slider is to adjust the viewfinder based on the zoom range of the lens. I simply removed the slider which had jammed when the spring came loose. Camera works flawlessly now. The only issue is that the viewfinder doesn't zoom, but who uses the viewfinder anymore anyway? Oh, and I have a screw leftover. What project isn't complete without having extra parts when you are done?
Hope this can help someone else!
Sep 29, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Front slider
Jun 22, 2008 | Sony DSC-T7 Digital Camera
How to Remove the Lens Cover on a Sony DSC-T7
It is only six screws, and you have to GENTLY wiggly the front cover off....Start at the bottom, and wiggle side to side to get it unattached at the top of the panel. I just got mine off. I'm having black screen problems....
Jul 17, 2007 | Sony DSC-T7 Digital Camera
Lens cover closed
I'm just shooting in the dark, but have you tried taking the batteries out then putting them back in again. Also, you might want to look through the Sony website for an e-mail address that you could wite a question and/or ask for help/advice.
Jun 18, 2007 | Sony Cyber-Shot DSC-T1 Digital Camera
SAND IN MY SONY DSC W50 CYBER-SHOT CAMERA
Hi there, this job is for a pro. Please do not try to open the lens. However there is a way and I will help you. Please contact me at live session. Arpi
Jun 11, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Will not charge battery
Please contact the nearest Authorized Sony Service. If you need more info please advice. Arpi
Feb 16, 2007 | Sony DSC-T7 Digital Camera
Lens Cover Closed
the switch inside that activates the camera is probably loose, or worse, broken.
Sep 09, 2006 | Sony DSC-T7 Digital Camera
Turn on the camera, cover lens is closed even though i already pull it down
if you open up your casing you will find that almost dead center on the front PCB, just to the right of the battery at the top of the empty battery area there is a box. possibly with some plastic fragment that is broken off. if you touch inside this box w/ something conductive it will think the lens is open. You can either fix this area or permanently solder it so it thinks it is always open. You can still turn it off using the button on the side of the camera
Sep 07, 2006 | Sony DSC-T7 Digital Camera
Sony DSC-T7 Digital Camera Logo
128 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
