Question about Ricoh Aficio 1018D All-In-One Laser Printer
Aficio 1018d my aficio 1018d says sc546 functional problem......help
  • florentmauri Jan 29, 2009
    The Copier shows a red light key with the 'on screen' inscription that reads: FUNCTIONAL PROBLEMS SC546.
    New Friend:
  • 63 Answers
Try this     you will have to enter service mode
clear modes(yellow button@ top)-1-0-7- and hold down the clear/stop button until the screen changes saying service mod, after that, while machine is still displaying service mode turn the machine off and then back on( don't use the MAIN POWER button on the operation panel just unplug the machine and plug it back in)  This should reset the code. The code may reappear if there is a problem with the machine but 90% of the time they start working Good luck
Posted on May 02, 2009
Sc 302
Posted on Jul 05, 2008
Turn main power switch off then on.If error reoccurs.call service.Functional problems. What does mean.
It means that something with the functionality of your device is not working properly. Take it for service.
Mar 07, 2016 | Ricoh Aficio 1018D Copier
How do I clear error sc546 on a Ricoh Aficio 2035
replace thermostat in heating section or u yuor tirmistor is directly touching the heat roller
Feb 13, 2012 | Ricoh Aficio 2022 Black and White Copier
Ho una fotocopiatrice Ricoh Aficio 1113, cpmare sul display SC546. Come posso risolverlo? Vi ringrazio in anticipo
SC546 - Unstable fusing temperature
Symptom: The fusing temperature does not rise
3 °C or more within 5 seconds after the
fusing lamp has been on over 8
seconds.
Possible Cause:
• Thermistor defective
• Power supply unit defective
May 27, 2011 | Ricoh Aficio 150 Copier
How do I clear error SC546 on a Ricoh Aficio 2045
SC546 A Fusing ready temperature unstable The fusing temperature is fluctuating. Thermistor connection loose Fusing unit connector loose you have to go into service mode and reset it
Apr 27, 2010 | Ricoh Aficio 450 Copier
I have ricoh aficio 1018d can it fax or print and i cannot find connection points on machine
Sir,
You can fax or print with the aficio 1018d provided that you have the fax and printer options. these connection points are located at the back of the machine.
Mar 06, 2010 | Ricoh Aficio 1018D Copier
Can MAC OSX 10.5.x use Ricoh Aficio 1018D? Do you now alternativ drivers for ricoh aficio 1018D. HP LaserJet 5-Gutenprint v5.1.3 is o.k. for A4 but not for A3
this is an older model copier, however try going to www.savin.com and click downloads then drivers. there will be a tab for drivers, this is 10.5 though not snow leopard. Ricoh/Savin/gestetner and Lanier are all the same copier, but savin site has more mac info than Ricoh site. Usually I have better luck using already installed Mac drivers than Gutenprint, if you type in the ip it should give you a list of preinstalled Mac drivers. I believe the Ricoh 1018 corresponds to a Savin 2518 if that helps. Also use print daemon, not ipp. hope this helps somewhat as Macs are difficult with options and such on most printers. also must use PS3 for best results.
Jan 09, 2010 | Ricoh Aficio 1018D Copier
Fax
go to www.ricoh.com, usa, downloads then operator manuals then fax manual it will download in a pdf file.
Oct 29, 2008 | Ricoh Aficio 1018D All-In-One Laser...
Aficio 1018d
Press the User Tools/Counter button.
Press System Settings.
Press Timer Settings.
Press the time button and make your changes.
Aug 22, 2008 | Ricoh Aficio 1018D Copier
Ricoh Aficio 1018 photocopier
MY PHOTOCOPIER IS ASKING FOR CODE SC194
Nov 30, 2007 | Ricoh Aficio 1018D All-In-One Laser...
Ricoh Aficio 1018D All-In-One Laser Printer Logo
511 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
