Question about Samsung SGH-E900 Cellular Phone
J600 i want to set alarm reminder for future appointments ,can set alarm but not alarm and date together.
Even i have the same prob
Posted on Nov 08, 2008
    Brigadier General:
  • 7,752 Answers
Sorry but it can not work on this model.
Posted on Aug 18, 2008
How do I set up reminders for appointment
Hiya
Go to your date icon where you can see the date then go to the date you want to put your reminder then follow the instructions there and it's done
Aug 11, 2014 | Samsung GALAXY S4
Turn off alarm for calendar?
As far is I can tell there is not a global setting for turning off the alarm on the calender. Whenever you create a "Schedule" event on your calender the default seems to be for a "Reminder" alarm to go off "On Time"; that is to say the alarm will go off at the exact of your scheduled event. However, when you first create a "schedule" event you can scroll down to "Reminder" and choose from "On Time", "10 Minutes before", "30 Minutes before", "1 Hour before" or you can choose the one you would want which is "No Alarm". You can also find options on that screen for controlling what kind of alarm you want including the choice of having a "Vibrate only" alert to you scheduled event. You can always go back and "Edit" any events that are already scheduled and deselect the alarm for those events.
If you don't want to mess with the different alarms and alarm settings you might consider creating from the "Create Event" menu either a "Task" or a "Note" for a particular date on the calender. There are no default alarms associated with either of those. Create "Note is very easy to use. Just select a date and you can enter the time and other appointment information in the "Note" area of the "Create Note" screen.
I hope this is a helpful solution for someone.
Jan 13, 2012 | Pantech Ease P2020 AT&T
Alarm clock
Try using Datebook, it isn't exactly an alarm but you can program reminders and apply them daily, work days, multimple days (allowing you to choose which days you want to be reminded), weekly, day per month, or even yearly.
Mar 25, 2009 | Motorola Mobility I335 Cellular Phone
Calender problem!
To add, change, or delete a Calendar appointment from the handheld, follow these steps: To add an appointment
  1. From the Home screen, press the Menu key.
  2. Scroll to and select Calendar.
    • NOTE: To select, press the trackball.
  3. Scroll to and select desired date and time.
    • NOTE: Selecting exact date and time will default to that date and time when the appointment opens, however these fields can be changed so any date and time can be selected.
  4. Enter a Subject.
  5. Enter a Location.
  6. If desired, select All Day Event.
  7. If desired, scroll to and set the Start and End date and time.
    • The 'Duration' should update accordingly.
  8. Scroll to and set Time Zone as desired.
  9. Scroll to Show Time As.
  10. Select one of the following as desired:
    • Free
    • Tentative
    • Busy
    • Out of Office
  11. Scroll to and set Reminder time as desired.
    • The options range from None to 1 Week.
  12. Scroll to and set Recurrence as desired:
    • None
    • Daily
    • Weekly
    • Monthly
    • Yearly
  13. If desired, select Mark as Private.
  14. If desired, select Notes, then type any notes.
  15. Press the Escape key.
  16. Select Save.
To change an appointment
  3. Select the appointment to be changed.
  4. Adjust any options as desired.
    • NOTE: The available appointment options are listed in the portion above.
  6. Select Save.
To delete an appointment
  3. Select the appointment to be deleted.
  4. Scroll to and select one of the following:
    • Open the series (for reoccurring appointments)
    • Open this occurrence
  5. Press the Menu key.
  6. Select Delete.
  7. Select Delete again to confirm.
I would recomend that you powercycle your phone regularly. If you have anymore questions feel free to ask me.
Apr 25, 2008 | RIM BlackBerry Pearl 8100
Samsung SCH-u740 Calendar Appointment Problem
This is what I got from Samsung when I sent them a summary of the calender failing to deactivate, even after the appointment was removed.
Mine has been quiet for an hour so far:
Thank you for your inquiry.
How Do I Reset My SCH-u740?
To reset the handset follow the steps below:
  1. While in standby mode, press the OK button for Menu
  2. Select Settings & Tools, using the navigation keys
  3. Select Phone Settings (6)
  4. Select Security (6)
  5. Enter the lock code, default password is the last 4 digits of cell phone number, unless it has been changed
  6. Select Reset Settings (3)
  7. Highlight Yes, using the navigation keys
  8. Press the OK button to confirm resetting the handset to factory default settings
Note: All settings (Except Contacts) are reset to factory default settings
Apr 23, 2008 | Samsung SCH-u740 Cellular Phone
How to set an alarm for a date in the future
When you set it,
did you tick the little box that says ALARM ??
Feb 06, 2008 | Samsung SGH-U600
O2 Xda Orbit Calendar Notification Problems
well, you mightwant to check under options if your enabled the ringing. and set it up. if you are not able to see anything regarding about alarms, might as well check your manual for further instructions on how to manually check and make an alarm. hope this helps.
Feb 05, 2008 | O2 Xda Orbit Smartphone
Alarm won't shut off
Have you tried turning the entire phone off then turning it back on again?
Jan 30, 2008 | Motorola Mobility RAZR V3
Reminders not working
The same happened to me. I discovered that it can be fixed by setting your clock to Visiting time zone and back to Home time zone.
Aug 09, 2006 | HP iPAQ H2210 Pocket PC
Blinking Green Ligh
Yes, this blinking green light is an appointment notification. So if you set up an appointment for September 30th, 2005 at 9:00 AM with a reminder set to 1 day....then on Sept 29th at 9:00AM, the IPAQ will turn itself on and a reminder screen will appear on your IPAQ. After a length of time (the default of which I can't remember now) the Ipaq will turn itself off, but will leave that green light flashing. When you then turn the IPAQ back on, the reminder screen will again appear and you can choose to dismiss the reminder or snooze it.
Sep 07, 2005 | HP iPAQ HX2415 Pocket PC
Samsung SGH-E900 Cellular Phone Logo
43 people viewed this question
Top Samsung Cell Phones Experts
Fotis Papastamatiou
Bill Long
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
