Question about Panasonic PV-GS2 Mini DV Digital Camcorder
No playback I used to have blue lines on the playback but cleaned the camera. The tape would begin with blue squares all over the picture but after about 15 or so seconds, they would go away and the picture was fine. Now, a tape won't playback at all. It will fast forward and rewind but I don't get anything but a blue screen when I press Play. I hear a whine coming from the camera but no sound like the tape is moving. Can you help
Even though my husband cleaned the head with a q-tip and alcohol, I decided to purchase a cleaning tape. I popped it in and it worked in less than 15 seconds! It was expensive, $18, but not nearly expensive as a new camera!
Posted on Jun 24, 2008
When playback of tape, fuzzy, not clear picture, or blue screen with sounds
try rewinding the tape and play it from the beginning.if still the same,video heads may be dirty and needs to be clean.i recommend you use a dry head cleaning tape.after which reinsert tape and play it again.if issue persists use a diff tape with previous recordings.if still no go,use new tape and try recording on it,play it back and check.if still the same your unit will require service.thanks:) hope this help.
Mar 12, 2010 | Sony Handycam CCD-TRV308 Camcorder
JVC mini Dv GR-D720E has small squares on playback
Indeed it seems that there was a really stubborn bit of dirt on the heads. I had to use the cleaning tape several times to ultimately have a clear picture on record and playback.
thanks again ,but successive cleaning can help for an effective cleaning of the tape path and heads.
Feb 04, 2010 | JVC GR-D73E Mini DV Digital Camcorder
I have a blue screen during playback mode on my Sony DCR-HC32. I am not able to see anything I recorded. What should I do?
Follow this procedure to troubleshoot if a blue screen is displayed when attempting to playback video from the camcorder.
  1. Stop the tape.
  2. Ensure the tape has been rewound to the beginning of the video recording.
  3. Play the tape.
  4. If the issue is not resolved, stop the tape and remove it from the camcorder.
  5. Clean the video heads of the camcorder using a dry head cleaning cassette.IMPORTANT: Follow the instructions for use provided with the head cleaning cassette. It may be necessary to use the head cleaning cassette more than once per session.
  6. Reinsert the tape into the camcorder.
  7. Play the tape.
  8. If the issue is not resolved, stop the tape and remove it from the camcorder.
  9. Insert a different tape with video footage into the camcorder.
  10. Ensure the tape has been rewound to the beginning of the video recording.
  11. Play the tape.
Aug 06, 2009 | Sony Handycam DCR-HC32 Mini DV Digital...
LCD shows stripes thus the picture is not complete
Mine was similar - with vertical black lines on playback. Visit, enter your make and model and ask for a head cleaner. They sent me one within 4 days and that was over the Christmas period. Reasonably priced too (£3.50 + p&p) and the whole head cleaner can be used up to twice once the tape has gone from beginning to end.
Jan 03, 2009 | JVC GR-D395 Mini DV Digital Camcorder
Lines across screen on playback.
A Q-tip should never be used to clean a video head.  Unfortunately they can pull the tiny head out of alignment.  I believe this is your problem and the repaid may be more costly than a new purchase.
Nov 25, 2008 | Panasonic Palmcorder PV-DV351 Mini DV...
Solid blue lines through Picture on playback mini DV PV-gs19
One possible cause is that normal recording
could not be performed because the heads were
dirty at the time of recording. Clean the heads,
and perform recording and playback again. If
normal playback can be performed, the heads are
clean. Before an important recording, be sure to
conduct a test recording to make sure that normal
recording can be performed.
≥If the heads become dirty soon after cleaning,
the problem may be the tape. If so, try another
≥During playback, the picture or sound may be
interrupted momentarily, but this is not a
malfunction of the Camcorder. (One possible
cause is that the playback is interrupted by dirt
or dust that momentarily adheres to the heads.)
Apr 21, 2008 | Panasonic PV-GS150 Mini DV Digital...
4-5 Grey Lines appearing in the Playback Mode when playing tape
I have the same problem happening and can't find a straight answer. Some posts are leading me to believe that it may be dirty heads, and that the camera needs cleaning.
Oct 30, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Lost LCD Screen
You MAY just have a dirty playback head. Purchase a head cleaning tape (Bestbuy, Target, etc., for about $20) and try cleaning your playback head. Colored lines is ONE symptom of a dirty head. A blue screen is ANOTHER. I had that symptom yesterday (9/7/07), got a cleaning tape and solved the problem. I can now again see on the LCD display what I recorded on the tape. Good luck.
Aug 21, 2007 | Samsung SC-D363 Mini DV Digital Camcorder
Playback not working
Hai, Clean Video Head with Head cleaning Cassatte & check the picture. udupi M/s.Prathiksha Electronics
Mar 18, 2007 | Canon MV450i Mini DV Digital Camcorder
Lines in tape playback
Someone here recommended taping with the lense cap on in a quiet room for 5-10 minutes. When I played it back, no more skipping or gray lines. This worked for me!!!!
Jul 02, 2006 | Canon ZR85 Mini DV Digital Camcorder
Panasonic PV-GS2 Mini DV Digital Camcorder Logo
200 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
