Re: I have a new laptop and did not have setup driver to...
You can download the drivers or Lexmark X5495 Printer and install them on your system. Click here to get the drivers. Select correct Operating System to proceed
make sure your printer is connected to your laptop and its driver or installer is also installed property, then after you make your word file press ctrl+ P then select the desire setting ..,then print
Try to do a test print using the printer utility installed on your computer and also check if the driver is properly installed on your computer and if not make sure that your printer is using the printer driver from your setup CD.
Important OS X pre-installation instructions: The Macintosh OS X driver found on the CD provided with your product is not intended for use with Intel-based Macintosh computers. If you have already installed the OS X printer driver provided on your product CD, please follow these important instructions before installing the "epson11769.dmg" file:
Open the OS X "Printer Setup Utility".
Select the "Printer Setup Utility" tab and click "Reset Printing System...".
Click the "Reset" button.
Restart your computer.
Install the downloaded "epson11769.dmg" file.
Installation instructions (some of the following steps may not be necessary):
Download the file.
Double-click the downloaded file to create a disk image on your desktop.
Open the disk image.
View the included "Readme First.pdf" document for important information.
Double-click the installer icon to begin the installation
First you need to connect the printer to your computer with the supplied printer cable including the power cable. You need to install the printer driver on you computer. You may need to setup the printer preferences, eg. paper size etc. You printer is now ready to print your documents. When you have opened an document such as a word document, to print this document click on file - print
Uninstall all your drivers (and delete the preferences) and download the Mac drivers from this link. The drivers that came with your printer were developed before Snow Leopard came out.
On the desktop machine - go to the printers folder, right click the
icon for the Laserjet and choose sharing (enable print sharing). You
should be able to name the printer and make it accessible to anyone
within the workgroup. If needed you can run the network setup wizard to change the workgroup names on both machines.
On the laptop go to add new printer and choose network printer, you
should be able to browse to the desktop machine by name and choose the
Laserjet as a printer (whether you want it to be the default is up to
you). The laptop will download and install the drivers from the desktop
pc to the laptop and set the correct network path automatically.
It goes without saying that the desktop machine must be on in order to print from the laptop in this scenario.
Hi, I have solved my problem posted 5/2/08. Download the gdi driver from Panasonic website as I did above.
Install printer via Control panel, "Add printer" and browse to locate driver. If you do it automatic through the USB it will not work. Mine WORKS now!! Do check that the paper size is A4 also.
All the best...
you have to install the mfl-pro suite given to you by cd.
After installation go to START/PROGRAMM/BROTHER/PC-FAX SETUP (Guess you run windows).
Or simply use the paperport software: drag your document and drop it to the faxsymbol.
If you dont have it, download (153mb) from brother homepage of your country.
Pleas notice: the faxprinter of xp wont work anymore after installation of the brother drivers (but you have the bro drivers then installed for fax :) )
