Question about Samsung SGH-D900 Cellular Phone
D900 rebooting when switched on
Just had ribbon replaced but now when I switch it on and push a button it just switches off..the technician tells me the battery is flat and thats why its doing that,but charged it fully last night..Help
  • mailgeegee Jun 25, 2008
    Fixed it be upgrading the software..
All I can suggest is buy a new battery from a trusted supplier like Samsung or your network provider. If you have the equipment, try checking the polarity on the battery, it could have blown out.
Posted on Jun 24, 2008
Hytec Kohler Model LM34520 air jet swtich not working. 4 years old and last use, the push button stopped working. Cannot see connection detail at switch/button end but disconnected at motor and and can...
The problem you are experiencing tells me that the air switch in the motor most likely the problem.
This is a latching air switch that operates when the button on the side of the tub is pushed.
The replacement TBS-339 air switch is around $21
Rod
US Parts Center
Jan 06, 2013 | Jacuzzi Home
WE HAVE TO PUSH OUR GREEN PRINT BUTTON WAY TO HARD TO GET IT TO WORK ON OUR PC 920
You will need to remove the front control panel assembly (2 screws and 1 ribbon cable) with copier opened like removing a paper misfeed (or replacing toner unit). Next, you will need to separate circuit board from control panel in order to gain access to the switch under the green print button. Sometimes, you can use electrical contact cleaner (tuner cleaner) to spray into the switch itself, pressing the switch numerous times to evaporate the solution from inside contacts of said switch. Now use a multimeter to check for continuity while depressing the switch and releasing. If cleaning the switch fails, either the switch will need to be replaced or the control circuit board will need to be replaced...replacing the switch isn't difficult, if you know how to solder. Reassembly is reverse of disassembly.
Nov 24, 2009 | Canon PC-920 Black and White Copier
The kitchenaid dishwasher (model KUDC25CHSS1) appears to have the 'child lock' engaged on the led display panel. The 'energy saver dry' light is flashing red and when I attempt to push 'cancel' it only...
On my unit, I had the same problem (child lock LED on, or flashing.The cancel process of pushing anything was not possible, as a bad/stuck switch prevented any input from the control panel buttons.
The underlying cause of the problem turned out to be a faulty switch associated with the "Light China" button. I determined this by removing the control panel from the door and using a digital multimeter with OHMS and DIODE settings, was able to check each individual push-button switch using the following table to check the 12 switches (applies to the KUDC25CHSS1 model).
There are 2 ribbon cables, it is the larger of the two cables you need to check. Pin 1 is noted on the ribbon. You can use 2 normal sized paper clips to insert into the ribbon cable and make your connections. (My Ohm meter has aligator clips on its leads which helps a lot...maybe another set of hands would help if you don't have these kind of leads).
-Using OHMS: the reading should be infinite (open circuit, so no reading/no connection inside the switch) when not pushing the button, otherwise you will receive a reading when you push the switch.
-Using DIODE/beep: Ensure polarity is followed in the table below. When connected, pushing the associated button will cause a beep to occur, otherwise there will be no beep and no reading.
+Positive Lead -Negative lead
Antibacterial Sw 13 3
Rinse Only Sw 13 2
Light China Sw 11 2
Normal Switch 13 4
Delay Switch 11 4
Energy Save Dry 13 5
Cancel 12 5
Start 11 5
Soak & Scrub 12 6
Super Scrub 11 6
Short Wash 12 4
Sani Rinse 11 3
All my switches checked out OK, except for the "Light China" switch. On the OHMS settings I was never able to measure an open circuit for that switch, which means the switch was always closed. or connected.
I noticed that "Light China" was pin 2 and "Rinse only" also used pin 2, which happen to be cycles I never use. With power turned off, I carefully removed some of the plastic surround of the matching connector on the Control Board right next to it's associated Pin 2 all the way to the bottom. Then I carefully bent over pin 2 as close to the connector base as possible. Making sure all the remaining pins were straight, I plugged on the control panel ribbon cables and all is well again.
Prior to trying this I was resolved that I needed to buy a new dishwasher because I wasn't going to pay over $350 for a new control panel. Instead, I eliminated 2 unused cycles at no cost, and maybe I can get some more use out of this dishwasher.
Jul 07, 2009 | KitchenAid Dishwashers
Ge Profile model jgb900 has error codes & oven doesn't work
Hi, this is a lock switch malfunction and you may need to replace this.Check the wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch.
Mar 06, 2009 | GE Profile JGB900 Gas Kitchen Range
Anytime I moved my laptop, the screen would switch off. I left it with PC repair shop. They said it worked fine for them. I took it home. Now I just have to touch the laptop (usually lefthand corner beside...
If thats the case then its probably the cable from your screen to the motherboard. This cable is called the screen ribbon cable. these cables are not meant to be pulled out and in more than 2 times and after that they become unpredictable. Ask the shop if they can replace it.
Dec 07, 2008 | IBM ThinkPad T41 Notebook
Replacing Start Button on Fax Machine
Open the doc feeder
Use a screwdriver to pry black base away from keyboard
Unplug keyboard large white connector.
Remove 17 gold screws
Carefully disconnect ribbon cable by pulling white part of ribbon plug away.
Unsolder one of the switches you never use (contrast?) 2 pins.
Unsolder start switch and replace
Reverse disassembly.
Oct 14, 2008 | Toshiba e-STUDIO 50F Plain Paper Laser Fax
Switch off
try *2767*3855# or have the phone's firmware reflash
Apr 08, 2008 | Samsung SGH-D900 Cellular Phone
Samsung d900i candy
what happen to the samsung d900?
is LED on the keypad lights up?? if yes, the problem might be on flex/ribbon that connect keypad to main board. just replace it.
Feb 16, 2008 | Samsung SGH-D900 Cellular Phone
Ps2 slim will not power up
usually, there is a problem with a ribbon cable of power/reset switch. Try using a replacement ribbon of the same type.
Nov 01, 2007 | Sony PlayStation 2 Slimline Console
Samsung SGH-D900 Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
