External hard disk driver
Please can you help me?
I am looking on the net for a free driver for my external hard disk, toshiba reference "mk1234gax driver",
Thank you
  • 1 more comment
  • joel123456 Jul 17, 2008
    i have the same problem.. its detected in Safely remove Hardware but the drives are not in My Computer..
  • Anonymous Aug 09, 2008
    same problem
  • Amalan100 Aug 14, 2008
    I have the same or similar problem. I bought a Toshiba hard disk in Sri lanka and it was put into a 3.5" case. I backed up files on it and now I can't access it. There is a friver CD - installed something called 'X Driver' and the computer can see the drive but wont open it.
    Does anyone have a generic toshiba driver that will opn it?
  • 3 Answers
Do you know from were i can get the ( X driver ) Program
cuz i got the same problem plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
Posted on Sep 02, 2008
I plugged in a 120gb internal toshiba mk1234gax hdd2d16 hard drive and when turn laptop on it says SMART failure predicted on hard disk. how should i go about fixing this
Try turning off SMART in MotherBoard Settings (BIOS Settings) and if it won't work, Call a Computer Professional. If Warranty is alive, Call Authorized Service Center.
Mar 29, 2014 | Toshiba MK1234GAX 120GB 5400 RPM 8MB Cache...
My Toshiba hard disk HDD2D16C not showing in computer and sounding clug clug... plz help me.
At this point the hard is dead. that sound is the head tring to read and not working. Data recovery is a long shot it this point as well.
Aug 29, 2011 | Toshiba 120GB (MK1234GAX) 5400rpm 8MB...
External hard dirve toshiba Mk1234gax i pluged in but not responding
the simplest thing is change the usb cable or check it some other system also
Jun 19, 2011 | Toshiba MK1234GAX 120 GB ATA-100 Hard...
I pluged my external hard dirve toshiba MK1234GAX but it is not showing in my pc
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
I have external toshiba harddisk MK1234GAX .when i connect to my laptop its not detecting only red and green light blinking..its not showing on my computer..i need all the files in tht hard disk..please...
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Apr 21, 2011 | Toshiba 120GB (MK1234GAX) 5400rpm 8MB...
Toshiba MK1234GAX 120GB hard disk creating problems
Hello, verified if your hard disk is properly installed in the closure, don't forget to format your hard drive in NTFS. if your problem persist maybe need to check your USB connections in device manager.
Jul 10, 2010 | Toshiba 120GB (MK1234GAX) 5400rpm 8MB...
Hard drive detection
You should not need a driver for it. Assuming you are using XP or Vista, the disk should be supported directly by the OS.
Have a look at external HDD troubleshooting.
Jules
Apr 22, 2009 | Toshiba 120GB USB 2.0 Portable External...
USB Hard Drive Problems
HI,
I have a TOSHIBA MK1234GAX USB Device.
My USB Controller finds it an I see it in my computer devices, but it do not gets a hard drive letter, so I can not access to my files on it.
Yesterdey it worked properly.
Can You explain me what happend and how can I get to my files?
Jun 13, 2008 | Toshiba 120GB (MK1234GAX) 5400rpm 8MB...
When I plug in the HDD16 into the USB my computer says devise is not recognised
Please clean the usb cable. Use a cotton swab with Alcohol on it. (Not dripping). You may need to use a few. If that fails to help, try another usb device in your PC & check if the PC can see that device. The cable could be defective. The FAT on the drive could have been damaged or the drives file system could be corrupt. The usb port could be loose from plugging in & out. If your OS is Vista that can be the problem. Try a Pc running XP.
Please check these links for more options.
http://support.microsoft.com/kb/871233 Try this as well.
http://www.hat.net/geeky/node/221
Post back & we'll go from there!
please vote after everything...
Feb 07, 2008 | Toshiba 120GB (MK1234GAX) 5400rpm 8MB...
Computers & Internet Logo
828 people viewed this question
David Payne
David Payne
