Question about Intel Motherboard
PROBLEM of color resolution on the screen
How to get the resolution of 16 bits of color on my screen.
I just have 4bits with my intel desktop boards BIOS VA84510A.86A.0030.P10.0402160229
    Sergeant:
  • 458 Answers
Right click on your desktop and go to properties and you will find the settings. If that does not work you need to update your driver.
Driver Install;
Look on the Company site under drivers and downloads. You will have to put in your model first and then the serial number sometimes. After you find your product you will find the drivers and more programs if they have any.
After you download the driver you might have to put it in a folder for it to be stored in. After you put it in a folder, unzip it in that folder and it should have an .exe file. Click on this and it should do the install. If it does not do your install you can go to the Device manager and click on the device and tell it to install or upgrade the driver. Then you will need to direct it to the folder where you have the unzipped file. This should correct your problem.
You can click on my name from now on and I will do my best to answer your question within a day.
Posted on Jun 23, 2008
Toshiba Satellite displays a 16-bit color resolution after I replaced the video cable, what is causing this?
Click Start/Control Panel and look for Display or Appearance and Personalization. Open the Display, then click the Settings Tab. You can change the color from 16 Bit and you can adjust the resolution.
You can also get to the display by clicking on a blank area on the desktop and select Properties.
Apr 29, 2012 | Computers & Internet
My monitor gives 16-bit color at 640x480, but will only offer 256 colors at 1024x768 -- and only displays 16 colors when I select that... In order to access resolution options, I have to go into Advanced...
The monitor has no influence here - something is wrong with your video card: either its driver is missing (or corrupted) or the video chip has failed.
Uninstall all the drivers for the video(except the generic VGA one), from Programs and Device Manager
http://pcsupport.about.com/od/windows7/f/open-device-manager-windows-7.htm
and reboot several times then go to Dell
http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs
select your pc and get the correct driver.
If that doesn't fixes it then the video chip has failed, you will need to buy a new video card.
Aug 02, 2011 | Dell Dimension 4600 PC Desktop
My system was formated, since the the screen resolution is 4bits and it can't be increased to 16 or 32 bits. Please what can I do to have a good screen resolution?
Hello
You need to locate and install the video card or video device drivers.Compaq website should have your make and model and operating system video drivers available for download.
Once downloaded,install them.This will allow you to adjust your res.
Jul 31, 2011 | Compaq Computers & Internet
At 1440x1200 resolution the monitor (719Sw) visualizes fine, but a window appears saying "input not supported". Does my cpu not support this monitor. Its a P4, 32.99 ghz 504 mb ram machine
Restart the computer
2 While the computer is loading, press "F8" key on the keyboard right before the
computer reads the hard drive or press the "F8" key multiple times in 1 second
interval until the "Windows Advanced Options Menu" appears on the screen
3 Under "Windows Advanced Options Menu", using the arrow key on the
keyboard, select "Enable VGA Mode" then press Enter. Select "Windows 2000
or Windows XP" for your operating system.
4 Wait while the computer is loading and once the computer finishes loading,
5 Right Click anywhere on the blank area on the desktop then click "Properties"
6 Click on "Settings"
7 Click on "Advanced"
8 Click on "Adapter"
9 Click on "List All Modes..."
10 We recommend that for 15" LCD's select 1024x768, True Color (32 Bit) 60
Hz or 1024x768, High Color (16 Bit), 60 Hertz; For 17" & 18" LCD's select
1280x1024, True Color (32 Bit), 60 hertz, or 1280x1024, High Color (16 Bit)
60 Hertz, or
640x480, 256 colors, 60Hertz or 75Hertz
640x480, High Color (16 bit), 60Hertz or 75Hertz
640x480, True Color (32 bit), 60Hertz or 75Hertz
800x600, 256 Colors, 60Hertz or 75Hertz
800x600, High Color (16 bit), 60Hertz or 75Hertz
800x600, True Color (32 bit), 60Hertz or 75Hertz
1024x768, 256 colors, 60Hertz
1024x768, High Color (16 bit), 60Hertz
1024x768, True Color (32 bit), 60Hertz
11 Additional Valid Modes for use only with 17" & 18" LCD Monitor
1280x1024, 256 colors, 60Hertz
1280x1024, High Color (16 bit), 60Hertz
1280x1024, True Color (32 bit), 60Hertz
May 17, 2011 | AOC 917Sw 19" LCD Monitor
The icons is very large
You Icon SIze is very Big because you are using Low screen resulution
to MAke it small * right click propertoes > click stiings Tab > incrase you screen resolution a bit ally and Ok and then see the changes ,, if you sitll Mind it big ,, again increase the screen resolution a bit
Mar 24, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
It only displays 4bits
If your computer monitor displays 4 bit color and a resolution of 640X480 and you cannot increase the color bit and the screen resolution then the display graphics card driver was not installed or the wrong graphics driver was installed.
Install or re-install the correct graphics card driver.
Nov 18, 2009 | MPC Computers ClientPro 414 All-In-One PC...
Screen sizing
Your problem is that the correct video driver is not installed and therefore cannot use all the video RAM.(the XP version of the video driver won't work with Win98).
When you adjust to True color at a higher resolution it drops to a lower resolution because it has insufficent video RAM, but you will get a higher screen resolution at a 16 bit color because it requires less memory (video RAM).
Install the Win98 driver for the graphics card and then it can use the full video RAM at a higher screen resolution with 32 bit color.
May 01, 2009 | Computers & Internet
Lost my 32-bit color resolution
if its a stock system with out upgrades can go to
HP select your OS then select graphics
Apr 10, 2009 | HP Compaq Presario SR2011WM PC Desktop
Default monitor
Sounds like you need to install your video card drivers, to get the resolution you need.
Jan 06, 2008 | Computers & Internet
Intel Motherboard Logo
76 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
