Question about RCA D61W20 61" Rear Projection Television
Tv repair big screen tv shut off by itself. when you try to turn it on you hear an faint click but nothing happens
  • dannyarmstro Aug 01, 2008
    light blinks 3 or 4 times
  • RCA Master
  • 8,617 Answers
Does the power indicator blink? If so let me know how many blinks it blinks. Respond to this post so I have a way of keeping your symptoms and model number available for furture responses.
Posted on Jun 23, 2008
Samsung LED 60' TV UN60J620DAFXZA not turning on? No red standby light? No backlights?
Did you try repairing the PS with a repair kit first then replace both the boards after that?
Nov 10, 2017 | Samsung Televison & Video
While I was watching my Emerson TV I heard a loud click and the screen went black and audio went off. When I press tv button on cable remote the tv button glows red, and nothing happens on the tv.
Hi the power supply might have shut down through overheating turn the power of at the wall socket & wait for a short time before trying again the TV might reset itself if this doesn't work its probably shut down from a faulty component. good luck
Oct 23, 2016 | Emerson Televison & Video
TURN TV ON JUST PLAIN SCREEN (NO IMAGE), THEN HEAR A CLICK & TV TURNS ITSELF OFF- THEN ON AGAIN... CHANGED BATTERIES IN REMOTE & TRIED TO TURN TV ON DIRECTLY FROM TOP... NOTHING WORK. THIS IS A...
Do you see the backlight ever coming to the screen?
You will want to open the cover, disconnect the backlight inverter and try again to see if it will stay on even without an image.
If it does it's the inverter.
if it still shuts it's most likely (not guaranteed) either the power board itself or the main board.
A good tech should be able to test the power board independantly fairly quickly.
Jun 30, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
I have a Sony Bravia KDL-40S4100. I turn it on and I can hear the solenoid click, the green light is on and I get a faint blue illumination. I do not get a picture or sound... or any response from the...
YOU HAVE A BAD INVERTER YOU NEED TO CHECK TO SEE IF THERE IS 30 VOLTS ACROSS THE INVERTER ALSO CHECK TO SEE THAT ALL THE FUSE ARE NOT BLOWN ANOTHER ISSUE WITH THESE TV IS THE LCD ITSELF BUT 9 OUT OF 10 ITS THE INVERTER OR THE POWER SUPPLY PLEASE CHECK THE FUSE ON THE INVERTER THATS USUALLY A BIG PROBLEM
Jan 26, 2011 | Sony BRAVIA KDL52XBR2 Television
Hi, my Panasonic PT47WX49E rear projection tv suddenly shut itself off. It won't turn back on at all unless I unplug it and plug it back in. However, when I do that, the power light comes on but nothing...
Either give me a yahoo or note if light on front of set blinks--count the blinks if it does.
most common is 3 blinks, pause 3 or 5 blinks etc.
Let me know if I can assist you.
SD TECH
Sep 14, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Turns on and off by itself
If this happens on all inputs and you have disconnected the power and reconnected it and that didnt fix it.
Sounds like a logic board issue problem is LG only warrenties tvs for 1 - 2 yrs.
Jun 16, 2010 | LG 42LC2D 42 in. LCD HDTV
The screen won't turn on. The tv just clicks and
The power board ic coverter it dead.
U need to replace the power board.
U can go the web and buy this board changes
or get the tv repair man replace part and labor $575.
Aug 13, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
SONY BRAVIA
If you are turning off your TV by basically unplugging it (turning off the AC power supply) then you will not hear the click of the solenoid which is activated normally by the Power button. The glow may well be the after effects of the screen being on for some period of time. Quite literally the "afterglow". This should be very faint and fade after some time.
Feb 24, 2009 | Sony BRAVIA KDL52XBR2 Television
HLN567w-won't start amongst other things
HEY HRABOSKY,ONE COMMON ISSUE AMONG THE OLDER SAMSUNG DLPS' ARE POOR/DEGRADING SOLDER JOINTS ON THE DIGITAL PC BD.(THAT'S THE BIG SHIELDED ONE FACING THE BACK).I'VE HAD GOOD LUCK RESOLDERING ALL PLUG INTERFACES AND SET WAS FINE. JOE TV
Oct 21, 2007 | Samsung HLN567W 56" Rear Projection HDTV
Dropped TV!!!
Worth fixing? Sorry, probably not. My experience with problems like this are such that the set will keep being repaired as new issues develop. The click and shutdown are a safety feature and are kicking in for a reason. Take what you'd spend on repairs and get a new TV. It will be cheaper in the long run. You might make some $ back by selling the set for parts. Who knows? Hope this helps.
Nov 19, 2006 | Sony KV-27S42 27" TV
RCA D61W20 61" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
