Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
No Sound I have a 52 inch RCA television I bought it around 2004 or 2005. It has worked great up until now. The picture is still great, colors is great but there is no sound. For about a couple week I noticed when I turned it off the speakers would make a snap sound as it was shutting off, well now I have no sound at all. Help!
    Scholar:
  • 137 Answers
Hello Amullins001,
You have one of two possibilites going on here. Lets do the hard one first.
(1) you may have a defective audio Amp IC. part # 264589
(2) The most popular cause of no audio on this unit is "the wife was cleaning the unit and hit the speaker int/ext switch on the back of the unit" This switch is a little hard to find. Its very close to the Video/Audio inputs. Its a sliding switch.
Please let me know
Best regards
ciecuitcity
Posted on Jun 27, 2008
My Rca 52 inch has lost color But If I set the feature
PIP means the set uses either two tuners or a dual tuner--could be a issue with the tuner. If it has a swap feature in the PIP use it to see if color when tuner is switched from main to PIP tuner.
A possible way around the issue is to look to see if rear audio/video inputs have color---you could route signal from a box etc to one of those and BYPASS the problem if rear inputs do not have this problem(not likely they will).
Jun 15, 2012 | RCA HD52W59 HDTV Projection Television
My 52
YOU NEED TO REPLACE THE CONVERGENCE OUTPUT I.C.
Dec 26, 2009 | RCA P52926 52" Rear Projection Television
My rca toshiba 50 inch projection tv is showing a 3d color curve
Need the model number to help as I am not sure of you have a RCA or a Toshiba
Dec 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA big screen picture messed up after one of my children fell nto screen?? How can I fix this
The picture on my 52 inch RCA Projection television has green, red and blue squiggly lines around the objects on the screen and the picture looks 3-D.
Oct 30, 2009 | RCA P52960 52" Rear Projection Television
1987 RCA TV
most like the amp on speakers wwent bad best u can do add seprate samsng sterio suround system or ect form dish cable box to sterio direct for tv sound or rca outs on tv if those sstill work
Oct 06, 2008 | RCA E13309 13-Inch Diagonal XL-100 Color...
No Picture
where can i buy Deflection board for RCA D52W20
Jul 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
52" RCA Rear Projection P52937SG Color Dots?
There could be an obstruction in the way of the three picture tubes on the inside. This tv has a chassis that comes out from the back all in a chip core frame with handles. Takes a quarter inch nut driver to remove and you should look to see if the speaker wires or the keyboard wires are obstructing the picture tubes. Other something I think of is a broken reflector and when you get the chassis out you can look up inside behind the screen to check for this and for any other obstructions.
Jan 05, 2008 | RCA P52937 52" Rear Projection Television
RCA P52830BL picture is bowed and colors separated.
There is a convergence printed circuit board that likely has a few bad components. If you decide to get it repaired, the technican will probably check for fluid leaks from the picture tubes coolant area which has given problems on this model also. If the picture quality leaves a bit to be desired, it may be a wise move to upgrade to HDTV. A Sony KDS-55A20 model has a great picture and should be less than $2300. I just saw one at a local Sams Club store.
Mar 12, 2007 | RCA P52830BL 52" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
