Sanyo  Projector Lamp for PLC-XU100, PLC-XU110 Logo
Posted on Nov 25, 2010
No power reset button on bottom? - Sanyo Projector Lamp for PLC-XU100, PLC-XU110
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 05, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
820
Points
There is a power reset for this device. It's a tiny hole on the bottom in between the lamp access door and the CAUTION label. If your projector gets a surge of power, instead of blowing a fuse, it just trips a little breaker inside the device and all you need to do is push a paper clip (unplug your device first BTW) into this hole and it will reset the breaker. Hope this helps.
How to factory reset from the settings menu
  1. Tap the Settings icon from your home screen or app drawer.
  2. Swipe up to scroll down to the bottom of the page.
  3. Tap the General management tab.
  4. Hit Reset.
  5. Hit Factory data reset.
  6. Scroll down to the bottom of the page.
  7. Hit the blue Reset button.
  8. Enter your device PIN and tap Next.
  9. Tap Delete all.
Your phone will reboot and you'll have to go through the setup process again before you're able to restore your data.
And also there is another method you can use:
__Factory reset via recovery mode__
  1. If your phone is on, power it off.
  2. Hold down the Power and Volume down buttons. Instead of booting up normally, you'll see "Start" in an arrow pointed at the power button. Here you use the Volume buttons to scroll and the Power button to select an option.
  3. Press the Volume down button until you've highlighted Recovery mode.
  4. Press the Power Button to start recovery mode.
  5. When your phone reloads, you should see a screen that says "No command" with an Android robot in distress. Press and hold the power and volume up buttons together to load the recovery mode.
  6. Using the Volume buttons to scroll through the menu, highlight Wipe data/factory reset.
  7. Press the Power button to select.
  8. Highlight and select Yes to confirm the reset.
  9. Once the reset is complete, you will be bounced back to the same recovery mode menu. Press the Power button to select Reboot system now.
Your phone will power on and be reset to its factory settings. Your phone will reboot and you'll have to go through the setup process again before you're able to restore your data
I lost my romote to my roku and it got reset. how do i set it up again without the remote
Hello
Reset Roku without Remote:
Soft Reset
From Menus (Newer Models - 4, Premier, & Ultra)
1. From the Home screen, select "Settings" > "System" > "Power" > "System restart".
Using Button (Older Models)
1. Find the "Reset" button on the back or bottom of the device. Some models will require a paper-clip to press the button.
2. Press the button, then release after about one second. The device should reset successfully.
Power Pull If none of the above soft reset options work for you, you may need to disconnect the power cord for about 20 seconds, then plugging it back in.
Hard Reset
A hard reset will clear all settings from the device and reset it to factory defaults.
Via Menu (Newer Models - 4, Premier, & Ultra) If a soft reset doesn't fix your problem, a hard reset may be your only option. This will clear all data off the Roku and reset it to factory default settings.
From the Home screen, select the following depending on your device:
1. "Settings" > "System" > "Advanced system settings" > "Factory reset".
2. "Settings" > "Factory reset" > "Factory reset" > "Yes".
1. Remove all cables except the Power cord.
2. Press and hold the "Reset" button on the back or bottom of the device for about 20 seconds. Some models will require a paper clip to press the button.
3. Continue to hold the "Reset" button, then remove the Power cord from the back of the unit.
4. Release the "Reset" button, then plug all of the cords back into the device.
The Roku should factory reset, then walk you through the setup process again.
For any help Visit us: www Support Roku Com
1helpful
How do I factory or hard reset my digiland model No. Dl8006 tablet
hard reset
hold down the power button and the volume down button at the same time till the chinese writing comes on
then go down with the volume down button to the 6 menu = 3rd from bottom press the power button to ok it
then it will reset
if its in english do the first bit hold down power button and volume down button at the same time till the android man with writing comes on
go down to wipe data withe the volume down button highlight that press the power button to ok it
then go down to yes with the volume down button highlight yes press power button to ok it then it will reset
then if it goes back to the writing go to reboot highlight that press power button to ok it
factory reset settings go down to back up and reset click on
go to reset
then it will reset
For Hisense Smart Tablet factory "reset bottom" does not reset. Frozen. Tried 20 times
try hard reset the tablet press the volume down button and power button when u see the Hisense logo release the keys will come up with the android man with a red triangle hold down power button and up button release the keys u will see some writing then go down with the volume down key to wipe data press power button to ok to select wipe data to wpe your tablet clean
Error code c4801 For C284e
You may have main board issues. Maybe Try error code reset.
Open front door and locate main power switch on the bottom left and turn off.
Press and hold the reset button , button on control panel.
Turn main power switch back on whilst pressing reset.
after 1 - 2 min a white screen with 1 button saying"error code reset will appear , let goo of reset button.
Press error code reset and then turn main power switch of for 20 seconds. turn main power switch.
If code returns contact me on my phone to discuss
1helpful
How do I do a hard reset?
Remember that when you hard-reset, all of your personalization and information will be deleted. Here are the steps:
  1. Press the POWER button
  2. KEEP holding the Power button down, use the stylus pin to gently press and release the Reset button (on the back in the middle of the device) - don't take your finger off the Power button
  3. When the "palm powered" screen is displayed, release the Power button after 3 seconds.
  4. You'll receive a warning message that you are about to delete everything
  5. Press the Scroll button (bottom and center of the device with the triangle symbol on it.
You have now officially hard reset the system and you will need to go through the initialization process again.
Device comes on but screen is blank...will not load menu
there is a small reset button on the bottom disconect the power hold in the rest button on the bottom of the unit and power it up this will reset it to the factory default
PASSWORD PROBLEM
To restore the router to factory default settings, please do the following:
1. Unplug the router's power supply
2. Press and hold the reset button on the bottom of the router
3. Keep the reset button depressed and, at the same time, plug the power supply back in
4. Keep the reset button depressed for another 10 seconds
5. Release the reset button
My Palm TX device is not initializing. it says "palm powered" then a loading bar starts at the bottom of the screen, then it turns off...and it repeats the same thing over and over again.
Have you tried a hard reset? In case you need to know how...Hold Power button on Top of Palm down, then press reset button, then release reset button and continue to hold power button down until second Palm logo comes on screen and progress bar at the bottom of screen completes. If you release the power button and it asks which language you want to use you have done this correctly.
18helpful
3answers
Garmin Nuvi stopped working and won't restart
Got a Garmin Nuvi 260. Same problem. I read the booklet. There's a reset button on the bottom. Disconnect from power. Push the reset button. Connect back to power. Now it works. The reset button is tiny and looks more like just text on the bottom sticker than it does a button. But push it anyway.
Top Sanyo Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Rob Hill
Rob Hill
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
