Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony Trinitron PVM-20N6U Picture out of focus
I recently had a flood in my basement and my Sony monitor sat in a couple inches of water for a couple hours. After letting it dry out for about 2 weeks I powered it up and discovered the picture is out of focus. How can I adjust this problem? Or is the monitor shot?
CompuGuy44
  • 432 Answers
SOURCE: Picture and sound go away after 2 minutes
Protection circuit fault kicks in. No vertical Deflection (V STOP),B+ over voltage protection (OVP), This is about a $150 -$200 to fix.
Posted on Jul 04, 2007
jingjao
  • 252 Answers
SOURCE: Sony Trinitron KV-24FS100 red light flashes 4 times
your tv had a problem.if you have a knowledge in electronics, check or replace the horizontal transistor beside the plyback. it is a black square parts with 3 pins.
Posted on Oct 14, 2008
  • 4234 Answers
SOURCE: My sony Trinitron KV-32S42 keeps blinking on and off
This can be a symptom of the picture tube starting to fail or a power supply problem. Can you please verify the model number and I'll then be able to give you a few options.
Thanks,
Dan
Posted on Nov 11, 2008
  • 4234 Answers
SOURCE: Sony Trinitron Picture Tube replacement
I think that you will find the picture tube to be more expensive than a replacement TV, if it is still available (unlikely). That being said, it is also unlikely that the tube itself is the problem, The more common problem is the horizontal output transistor or the flyback transformer. Either part should still be available for a reasonable cost. Check with a local servicer for the part numbers and costs. These are common parts.
Dan
Posted on May 19, 2009
  • 4 Answers
SOURCE: Sony Trinitron XBR TV, picture-in-picture got
A solution I found for our KV-32XBR200 was to press Setup on top of the set, then select the "Demo" item with TV/Video. The text overlay apparently banished PIP. Verified this twice, as I'm at this page because our remote can only turn PIP on :-).
Posted on Feb 17, 2011
What can I do about my flood-damaged monitors?
I would strongly suggest putting an insurance claim and replacing them. Water damaged cabinets may swell and come unsealed over time, as well as the speakers themselves and the electronics degrading faster than you might expect.
Feb 07, 2016 | Yamaha MSP5 Studio Monitor Studio Active
Dryer wet due to flooded basement
if it was p[lugged in you might have to replace the circuit board,, they can conduit electricity from one circuit to the other in water
Apr 30, 2009 | Kenmore 62602 Electric Dryer
I have a 2001 sony wega 36 inches and the channels
If you are comfortable with working inside the set where there are potentially dangerous high voltages present, you can probably fix this easily. Open up the back and remove it. Plug the set back in and turn it on. In the lower right hand side will be the flyback transformer (large red wire coming out of the top and going to the side of the picture tube). DO NOT TOUCH IT!!! On the back of the flyback should be 2 "knobs". One will be marked screen and the other focus. Carefully adjust the focus until the picture is clear. When you do this, go beyond the clear point and work the control back and forth a few times before settling in to the focused spot.
That should resolve the problem.
Dan
Apr 07, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Thanks,
Dan
Nov 11, 2008 | Sony KV-32S42 32" TV
Wega FD Trinitron dark Picture
probably is only adjustment inside the tv or you may need to replace the flyback
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron - Picture Disappears
Hi, IK circuit is engaging which basically means the picture tube is getting tired, the only "fix" is temporary (may get another year out of it). You have to increase the "screen control clockwise".
Remove back of set, follow large black or red wire attatched to picture tube down to the flyback transformer, mounted on flyback are two black controls, one is focus (leave it alone) the other is "screen", adjust it clockwise approx. 1/4 inch, remember that this is a high voltage circuit so use one hand in the set the other hand out of the set at all times,any questions ? e-mail me back, good luck, BMW Rider
Feb 27, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
RCA 56 inch projection TV
six inches will just reach the bottom of the main cuircit board. Does the units green light flash? there is no reset hutton there is a fuse. but i would suspect if it got wet then something blew
Feb 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony Trinitron K29 inch CRT TV screen shows green shade!
i have the same problem with my sony trinton tv 36 inch if you know how to fix this please email me on amir.dhawan@gmail.com
Dec 30, 2007 | LG Flatron 295LM 22" LCD Monitor
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
