Question about Sony KP-57WS500 57" Rear Projection Television
Tv turns off byitself
When watching tv it snaps real bright then goes blank with the color blue then shuts down the red led blinks 8 times over and over, turn the tv back on it is ok for 5 min then does the same thing.
  • paulj7772 Jun 23, 2008
    i have had a service rep look at the tv he told me high voltage.
  • 10,594 Answers
Hi paul,
I need bit more details in symptom of your tv set. When tv shows hight bright blue picture, does it have few lines (5~7) on screen?
Regarding 8 times blinks, it shows error in High Voltage area.
Waiting your reply.
Posted on Jun 23, 2008
    Master:
  • 638 Answers
I will give u the link for the solution of such problems n wat 8 blinks is related to in most of the models.all the possible information n repair process regarding ur problem is available on this link: http://www.repairfaq.org/sam/tvfaq.htm#tvtvrep
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
  • 4,234 Answers
I'll need to look up your specific model to be 100% sure, but hte 8 blinks is either the audio output amp that is bad or the Flyback transformer. The 8 blinks mean different things depending upon the model. Check the horizontal output transistor on the "D" board for a shorted condition (if you know how). That is the most common part to fail. If you are not comfortable with working inside the set, request a detailed repair estimate. Figure on $20 or so for parts if the problem is not the flyback and around $125 or so if the flyback is bad. Add in the local labor rate for the total repair cost.
Hope this helps,
Dan
  • ABRsvcs Jun 23, 2008
    By the way, the reason the set shuts down is the protection circuit kicks in to prevent further damage. And given the symptoms just before the shutdown, I'd be leaning toward the flyback being bad.
    Dan
  • Sony Master
  • 19,396 Answers
It is the safety switch
  • Ginko
    Ginko Jun 23, 2008
    The device detects there is a problem with some of the circuits and shut itself off after diagnosing the problem, usually a short or a faulty component on some of the boards inside tv .
    8 blinks mean internal problem with the audio board, TVgoes to standby and
    blinks the self-diagnosis code 8 times. You should have IC406 audio amp, PS401 and 402 checked, and eventually replaced.
    Regards
  • Ginko
    Ginko Jun 23, 2008
    After fixing the problem you should perform a service reset procedure, otherwise tv will keep returning the fault code. This is done by going into service mode (press display, channel, 5,
    then volume plus, then power). When in service mode press 8 and Enter. This should return
    everything to factory preset condition and clear error code.
My sony kp-51ws510 color rear video projector tv when i turn it on it stays on for abt five seconds and then turns off and also the timer and standby light is flashing red
this model did have problems with bad picture tubes---screen goes bright red,green,blue and set shuts down.
set also does this to protect itself---when fails look to see if specific sequence of blinks
Apr 17, 2012 | Televison & Video
The Screen Turns Green then shuts itself off? Is this the Bulb or something else?
My sony 65Ws500 model about 4 months ago it started turning the screen all blue as soon as I turned it on. it stayed blue for about an hour then come back on normal now when I turn it on it will shut down and I get a small red light flashing 8 time then pauses and does it again 8 time then pauses then again and so on. I took back panel off. I turn on tv The blue bulb gets very bright and the green and red projection bulb goes out and now it shuts off. and the blinking starts it a code flashing but don't know the code to find out whats wrong. would someone help if u can been wife and I laid off from work 3 months now cant afford tech prices on our employment. wife and I has 2 little girls to raise. along with the rest of u parent out there and one getting employment cant offord repairs. Thank U. Adams01220@yahoo.com
Feb 13, 2011 | Sony KP-65WS500 65" Rear Projection...
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Panasonic projection tv (shuts down)
Does the power indicator blink? Let me know and I will try to help you out. Just keep responding to this same psot so previous info will still be available.
Jun 30, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Help with kogi F9AH screen
Intermittently displays bright red/green/blue raster then shuts down with led flashing 2, 4 or 5 times
Amazingly this was due to the CRT being faulty !
Blank raster
Replace defective TDA6111Q for Red, Blue and green
Red or Green or Blue screen
Check and replace on crt module : D702, D703, D704 (all 1N4148) replace with type 1N4948T
Dead, led flashing red/green at first, then going to red standby
Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
Nov 23, 2007 | GVision F9AH-TG Television
Sony KP-57WS500 57" Rear Projection Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
