Question about BEL 950 Radar Detector
Old Bel 95 Vector
Get an error message ?LO3 CAL It will stay in this mode until I turn it off and on several times. At times even this doesn't work and I will wait a day or so.
  • den3awi Feb 15, 2009
    I have a Bel 95 vector and have the same problem . Get an error message ?LO3 CAL It will stay in this mode until I turn it off
2 Suggested Answers
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
SOURCE: Bel 980 problem
Mine has the same problem, but it seems to be caused mainly by excessive heat, mainly from being in the window of a hot car in the summer sun. Mine rarely does it in the winter. I suspect the CAL part has to do with a calibration fault when it self-tests itself when it's first turned on.
What I usually do is to pull the detector out of the mount and hold it in front of the air conditioning vent so that the cool air can go in though the holes in the case. It may take several minutes of cooling in this manner before it can power up without the LO CAL 1 message.
Posted on Aug 02, 2008
How do you set this atomic clock C17D2090 (WIC#628865)
Instructions to set the C17D2090 atomic clock
A. To manually set the clock
1. Use the CAL/ALM button to toggle the display until it shows the calendar
2. Press and hold SET until the screen flashes "12hr"
3. Use the UP (antenna) and DOWN (alarm) buttons to change the settings
4. Press SET to set the value
This mode will let you set the 12/24 hours clock, the time, date and year. You should be in the right time zone before you start.
B. To set the alarm1 time
1. Use the CAL/ALM button to toggle the display until it shows the AL1 alarm time
2. Press and hold SET until the alarm time flashes
C. To set the alarm2 time
1. Use the CAL/ALM button to toggle the display until it shows the AL2 alarm time
D. To turn on alarm1
2. Use the DOWN (alarm) button to toggle the alarm on and off (a bell appears on the screen)
E. To turn on alarm2
F. To have the atomic clock set automatically
1. Press and hold the UP (antenna) button until a little triangle flashes on the screen
2. Wait for clock to set
3. To give up waiting, press the UP (antenna) button again.
G. To change the time zone
1. Tap the ZONE button to toggle between the 4 time zones
Aug 16, 2012 | Audio Players & Recorders
Tip
Xerox system error
If you are using a Xerox printer, you might have faced a system error problem, similar to "System error 09.038.46:113334" or something within that line.
I faced a similar error message like this a few months ago and i solved it using the following steps.
The ink count sensor flags were stuck.
Verify that the ink is correct and genuine and then reset the system and error message by performing the following steps:
1- Turn on the printer
2- Wait for the xerox logo to begin moving across the display
3- Before the logo is centered on the display (stops moving) press and hold the "back" and "help" buttons on the control panel.
4- Hold both buttons until the display reads "beginning service mode initialization".Release the buttons and the printer reboots into service mode with the "Service Diagnostics" menu displayed
5- Then scroll until you find function menu then click "OK"
6- Scroll until you find "Clear ISC" fault and press "OK"
7- Click back several times and then reboot the machine.
If you follow these exact steps your problem should be solved.
Thank you for using Fixya,
Kenneth.
on Apr 07, 2010 | Office Equipment & Supplies
Error 5200 of canon pixma mx328. i already tried turning it on and off several times and even got the cartridges and returned them back but still when i tried to print a page error 5200 still...
Error no 5200 is caused by its temperature high.. to solve your problem follow the instruction given below::
1. Turn Off printer, cable power still plug in.
2. Press Stop/Reset button, don't release the button.
3. Press Power button by holding without release and than release Stop/Reset Button.
4. Press Stop/Reset button two times (2x) now release the Power Button.
5. Wait until service mode to zero (0).
6. Turn off the Printer, cable power still plug in.
7. Press Stop/Reset button, don't release it.
8. Press Power button don't release & than release Stop/Release button.
9. Press Stop/Reset button four times (4x), wait until service mode to "1"
10. Turn off printer, and loose cable power, wait for one (1) minute.
11. Connect cable power, turn on printer again, now this printer ready to use.
Aug 23, 2011 | Canon MX300 Office All-In-One Printer
I just purchased a Voyager Pro. When trying to pair it with my Blackberry, I turned the device on and held the button down waiting for the LED to flash red/blue. The device turn on blue, then flashed red...
You will need to turn off your headset and then press and hold the power button until the LED starts to flash red/blue, red/blue, it will stay in this state for a few minutes.
Good luck from Headsets Direct - 800-914-7996.
Aug 08, 2011 | Plantronics Voyager PRO Bluetooth Headset
Atomic travel alarm clock. Model number C17D2090 WIC#693047. (No brand name on clock.) I am living in outside US time zones and can't manually reset my clock to the correct time. (I lost the instructions.)...
Mar 26, 2011 | Audio Players & Recorders
My Soehnle scale shows an out2 error - how do I fix?
How to calibrate when "out2" is shown.
With the power off andthe scale on a stable surface, hold "g" and press "on". Some number will show up, probably a negative number. Press the "on" button again and the scale should display "Zero". Wait until it says "200.0". Gently place a 200 gram weight on the scale and wait a few seconds. If your successful it will say "Pass" and your scale will work again, yay!
May 14, 2010 | Salter 2001 electronic kitchen scale
I have a Beltronics Vector LR. It is probably
Get a new one with X k Ka and laser protection
Sep 21, 2009 | Vector 965 Radar Detector
Vector 940 works for a moment, then flashes ?L03 CAL ?MARKERS
just turn off the sws messages.
it probably recieved a jumbled signal from a "roadworks traffic control unit".that it couldn't understand.
Aug 31, 2009 | Pro RX65 Radar Detector
Error message, cant take pictures
Camera needs to be serviced. This is a common problem with sony cameras. If you have any knowledge of electronic, you could take apart and clean and lube lens. If not sony will fix for a fee, go to the sony web site, they offer a repair service. This happened to mine, it cost $95 plus shipping costs to repair. Now it works great, for how long who knows.
Jul 17, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
BEL 950 Radar Detector Logo
526 people viewed this question
Top Beltronics Vehicle Parts & Accessories Experts
John Nolan
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Beltronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
