Question about Black & Decker String Trimmer Cordless 12" 18V
I cant fit my replacement line for Black and decker GL430 Strimmer - the line pulls back inside within 20 secs of starting it up.
SOURCE: how can i repace the
Instructions can be found at: https://www.2helpu.com/PDMSDocuments/EU/Docs//docpdf/gl550_uk.pdf.
If the line keeps getting too long, it's because swivel 14 in diagram 7 was in the wrong position when you inserted the spool - just move it to the ouside position, re-insert the spool and away you go. Frankie.
Posted on Jun 11, 2008
  • 9 Answers
SOURCE: how do I rethread the
take the spool out there shood be a I hole to push the twine throu tie a not that wont come out look for dirtion or arrow to wind it leave enough to sitck thru the side where the twine cuts push the spool up and lock it
Posted on Jul 30, 2008
  • 9 Answers
SOURCE: how do u rewind a
if it is going back onside or unwinding it proble is in upsidedown or wond backwords
  • 4 Answers
SOURCE: got a Black & Decker GL301 strimmer but have lost instruction manual. dont know how to fit new cutting wire
Go to Homebase, B&Q, Ebay or your local hardware shop and buy a new spool, ALM part number BD032.
Posted on Jun 01, 2009
#1 Taper
  • 1040 Answers
SOURCE: threading line on black & decker GL301 strimmer
Do you mean that the string keeps feeding as you try to operate the trimmer?
If so, you are winding the string on the spool the wrong way. Put the string on the spool in a clockwise direction. This should do it.
Jim
Posted on Jun 21, 2009
Hi, i have a b&d gl430 strimmer. lever that links to line spool is broken, where can i find another please ?
Try Tulsa Engine Warehouse. TEW.com those guys are very helpful., Can also try Pat's Part Supply. All do business on-line.
Apr 06, 2014 | Black & Decker Garden
How do i fit the spool on my black and decker strimmer model no GL535
guide the two strings thru the holes in the outer ring,then push it down into place,and screw knob on
Jun 21, 2010 | Black & Decker String Trimmer Cordless 12"...
I have a black & decker gt701 strimmer. i recently replaced the line on the spool but now it wont feed, ??
Remove cup from bottom of unit by depressing 2 detent tabs and pulling away from unit.
Replace empty spool with new full one or wind on aftermarket string. Wind in direction of
arrow on spool. Make sure spool is seated on rachet firmly.
Apr 16, 2010 | Black & Decker Garden
How do i replace strimmer wire on a black and decker 315
how do i replace a spool and line on a black and decker GL20 strimmer x
Sep 10, 2009 | Black & Decker Garden
Reloaded string empties and shreds continuously in seconds
It sounds like you may need to replace the head. It is designed to advance and stop, but your's isn't stopping. Try this: Clean the inside of the head and connection to the machine well. Put some graphite inside the spool and where it connects to the machine; be generous with the graphite. Put the head back on with some line properly wound onto the spoo (note arrows on back of spool). With the machine off tap the head on the ground enough to disperse the graphite thoroughly in the head. Now, push the head as though to advance the line, and pull on the line. If it advances a little and stops, it is working. Do this several times to be sure. If you can get it working like this, you're good to go. If not, replace the spool. Even with the new spool, occasionally put some graphite in it to keep the line advance smooth!
Best regards, --W/D--.....Please feel free to rate this solution. Thanx!
Jul 25, 2009 | Black & Decker String Trimmer Cordless 12"...
How do you fit a new spool?
refer to here for generic instructions of replacing the wire/string on a trimmer.
http://wiki.answers.com/Q/How_do_you_replace_a_weed_eater_trimmer_line
have a read through, it may help assist you.
Jul 21, 2009 | Black & Decker Garden
Threading line on black & decker GL301 strimmer
Jim
Jun 19, 2009 | Black & Decker Garden
Got a Black & Decker GL301 strimmer but have lost instruction manual. dont know how to fit new cutting wire
Jun 01, 2009 | Black & Decker Garden
Black & Decker String Trimmer Cordless 12" 18V Logo
293 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
