Question about Panasonic Lumix DMC-TZ3 Digital Camera
Status indicator light stays on
When we turn the camera off, the status indicator light remains on. This means that it still uses battery life and needs recharging constantly. How do I get the status indicator light to go off?
  • 76 Answers
If you go into menu and there should be a restore original setting or reset or something like that if not if you check the body of the camera there may be a hole saying reset put a pin in that while it is on and in camera mode and that might fix it
Posted on Jun 23, 2008
Asus g73jh status indicator for battery flashing green/orange
the green and yellow light indicating that your battery needs replaced
Feb 02, 2013 | ASUS G73JHA1 Notebook
My camera battery indicator not show the battery status while using camera but batteries are shown when executed. find solution.pls.
The camera will not display the battery status until it drops below a certain threshold. When you don't see the status on the screen, take that to mean the status is good.
Jan 19, 2013 | Nikon Coolpix L310
The battery light flashes alternately blue and amber everytime i turn on my inspiron 1420 (even when cool). I've done a health check using the check button on the battery. Indicates battery status fine and...
Hi justlai33
Not to worry, it is a normal process when any laptop is started. It first check if it is connected to power and starts charging if connected to power.
As far as battery life status is good and fine, you can continue working on your laptop.
You will get a pop of notification when the battery life about to end, till then you can work with out any tension.
Thank you
gowtam1402@live.com
091-9916828137
Jan 02, 2011 | Dell Inspiron 1420 Notebook
Red light stays on after changing the water filter and running about 2 gallons through it
Water Filter Status Indicator
Light (select models)
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
• Press and hold both the Lock and Water
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Nov 27, 2009 | Maytag MZD2665HE Side by Side Refrigerator
Change filter light
To Reset Indicator:
successfully reset.
Sea Breeze
Nov 25, 2009 | Maytag MSD2650H Side by Side Refrigerator
Changing light after installing new water filter
(select models)
To Reset Indicator:
• Press and hold both the LOCK and WATER
successfully reset.
Aug 12, 2009 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Screen won't come to life to take photos
there will be a setting in the camera or maybe even a button that will turn the display on and off. change this to on. please refer to your product manual, if you have lost it just do a quick google search (ie. "camera make" "model#" manual)
Jul 19, 2009 | Olympus FE-340 Digital Camera
Low Battery Indcator Flashes
You can check the status of your battery, including chargeble life remaining, in the Setup Menu. You need to have the CSM/Setup menu option to display Full menus, not Simple, in order to get battery status. So see if that battery status selection says you need to replace the battery.
Since you can shake the camera to get full battery, it's possible the battery contacts (on the battery or in the camera) are dirty, so check that.
If you do need a new battery, spend the few extra bucks to get a genuine Nikon EN-EL3e from a Nikon dealer. I have learned that many off-brand batteries do not properly implement a needed reserve, and "Genuine Nikon" batteries bought online from non-dealers are often counterfeit, just relabeled junk.
Mar 01, 2009 | Nikon D80 Digital Camera with 18-200mm...
Laptop won't start-up
Can you tell me if the status lights on the power adapter and/or the battery turns on? Because you are telling me the status lights only stay on for 30 seconds, this should be a power connection problem.
One other possibility: can you tell me the climate environment of where you use your laptop?
Nov 16, 2008 | Dell Inspiron E1505 Notebook
Battery Status
I have the C-740, and the battery indicator appears in the upper left-hand portion of the screen when the camera is turned on, and also when I put the camera in view mode (a small green triangle on the dial) to review the pictures on the LCD screen. I also think the indicator will come on if the battery gets low. Don't know if the 750 works the same way.
Sep 13, 2005 | Olympus Camedia C-750 Ultra Zoom Digital...
Panasonic Lumix DMC-TZ3 Digital Camera Logo
178 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
