Question about Cameras
"battery doesn't hold power" " I turn it off, light is still on" "can't see any preview picture" "not able to take any picture" "the shutter speed is very slow" "a little click is heard when trying to take picture"
The premier camera don't hold the power!!
just few pics (7/8) and it's power off....
absolute negative
Posted on Jun 23, 2008
I'm using a Toshiba L505-10W. recently i've installed windows 8 consumer preview. my wireless doesn't turn on and the flash cards doesn't work either. realized that even my bluetooth d
The drivers for the hardware don't exist for windows 8. You need to format. turn on holding the 0 key. follow steps to set to factory defaults, save your pictures and documents first cause this will erase them.
Jul 01, 2012 | Toshiba Computers & Internet
How can i bypass my forgot admin password on my compaq armada e500
With the older Compaq Armada E500 Notebook PC, I believe;
1) Remove the CMOS battery.
2) Leave it out for 30 minutes.
3) Press the Power On button, and hold it for a count of 10 seconds. Let go of the Power On button.
Press it again. If the Power On light comes on, hold the Power On button in, until the light goes out. Keep pressing, and holding the Power On button in, until the Power On LED light does Not come on anymore.
Reinstall the CMOS battery. WAIT 1 minute, turn the laptop on.
If this doesn't do it, there is a capacitor inside the laptop keeping residual power. There may be two copper pads that are briefly touched across, to dissipate this residual power.
Perform the removal of the CMOS battery first. If this doesn't work I'll try to find info on the copper pads. (They are usually under the Wireless Card, and a small piece of Mylar plastic sheet)
Post back in a Comment as to your findings.
Regards,
joecoolvette
Jan 22, 2012 | Compaq Computers & Internet
All the light on the control panel are "on" status & "status screen" see nothing. M/C can not work completely.
Try defaulting the printer: with power OFF open the printhead, remove the media, and hold the PAUSE and FEED buttons in. Power ON the printer. Keep holding the PAUSE and FEED buttons until the green DATA light flashes. The printer will be defaulted and returned to all factory serttings. If this doesn't clear the problem you most likely have a bad main logic board.
Sep 02, 2011 | Zebra 140XiIII Plus Thermal Label Printer
Im trying to charge my camera via computer. . there is a red light on the charge cable connector and a green light on the camera which i have switched "on". it still says "low battery even...
Hi, I'd suggest using a wall charger as they're able to provide more power to charge then a computers USB port. Often with camera's the USB port doesn't supply enough power so the camera doesn't charge at all.
Aug 18, 2011 | Samsung SL102 Digital Camera
I have a Canon PowerShot A430 camera. When I turn it on, the lens doesn't open and it shuts off. The message on the screen says " Lens error, restart camera." Please advise. Thanks
The Lens Error is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
You can reset the Camera back to factory default by performing the following steps:
Press the power button.
Press and hold the MENU button for more than 5 seconds. Default Settings will get displayed.
Use the arrow buttons to select OK and press the FUNC./SET button. This will reset all the settings back to factory deafult.
This should resolve the issue. If the issue persists, service may be required.
Thanks for contacting FixYa
Aug 10, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
My Samsung 20" CRT model # TX-P2036 has power
May be you should press the channel button on the set itself or there is a problem with the eeprom of the set circuit.
Jun 15, 2011 | Samsung TXP2036 20" TV
Battery level don't show on display.
hi friend,
follow these steps
  1. Turn off your LCD display screen. I know this is hard—who likes shoving their face against the camera to compose a shot through the little viewfinder? But the LCD screen single-handed-ly drains a lot of power.
  2. Minimize the picture preview to the least amount of time possible—usually one second. This uses less LCD screen time, thus less power.
  3. Dim the brightness on your LCD screen. A dimmer display extends battery life by consuming less power to light the screen. This might make the display harder to see, but usually only in direct sunlight.
  4. Set the power saver to the least amount of time. Power saver lets your digital camera “sleep” when not in use, but doesn’t shut it down entirely. To “wake up” your digital camera, simply click the shutter button.
  5. Use your zoom as little as possible. The motor that moves the lens uses power. This also goes for repeatedly turning your digital camera on and off if it has an extend able lens.
  6. Turn off the continuous focus. Again, constantly using motors and electronics to ready your shot drastically minimizes battery life.
  7. Don’t push the shutter button half-way down until you’re ready to shoot. Pushing the shutter button (constantly resetting and refocusing) will drain battery life.
  8. Use the flash only when necessary. Your digital camera’s “auto flash” option should take care of this, but make sure your flash isn’t going off in broad daylight.
  9. Don’t delete pictures from your digital camera unless necessary. This consumes power. Wait until you download the pictures to your computer before deleting.
  10. This one’s basic, but charge your battery often. Lithium ion batteries, which most digital cameras use, don’t have “battery memory” like older alkaline. In fact, lithium ions work better and last longer if charged completely and regularly.
thank u for using fixya
regards,
sivaranjini
Aug 11, 2009 | Kodak EASYSHARE M1063 Digital Camera
Batteries won't hold charge.
What batteries are you using and how large a picture are you taking. Set the picture quality lower. 300X300 is fine for up to 8X10 enlargements. If you are using the preview screen for each shot, that uses battery power too. Don't use cheap batteries. They will let you down. Duracell or Energizers will give you better service than other batteries.
Aug 08, 2009 | Canon PowerShot A470 Digital Camera
Sony cybershot stopped working..my camera closes down as soon as i open it.i hv dropped it once..also its lens r projected out so what can be solution to open it?
Please try Power Resetting the Camera.
To Power Reset the Camera, First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
Jun 15, 2009 | Sony Cyber-shot DSC-H2 Digital Camera
Can't take pictures or video
Lens assembly is defective in your camera. If you know about camera, open it and inspect.
Jul 31, 2008 | Sony Cyber-Shot DSC-P92 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
