Question about Kirby G5 Bagged Upright Vacuum
How to attach sand paper to the Kirby Turbo Sander attachment?
How do you attach the sandpaper to a Kirby Turbo Sander attachment? All I see on the bottom is a rubber pad with adhesive at both ends, but slipping the paper under this adhesive does not create a bond. Is there another part that I may be missing?
Thank You,
elisa
  • 357 Answers
There is a plastic guard around the edges that comes off. Then, there are clamps that hold each end of the sandpaper. If you can't see the clips, then the guard is still on and needs to be removed. Hope this helps...
Marci
Posted on Jul 25, 2008
How to put on attachment hose
Here is a walkthrough on that with pictures:
Vacuuming Bare Floor with Kirby vacuum
You will need to take off the nozzle to attach the hose.
Install Kirby belt and nozzle
800-775-6586
GoodVac com
Dec 05, 2014 | Kirby Vacuums
Tip
How To Attach Carpet Shampooer To Your Kirby Generation 4 (G4) Upright.
This is an excellent, easy to follow video presentation of attaching the carpet cleaner to your Kirby Generation 3 Upright Vacuum Cleaner. Please note that the model being used in the video is a newer model named the Sentria, but the process of attaching the carpet extractor attachment is identical on the Kirby Sentria and the Kirby Generation 4. The only major difference is that the Generation 4 does not have the lever that extends out to turn the belt to off. On the Generation 4 this is dont by turning the entire white square with the Kirby logo on it in the front of the vacuum cleaner.
Please feel free to ask for a repair clarification if you have a question on how to attach the carpet shampooer. I'm always, more then happy to answer any follow up questions there may be.
Instructional Video On How To Attachment Carpet Shampooer To Kirby Generation 4 (g4) Vacuum Cleaner:
http://kirbywhq.powweb.com/videos/Carpet_Shampoo.mov
I hope that this helped you change your Kirby into a carpet shampooer. I you found this video helpful, please rate this Tip as helpful by clicking the Thumbs Up Icon. I really do appreciate it, thank you.
Chris J.
on Mar 21, 2010 | Kirby G4 Bagged Upright Vacuum
Tip
How To Attach The Carpet Shampooer Cleaning Attachment Kirby Generation 3 (G3).
This is an excellent, easy to follow video presentation of attaching the carpet cleaner to your Kirby Generation 3 Upright Vacuum Cleaner. Please note that the model being used in the video is a newer model named the Sentria, but the process of attaching the carpet extractor attachment is identical on the Kirby Sentria and the Kirby Generation 3. The only major difference is that the Generation 3 does not have the lever that extends out to turn the belt to off. On the Generation 3 this is dont by turning the entire white square with the Kirby logo on it in the front of the vacuum cleaner.
Instructional Video On How To Attachment Carpet Shampooer To Kirby Generation 3 Vacuum Cleaner:
Chris J.
on Mar 21, 2010 | Kirby Generation 3 Bagged Upright Vacuum
I lost the instructions for the shampoo attachment. How do I use it?
Kirby made a pretty good instruction video for attaching the shampooer. Click on "Attaching the Carpet Shampoo System" on the following site.
http://www.kirby.com/Portals/0/videos.html
Sep 29, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Putting on the attachments for the kirby g4
Well... some attachments you may end up not using at all... some of them are very handy...
I have online manual for attachments HERE
Good Luck
Mar 02, 2009 | Kirby G4 Bagged Upright Vacuum
How to attach Kirby Heritage Suds-o-gun?
To use the suds-o-gun you need to convert you Kirby to blower mode. First remove the carpet head.
If you have all of the standard kirby attachments there should be a plastic cover to go over the front of the kirby where the carpet head attaches. Its round with square holes in one end. If you don't have this no biggie. Just leave the carpet head on the machine and rotate the belt to the off position so the brush rool bush on rotate. Remove the bag for the machine attach the hose where the bag was use the same end that attaches to the front on the machine. There are notches on the inside of the hose connector the fit over the tabs on the bag port. Fill the suds gun tank with shampoo and water. Attach the suds gun to the kirby hose. The suds gun nozzle is funnel shaped with wire mesh on the end. This helps to make the suds finer. Also the suds gun should have a knob to set how much suds come out when you pull the trigger. Turn on you kirby and suds away.
I hope this helps.
Feb 05, 2009 | Kirby Ultimate G Bagged Upright Vacuum
How to use attachments
HERE is online Kirby vacuum manual by goodvac.com with tons of pictures.
Nov 24, 2008 | Kirby G4 Bagged Upright Vacuum
Kirby Ultimate Diamond Edition G Series, upright. Problem: I lost my manual. How do I use my vacuum on hard wood floors? How do I use attachments, where do they attach?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=576029
Generic problem for all Vacuums
Posted by jlutsi on May 06, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You can cal the Kirby factory to request a new owner’s manual and they will describe how to use the vacuum on hardwood floors. There is a felt piece as wide as the brushroll area that will clip on to the bottom of the revolving brush area so that you hard wood floors don’t get scratched. The Kirby head will dial off and the Kirby head will come off and the attachment hose will connect to the front of the Kirby and that is how you use the attachments. Also contact your local Kirby vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Don – The Vac Man
Go Ahead. Use Us.
May 06, 2008 | Vacuums
I have lost My Kirby G5 Manual
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=11561&thid=539967
Posted by Marie1231 on Apr 23, 2008
I need to know how to use the attachments that came with the Kirby. I know how to use the shampoo/vacuum, but not the other attachments or the upholstery cleaner. Does anyone have any idea?
1st, you need to un-hook the lever @ the top of the Kirby head, dial off the belt from the Kirby Vacuum Head using the Kirby emblem in the front of the vacuum, that also serves as a hook/spoon to dial the belt off the fan pulley. Once you have removed the vacuum head you now hook up the attachment hose to use the attachments by locking the attachment hose to the top lever. All regular Kirby attachment will fix on the attachment hose end including the spin brush if you have one with your Kirby --- using the Kirby Shampoo spray the soiled area and use the spin brush to agitate the carpet and or upholstery, try not to use to much water. If you have a Kirby shampooer – use the recovery tank on the exhaust port of the Kirby (this means that the cloth/paper bag needs to come off and install the clear recovery tank. Please refer to the Kirby owners manual for any type of trouble shooting that you might need – or please feel free to contact your local vacuum dealer in the yellow pages or contact your Kirby factory manufacturer listed below:
Monday thru Friday
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 23, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby G5 Bagged Upright Vacuum Logo
849 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
