Question about Cell Phones
Cell phone won't charge/or hold a charge
Have motorola cell phone and when I plug it in to the charger, it usually beeps indicating the charge is starting. Now, it doesn't beep and remains with the battery icon completely white [no bars], then it takes a few minutes and slowly begins to charge. Sometimes beeps "Low charge".
Doesn't keep the charge very long after being plugged in over night.
  • Anonymous Nov 23, 2008
    my lg scoop i got less than 4 months ago will not take charge at all. it cant be the phone bc wen i do get it to show the first screen of the powering on process it gets half way there and shuts town bc it is so dead. I have tried a lot of chargers from a variety of brands and nothing.. Tomorrow i am goin to just get a friend's and see if my battery works in her fone. If any others have this problem.. ur Radioshack or local Alltel Retail Store can order ur battery and the fone comes with a 1 year warranty on it so it will send another fone if it has not been abused or submerged to any moisture.
I had that same exact problem, with my razr so i just went out and bought a new battery for like 15 dollars, and now it works like a charm :)
Posted on Feb 27, 2009
    Brigadier General:
  • 7,752 Answers
You are not to keep a phone charging that long...only charge a mobile when the battery is completely dead that is the only way that you will have a good battery for a long time.
what you should do is try a new battery with the work and see if that helps other then that you will need to have the phone usb port service or checked.
Posted on Jun 23, 2008
2 Suggested Answers
SOURCE: Won´t charge
My SLVR had the same problem, so I bought a new one from Amazon. When I plugged the new one in the first time it did fine, but when I ran the battery completely out, it wouldn't charge. I played around with it a little bit, and I think I've found a solution that works: try taking the SIM card out of the phone, THEN charge it. It works on both my new one and my old one that way. The drawback for you is that you can't use your phone while its charging, I just switch phones while the other is charging, a bit of a pain sometimes, but the SLVR is my favorite phone so its worth it. :-) Good Luck.
Posted on Dec 20, 2007
My Motorola electrify won't turn on or charge. It
maybe your battery or your phone os .... try a new battery if nothing happens... try re flash your phone
Jun 02, 2013 | Cell Phones
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
My motorola Blur won't charge, I've tried other chargers and nothing, it will catch a charge for a second and then nothing, now my phone is dead
My Motorola Blur would not charge kept saying Connect Charger. I tried various power connecters including the Original one that came with the phone and the USB to no avail. This morning I took the phone apart and clean it and still would not recognize the charger.
Fix: I lifted up the connector where the charger plugs into on the actual phone and now it is making contact and appears to now be charging my phone.
Sep 15, 2011 | Motorola Mobility CLIQ Cell Phone
My cell phone died and now it wont charge!!!! :'(
It won't turn on because battery is too low. Another benefit of lithium ion batteries. When they are depleted, the internal controller / charge circuitry on battery disables it.
You didn't mention what kind of phone other than Motorola. If it has a USB connector to charge through, make sure that you are using a motorola approved charger. There is a way to make the USB connectors (charger side) indicate a particular class and rating. If this doesn't match what the phone expects, then you will likely get a Cannot Charge message or similar.
That being said, this usually only happens with AC wall chargers. I have yet to see it happen with a vehicle charger, though I don't rule it out.
Aug 25, 2009 | Motorola Cell Phones
Razr not charging -
New charger is needed - Razors are VERY particular about their type of charge - If it is a bad charger - You will see the battery indicator flashing red - and it will be empty - this is the phone saying pretty much that it cannot use this charger -
I have had ALOT of problems with razors and returned chargers - Try to scoop up an original - or take it to a location and test the charger first -
You can try to remove the battery and then put it back in - then try to charger it but i doubt that will work -
Get a new charger - TEST IT FIRST IN STORE!!!
Good Luck!
Jul 17, 2009 | Motorola Mobility RAZR V3
Motorola razr v3 wont charge, the bettery is not that old the phone beeped to signal charge requred, plugged it in as usual but cant turn it back on.
If the charger is plugged in, the phone is hooked to it, and it still will not come on, I would think it's a charger or electrical outlet problem.  I think most phones will bypass the battery power if they are plugged into an outlet, so try another wall plug, and if that wasn't it, try a different charger.  If a different outlet and charger don't solve it, it may be time to take it to the store to be checked.
May 29, 2009 | Motorola Mobility RAZR V3
No indication of charging after connecting to usb
Kumar,
Try the followings:
1. Plug the phone back to the pc and see if it will charge it. Or if it would beep when a cable is plugged to it. If I'm not mistaken, the driver for your phone should charge it when plugged to pc.
2. If nothing happened from doing the above advice, then get a toothbrush, dip it rubbing alcohol and brush both the phone's charging port and the charger itself.
Best of luck....
Jul 15, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Motorola razr v3 won't charge
have you tried measuring the output voltage on the charger?? if not... use a multimeter to check if there is a voltage coming out on the charger.. if there is... you doomed.... the charging module (charging IC) on your phone is fckd..
Jan 11, 2008 | Motorola Mobility RAZR V3
Battery won't charge.
hello,
normally many cell phones requires 6-10hrs for its batter to fully charge up. also i have seen it where battery can be brand new but doesn't have enough juice to hold the charge.
now as far as red light on charger, remember even if you have 99% charged batter and you plug in the charger it will show you red light on phone/cradle.
FYI- all brand new phones are covered with 30 days of warranty replacement with new phone. after 30 days it covers upto 1 year from the date of purchase with refurbished phones.
In your case i think it is just the battery, try having your provider replacing new battery if no luck again then my suggestion will be to replace your phone with new battery with in 30 days.
TY
Dec 22, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Car charger lights up but phone does not take charge
try charging your fon in your house outlet. if it works then your car charger is defective. if still your fon wont charge in your house then your fon has a prob in its charging section.
Oct 08, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
7,538 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
