Question about Buffalo Technology AirStation G54 WHR-HP-G54 Wireless Router (DHWHRHPG54)
Problem with my buffalo airstation G54 WHR-HP-G54
I am unable to connect to 192.168.11.1 to configure final settings. When i ping it, it says request timed out.
Also, the settings of the connection do not appear to be correct:
IP: 82.6.177.210
subnet mask: 255.255.252.0
Def. Gat: 82.6.176.1 (same as modem)
DNS servers : 194.168.4.100
194.168.8.100
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 163 Answers
  1. After unpacking your Buffalo wireless router, connect the ethernet cable from your jack to the rightmost ethernet port on the back of the router. This is the blue WAN port labeled "Internet". Next, use another ethernet cable to connect your computer to the router, using any of the 4 remaining open ethernet ports on the back. Finally, plug the AC adapter into the power port on the router and plug it into the wall.
  2. Once the router has been plugged into the network and powered on, the power light will come on and the other status lights on the front will go through a series of flashes. Once the leftmost diagnostic light labeled "Diag" has gone off and the light labeled "Router" has come on, this means your router has been initialized and is connected to the network.
  3. Now open a web browser window and enter 192.168.11.1 in the URL field and press enter. You will get a prompt to enter a username and password to access your router settings. You should enter "root" (without quotes) as the username and leave the password field blank, then click OK. You are now taken to a page where you can configure your Buffalo wireless router.
  4. Click on the Admin Config button on the top right of this page. Enter a name for your AirStation and click Apply. Wait for the router to restart with the new setting, you may have to refresh your browser window.
  5. Next click on the Password button in the small row of choices under Admin Config. The Administrator name is fixed as "root" however, you should now choose an Administrator Password (8 characters or less) and enter it in the two fields provided, then click Apply. Wait for the router to restart, and you will be prompted to login with the username "root" and the new password you just set up. If you choose a password over 8 characters long, you will be unable to login and will have to reset your wireless router by using the pinhole on the bottom.
  6. Next click on the Wireless Config button on the top, third from left. In the small row of choices under Wireless Config, click Basic(11g). Make sure the box labeled Enable next to the Wireless Radio setting is checked. For the SSID setting, switch to the second choice Use: and then choose a name for your wireless network. You should write this name down and keep it near your wireless router in casProblem with my buffalo airstation G54 WHR-HP-G54 - buffalo03.jpg it. Click Apply.
  7. Next click on the Security(11g) choice under Wireless Config along the top of the page. For the Wireless Authentication setting, select WPA/WPA2 mixedmode - PSK. For the WPA-PSK (Pre-Shared Key) field, choose a password that Problem with my buffalo airstation G54 WHR-HP-G54 - buffalo04.jpgand 63 characters (letters and numbers only) and enter it here. Click Apply. buffalo04.jpg
  8. Your Buffalo wireless router will restart and is now configured to connect securely to the Internet.
Posted on Dec 05, 2011
Did you set your wired network connection to 192.168.11.x with a subnet of 255.255.255.0
That should make you be able to connect to the router directly if the router has the default settings on it.
Posted on Jul 29, 2008
I have to disconnect and reconnect my Buffalo Router each time I want to use a different system. How do I fix this problem so I don't have to do this anymore?
I think you need to reset your modem and start anew. I am going to send you to another forum to learn about your WHR-Hp_G54
See: http://www.techsupportforum.com/forums/f136/buffalo-whr-hp-g54-227877.html
Jan 08, 2011 | Buffalo Technology AirStation G54...
Not connecting to internet after going through steps
Please put your modem to the bridge mode and then configure your router.
For the router settings please contact your ISP
May 03, 2010 | Buffalo Technology AirStation G54...
I need to connect to one PC trougth my buffalo router, I have the Public IP, but I don{t konw hoe to configure the router and the pc
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Apr 28, 2010 | Buffalo Technology AirStation G54...
Need a password to get access for my iTouch
You can check with "Admin" or no password.
if above are not work, please try to contact with your vendor.
Mar 29, 2010 | Buffalo Technology AirStation G54...
I have lost my Network Ket to my AirStation 54G. Is the only way to change it to Reset the ROuter ?
To get the network key of your wireless network, you will need to access the rotuerset up.
Is there any computer conencted to the router with the cable ?
If not then is there any computer online through the same router wirelessly ?
You can open the set up page on the working computer.
If you do not have any other computer online then you will need to connect the computer to the router with the cable.
Click Here for more info about how to find the network key
Nov 19, 2009 | Buffalo Technology AirStation G54...
Can't get it configured
Try to reset the router using a paper clip, then try to re-log in to the router with the IP address, If you are still unable to log in , try log as admin as the username and password as admin or admin on the username and password is password.
May 26, 2009 | Buffalo Technology AirStation G54...
Trying to connect buffalo router to comcast modem for wireless internet
You will need to use the MAC address of your PC. Do an IPConfig/all while connected with a ethernet cable. That's whatg you need to put in under Wan--> WAN MAC address
Jan 17, 2009 | Buffalo Technology AirStation G54...
Router getting poor connection
Jun 06, 2008 | Buffalo Technology AirStation G54...
Buffalo Technology AirStation G54 WHR-HP-G54 Wireless Router (DHWHRHPG54) Logo
1,030 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
