Question about GoVideo Go Video DVD/VCR Combo
THE VHS TAPE DOES NOT DO ANYTHING - GoVideo Go Video DVD/VCR Combo
  • 734 Answers
Go video is made by LG. You have to replace the VCR in the combo.
Posted on Nov 25, 2010
SOURCE:
I would like to buy a vhs tape that i can slot a video 8 tape into where can i buy
You can't. They don't exist because Video 8 is a completely different technical format to VHS and so whatever you did to physically get a Video 8 tape into a VHS machine, the hardware would simply be unable to do anything with it. Apart from chew it up...
Perhaps you're confusing the existence of VHS-C to VHS adapters where the smaller (but technically fully compatible) VHS-C tape is able to play in a standard VHS machine?
Sorry to disappoint you, but I hope that you have still found my reply to be of use and that you'll take a moment to rate my answer.
Mar 05, 2010 | Mercury Electronics MoviePix DV-33 Digital...
I cannot remove a vhs tape from my Mitsubishi HS-U51 player. HELP! KEN
If you are handy,
1) Unplug unit from power outlet before you do anything.
2) Take the top off /remove - screws usually phillips on both sides.
3) You will probably find the tape of the VHS wrapped around or pulled out of the cassette so you could cut the tape and probably pull the VHS out of the unit.
4) This deck sounds like it will need some cleaning and attention.
Might be a good idea to take it into a qualified TV repair shop and mabe for a small fee they can clean it.
Blessings,
A/V Media Tech Guy
Nov 24, 2009 | Televison & Video
Vhs tape won't play
sounds like to me the tape is to tight .try rewinding the tape all the way then fast forward all the way till it stops repeat and it should loosen up. if not the tape is no good the blue screen might go away after the tape is loosened n try cleaning the tape player good luck
Sep 19, 2009 | JVC DF420 D-VHS Tape
I have a broken VHS cassette.
You can remove the 4 or 5 screws at the bottom of the tape, turn the tape over CAREFULLY pull the top off. If the tape pulled out of the end of 1 spool, you have to remove the clip in the tape hub, reinsert the tape and snap the clip back in. Holding the tape door open so as not to catch tape, put top back on and replace screws. Hope this helps.
Aug 08, 2009 | TDK T 120HS VHS Tape
JVC CR-6060U Stuck in 'Search' mode
TAKE IT APART CHECK TO SEE IF ANYTHING IS STUCK,,TRY A JUNK TAPE ,,,,BLOW OUT ANY DUST ,,USE A HEAD CLEANER WITH ALCOHOL
Feb 06, 2009 | Samsung VR8460 VHS/S-VHS playback VCR
Do you have a diagram of how a vhs tape looks inside case?
Here you go
http://www.cctv-information.co.uk/constant1/vidcaset.gif
Jan 01, 2009 | Generic Memory Generic VHS Tape: Generic...
TV recorder wont record from TV. All cables work and are plugged in
WHAT "" system needs to be calibrated and then configured ""........""It works fine otherwise""
Disconnect the VCR from anything. place a vhs tape with information [picture of something you don't want any more or a vhs tape that you want erased] in the machine. The tape at the back left TAB must be covered to promit recording. turn machine on,shub the tape in, press record. if after a time and you REWIND, and the begining is blanked of picture information...........the recorder [VHS] is working. looking to see the cables and how they are connected.
Nov 10, 2008 | LG Televison & Video
Stuck VHS tape in Samsung TV/VCR Combo
I told you in premium post that Unplug your Combo for 5 - 10 minutes from AC outlet and replug it. Now push eject button and take out cassette.
Oct 09, 2008 | Samsung CXJ1352 13 in. TV/VCR Combo
Can't put a VHS in
If the VHS isnt going in it may require a little force as the track might have gotten stuck with dust. if you think its something else i suggest you openj it up and see if these is anything logged in the carriage way or if the tray might just be stuck. once it is open simply insertthe vhs tape and keep pressing in on it until the machine takes it in. while pressing keep you eye on the carriage and see hwat might be stuck as to preven the tape from entering. BUT I THINK IT MIGHT JUST REQUIRE A LITTLE FORCE as it may be binded with lack of use
Jan 04, 2008 | Televison & Video
GoVideo Go Video DVD/VCR Combo Logo
Top GoVideo Televison & Video Experts
Marvin
Marvin
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
