Question about Gateway 450ROG Notebook
Gateway 450ROG laptop does not boot
I have two 450ROGs belonging to my relatives. They both have the same exact issue. The power comes on, the status lites come on and then go off. The fan stays on but no display. I have switched the hard drives, power supplies and still no display and the LEDs only come on for a second when the power is switched on and then they go out. I hope some one has some ideas as I have none at this point. Thank you,
Did you find the problem?
Posted on Oct 21, 2008
The same as above. Goes on and off, but no display. fan runs....... on/off, on/off.
Pleae help. Computer less than a year old.
Posted on Oct 20, 2008
    Problem Solver:
  • 5 Answers
Al parecer tu mother Board esta dañana en el modulo del controlador de Video ATI,, este es un circuito de superficie que al parecer por el calentamiento que se genera en el uso de la laptop se daña la soldadura de este mismo.. lo puedes checar comprando un solvente para circuitos integrados,, este le rocias a l circuito que esta debajo del teclado y de su disipador,, le rociass entre el didispador iy el circuito.. y trata despues de encenderla.. si esta funciona el circuito esta dañado ,,,,ni como repararla , hay que hacer un cambio de mother board o aplana con un poco de fuerzas el circuito y tal vez tu lap funcione unpar de meses mas...
Posted on Jul 02, 2008
I have a similar problem with my 450rog but I get 3 beeps on startup - everything runs: fan and drives but the screen is blank and the computer dead.
Gateways tech dept told me it was a faulty memory module but I bought a new one and it made absolutely no difference.
So must be something moreserious.
Good luck
PM
Posted on Jun 27, 2008
Not able to get the right sound drivers for my gateway 450ROG Help
You can download the audio and device drivers for your model Gateway laptop from this WEB site. Make sure you select your model laptop and the correct Windows drivers. Click on this link to download the drivers: -
http://driver-pro.com/related/english/hardware-drivers/?a=12221&gclid=COmm19XHtpwCFSMSagodPRuwnQ&hit=1
Sep 19, 2012 | Gateway 450ROG Notebook
Tip
Intel wireless drivers for Gateway 450ROG
Recently ran into an issue where someone did not have all the original materials for their laptop. One of the issues was the wireless NIC acting up. The drivers were kind of a pita to locate so I figured I'd post a link here to the Intel drivers.
http://support.mpccorp.com/apps/disclaimer.asp?FilePath=/support/gateway/9525415.exe
on Feb 18, 2009 | Gateway 450ROG Notebook
There is a password on the cemos i need to clean it because it can't boot on the cd rom GATEWAY 450ROG
you need to reset cmos, cmos reset located inside the laptop this can be in different places from laptop to laptop. watch the video
Dec 18, 2010 | Gateway 450ROG Notebook
Gateway 450rog computer constantly restarts
remove all other devices hooked to your pc except for the basics, mouse and keyboard. then try the last known good configuration. press F8 before it boots to windows then choose known good configuration.
Mar 31, 2010 | Gateway 450ROG Notebook
Netgear will not connect to the internet on my laptop
Check the power adapter to the Netgear router with a multi-meter. The voltage should be slightly higher than the voltage that is printed on the label on the power adapter.
Feb 11, 2010 | Gateway 450ROG Notebook
Gateway 450ROG WiFi Not Working
Sounds like you need to look at that board closer. You wifi is not getting power.
Feb 21, 2009 | Gateway 450ROG Notebook
Confused on how to install gateway hardrive
Instructions on how to replace the hard drive:
http://support.gateway.com/s/Mobile/Gateway/450ROG/3501353faq85.shtml
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 10, 2009 | Gateway 450ROG Notebook
He power comes on, the status lites come on and then go off. The fan stays on but no display.
try taking the battery out and leaving it out for a little bit and then plugging it back in
Nov 01, 2008 | Gateway 450ROG Notebook
Gateway laptop
The first link shows what the status lights are, and the second is for the user guide. I believe the status light you're seeing indicates that the module is ready to swap. This refers to the modular bay or your CD drive. This is covered on page 52 of the user guide. It appears that you have hit the safely remove hardware icon, and most likely turned off the CD drive. Release and slide the drive out and put it back in. This should reset it, and the light should go off or turn green.
http://assets.gateway.com/s/Mobile/Gateway/450ROG/3501353ivr6.shtml
http://assets.gateway.com/s/Manuals/Mobile/9528975.pdf
Jul 26, 2008 | Gateway 450ROG Notebook
Sound Card Broken?
Im sorry to say it sounds like a surge in power is causing this issue. It would be interesting to see if an original power supply solves this issue. In any case I would get this checked by a qualified engineer to determine the exact fault (Use the repairman finder on this site to find one near you.)
Apr 01, 2008 | Gateway 450ROG Notebook
Gateway 450ROG Notebook Logo
281 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
