Question about HP DVD DRIVE DVD Drive
DVD Drive ...missing?
I'm helping my chaplain out with his computer. He has a HP Pavilion dv2715nr notebook (everything standard; no added frills). The DVD drive is not being read by the computer. The hardware is properly installed. I push the eject button it ejects the disc, the light comes on before opening and after closing, it spins to read the data on the disc. The computer itself doesn't read the drive.
In "Computer" the only drives available are C: and D: (recovery). Even the device manager does not show an installed DVD drive. My first thought is that in some way or another the drivers for his DVD drive were removed. Where could I download the drivers? Or do you think that perhaps it is a different problem altogether?
  • 2 more comments
  • Knewl2 Jun 26, 2008
    I have the same problem, can anyone help?
  • pcarnohan Oct 08, 2008
    i have the exact same problem
  • Laura910 Dec 06, 2008
    I have the same problem. My laptop is an HP DV2200. It happened right after I installed some photo software.
  • Anonymous Jan 28, 2009
    exact same
I HAD THE EXACT SAME PROBLEM THIS WORKED!!!!!! This information is excellent but if you get to the point where you can't find the upper and lower filters and you go to your BIOS and that don't help and yet your DVD/CD ROM still physically works but the computer doesn't want to acknowledge it then try this it is FM......Make sure you have a DVD ready..... goto your Control Panel....System.....Device Manager.....place Your DVD in the Driver then Right Click on... Disk Drives....Click.... Scan For Hardware Changes...........It Worked for me when none of these things worked like I said FM....
Posted on Dec 26, 2009
    Guru:
  • 859 Answers
Do you still need help with this?
When you bootup and access the setup screens by pressing F10 there is a property value for your multi purpose bay. It can be released at any time or only when the laptop is off. Is this set to anytime or was it set to only when off when you ejected the drive?
In any case you would need to reinstall the driver from HP and maybe then the drive bay could work. Otherwise, if its set to off and the Chaplin may have been doing this without using the Icon in the system tray to Safely Eject, etc. If done correctly youu usually okay. But, lets assume he hasn't. The drive bay chip may be damaged but I doubt it. To fix this you need to update and use the automatic software updater program. This should resolve issues, then it may not but it most likely will take care of a lot of problems including this. Click on the link below..
Here's the new software updater download location.
Should this is not work, Press F8 on startup and you'll see boot from D: the recovery partition. Do that. If its not on the first F8 screen escape and press F8 again immediately. You may see Repair my installation or words to that effect instead of Safe Mode.
Good Luck,
Worldvet
Please don't forget to rate this solutoin.
Posted on Jun 28, 2008
Can HP dv2715nr hibernate instead of putting it on sleep mode?
It sounds like the hibernate feature is missing from the power options list. Click on start button, select shut down, and then hold shif or ctrl and stand by should change to hibernate.
Let me know how you get on.
Regards.
Mar 11, 2010 | HP Pavilion dv2715nr Notebook
Can HP dv2715nr hibernate instead of being put on sleep mode?
  • Hi. "Yes," but putting the computer in the Hibernation State, can use up to 400MB of memory, and can be very "unstable to the system." You Can change the "Sleep, Hibernation, Wake-up...from the Start search window, Type Power, to open the Power Options. "If the solution helped, "Rating it is appreciated, thanks."
Mar 07, 2010 | HP Pavilion dv2715nr Notebook
My device manager does not have the dvd/cd rom drive listed . the computer opens and closes but doesnt recognize that there is a disk insi
This is what you do...
Start the Run Command Prompt
Type in "regedit" without the parrenthesis then click ok
Go to HKEY_LOCAL_MACHINE
Then SYSTEM
Then CURRENT CONTROL SET
Then CONTROL
Then CLASS
Then find {4D36E965-E325-11CE-BFC1-08002BE10318}
The whole thing looks like this:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Then delete the upper and lower filters....
RESTART YOUR COMPUTER
Nov 25, 2009 | HP Pavilion dv2715nr Notebook
My HP Pavilion dv2715nr won't play any discs...how can i fix this?
try to clean the links of yuour dvd room, then check the cd if good or not
Sep 07, 2009 | HP Pavilion dv2715nr Notebook
My cd/dvd driver is not working on my hp notebook
Go to HP's support website, find your laptop, and get the missing driver, or find out what brand your cd/dvd drive is and go to the manufacturers website to get the driver. I hope this helps!
Jul 24, 2009 | HP Pavilion dv9000z Notebook
HP Pavilion dv6700 - CD/DVD driver is missing
Might be that your laptop fell off or hit something which must have damaged the dvd/ cd drive. You have to replace the drive sorry.
Please rate this.
Mar 20, 2009 | HP Pavilion DV6700T Notebook
Keyboard wont work.
i had the same problem and called hp i was told to turn off my notebook and unplug the charger from the notebook take the battery off and hold down the power button for 30 seconds then reattach everything my keyboard started working again. i was told this happens because i donot let the battery die on my laptop or i keep it plugged in all the time which is true the notebook has to much static and the keyboard stops working. hope this helps
Feb 15, 2009 | HP Pavilion dv2715nr Notebook
Hp Pavilion dv6000's dvd-rw won't work
Hi, i use an HP pavillion dv6000 with Optiarc dvd rw ad -7561a ata (light scribe). i tried installing a softwear after which my dvd rom will not work it was complaining of driver corruption. i did uninstall and re- installed th driver from the system hard drive. but it will not install correctly. my computer can also not read drive E anymore. can some one help please.
May 01, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
339 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
