Question about Indesit W 123 Front Load Washer
Washing machine how do i reset
  • 1,462 Answers
Turn off. turn dial to one of the three black dots - doesn't matter which one. turn back on. lights will give a few rapid blinks and machine is reset
Posted on Jul 07, 2008
How to reset a Kenmore model 2661532210 washing machine
try this.if it does not work then go to this link and see if it helps you out...... Programmable Washing Machine Certain programmable washers have a reset function. This function clears an unintentional "Delay Start" command and resets controls in the case of a program error when the machine won't start. The method of resetting varies by make and model. In certain models, turn the knob to reset with the power button "Off." Select the desired program. Press the power button to restart the washer. In other cases, if the machine has a "Cancel" button, push it to clear the error and then push the "Pause" or "Stop" button to reset it. Consult the handbook for the washing machine for the correct procedure that applies to your model. You can often find washing machine handbooks or troubleshooting instructions on the manufacturer's website............
Reset Buttons for Washing Machines
Dec 08, 2016 | Kenmore Washing Machines
How to reset brandt washing machine
Stopped or Won't Start If the washer won't start or has stopped during a load, verify it has power. Plug a nightlight or other device into the power outlet to test it if you can easily access it. Otherwise, check the circuit box for a tripped breaker. Open and close the lid or door of the machine. If the washer stopped during a wash, adjust the load so that it is balanced. Check if the drain hose is clogged, and clear if needed. Turn the machine on with dry hands. If it still won't start, unplug it or turn the circuit breaker off, then back on until the breaker firmly clicks in place and plug the machine into the outlet. Push the restart button. Some machines may require you set the knob to a specific setting for the reset feature to work. On some machines, hold down the button labeled "Start-Pause" or "Stop" for a slow count of five. Turn the washing machine on. Run a rinse and spin cycle to check that washer is working and that the error code, if applicable, cleared.
Washers Without a Reset Button If it isn't possible to access the washing machine's plug to manually reset the washer, turn off the circuit breaker. Leave it off from 30 seconds to 1 minute, depending on the machine model or instructions in the owner's manual. For washers with a knob control, turn the dial clockwise to any cycle other than "Final Spin." With button controls, select any cycle other than "Spin." Check that the water to the washing machine is on. Turn the breaker back on. Turn the washing machine on. Some machines require that you open and close the lid six times after plugging the machine in to reset the motor.
When Reset Doesn't Work In some cases, after using the reset button -- or resetting the washer manually -- nothing happens. Your machine may have a problem or a faulty part that keeps it from operating. Among the most common are problems with door switches, latches or a faulty timer that may require replacement. Authorized technicians can replace parts or service the washing machine as needed. Websites of major manufacturers have replacement parts available to order and some provide schematics or answer your questions. On a recent-model washing machine, check if it's still under warranty.
Aug 14, 2016 | Brandt Washing Machines
I have a Bosch Maxx WFL 1662 washing machine. It does not stop washing and go over to the rinses sickle.Where do i start looking for the problem?
Hi Eric, There's two links below... 1st link is Bosch Washing Machine Error Fault Codes and the 2nd link is worth reading, The master reset is only part of the trouble shooting, I hope these help.
To perform the Master Reset, carefully unplug the washing machine from the power outlet and leave it unplugged for one minute. After one minute is up, plug the washer cord back into the wall. Next, open and close the door of the washing machine 6 times within 12 seconds to send a "reset" signal to all the components. (This is a common fix that many appliance repair mechanics use - it works on about 50% of all washing machines.) Once the reset has been completed set the washer to do a small load with no clothes in the washer. See if the washer goes through with the cycle as normal. If the washer performs correctly, then it has been reset and is fixed. If not refer to more troubleshooting techniques and causes of problems below.
How To Fix Washing Machine That Is Not Spinning or Draining
Apr 02, 2016 | Bosch Washing Machines
Error code 141. How can I fix it?
Bosch error code 141 Washing Machines Questions ... - Fixya > Forum > Tags > error code 141 > Washing Machines
Bosch washing machines error code 141 related questions and answers. Ask your Bosch questions. Get free help from washing machine experts.
error code 141 Washing Machines Questions & Answers ... > Forum > Tags > error code 141
Washing Machines error code 141 questions and answers. Ask your error code 141 washing machine questions. Get free help, advice & support for popular ...
Zanussi Washing Machine Fault Code Reset - iFixit
iFixitMy Zanussi Washing Machine hasn't been working properly for a while. then it stopped spinning and emptying, then wouldn't go through the programmes at all.
[PDF]TOP LOADER Automatic Washing Machine - you
Dec 29, 2015 | Washing Machines
Service light on awo/r5206 washing machine
Resetting the washing machine: Follow these tips, click on: Reset
Jan 20, 2013 | Washing Machines
Where is the reset button or how do I reset my washing machine?
there is no reset button but if you unplug the machine for about and hour and then plug it back in it will go back to the settings it was at when it left the factory.
Jun 22, 2012 | Whirlpool GSW9800PW Washer
How to reset or unlocked the beko washing machine timer
My washing machine time delay switch is flashing and I can't turn the machine on what do I need to do?
Feb 07, 2012 | Beko Washing Machines
Reset Fisher and Paykel washing machine
HOw to reset the Fisher Paykel machine. Mine one keyborad working but machine doesn't function. Where is reset button please?
Feb 18, 2010 | Fisher and Paykel GWL11 Top Load Washer
Indesit evolution de73 dishwasher
01 = Acquastop operated due to leak / overfill - machine drains until empty + lmin.
A02 = Heater Relay open circuit/short circuit or Thermistor or Safety T/Stat o/c or s/c or Element machine fills to Level Switch & Wash Pump runs.
A03 = Thermistor open circuit /short circuit - machine drains until Level Switch resets +1minute
A04 = Unable to sense/reach temperature in 70mins. - machine drains until Level Switch resets + lminute
A05 = Level Switch not resetting in within 3' 20" of drain commencing - machine drains until Level Switch resets +1 minute
A06 = Not used see also H20 at end
A07 = Wash pump Triac closed/open circuit - check that Drain Pump is not disconnected or Aquastop operated
A08 = Auxiliary Wash Pump Triac closedlopen circuit - check Wash Motor operation- machine drains until Level switch resets+30"
A09 = Main Wash Pump Triac closed/open circuit - cheek Wash Motor operation- machine drains until Level Switch resets+30"
A10 = Fill Solenoid valve Triac closedlopen circuit - check valve/operation - machine drains until Level Switch resets+30"
A11 = 1/2 load Solenoid Valve Triac or alternating Wash Motor action - check Solenoid Valve operation & alternating Motor action, replace Module if required - machine drains until Level Switch resets +30"
A12 = Relay with open circuit - check Heater, replace Module if required - machine drains until Level Switch resets+30"
A 13 = Dispenser Triac incorrect operation closed/open circuit - Wash Cycle completes but with Dispenser Lid notfunctioning correctly
H20 = Static 'Fill Time exceeding 6 minutes - cheek for blockages/low pressure
Apr 07, 2008 | Indesit 24 in. DE73 Evolution...
Indesit W 123 Front Load Washer Logo
252 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
