Question about GPS
Garmin Nuvi 360T won't find satellites
Nuvi360T has worked perfectly since last June, but yesterday wouldn't link with satellites, at all. Have completed advice to download software update to V 4.40 and reset the unit. It now has set clock to 01 April 2007 and the incorrect time and simply sits Locating Satellites for hours. Garmin 660, 18 months old, has worked flawlessly until yesterday when it lost the satellite in the middle of a trip. I downloaded the latest update and reset, but no relief. It does occasiolally say it is having trouble locating the satellite, asks if I am indoors and in Georgia, but nothing happens when I answer these questions.
  • jhill4796 Jul 24, 2008
    My Garmin 660 does not have a removable battery, so the posted solution is not applicable. The GPS can not acquire satellites.
  • 3,037 Answers
The ribbon connecting the reciever to the unit could have become dislogged or damaged. This may have occurred without any major bumping and just from the normal using of driving with it.
If you can, I would try opening it as I would think your warranty is done, if it is still good, then send it in to Garmin. When you open it up look for the connection to see if it still is connected well, many times a ribbon connection may become broken or become loose from all of the normal bumps on the road. Let me know what you find and whether you have any further questions
Posted on Jul 24, 2008
  • 2,071 Answers
In order to achieve a location lock your GPS receiver must receive complete reports from at least four Global Positioning Satellites. If you are standing still in an area with a relatively clear view of the sky, this should happen fairly quicky. However, if you are operating your GPS indoors, in a vehicle, or in an area with obstructions that block the line of sight between the receiver and the sky or if you are moving, it makes it more likely that the receiver will be unable to receive these signals or that part of the signals may be garbled or missed. In these cases it can take some time for the GPS receiver to aquire all the satellite data it needs.
Newer GPS receivers are much less susceptible to this issue, but it can still occur depending on how and where you are operating.
Posted on Jul 20, 2008
  • 19,396 Answers
Remove battery and disconnect from power for 5 minutes, also remove map card, this will reset the device. Try it out
Posted on Jun 23, 2008
  • 13,433 Answers
Please try going outdoors in to a clear area and walk around for a while to see if you get a satellite lock, it might take a moment.
  • Ekse Jun 23, 2008
    you might have to get the device replaced or repaired.
Will not aquire satellites
This is a common problem on the Nuvi 3xx and 6xx series and is caused by a failed component. Please see this link for troubleshooting information.
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Nov 23, 2011 | Garmin Nuvi 660 GPS Receiver
Ive been getting the message ''acquiring satellites'' since yesterday morning
Acquisition of satellite speed has been addressed in new firmware / system software updates for the Garmin Nuvi 200W .
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Dec 02, 2009 | Garmin nuvi 200W GPS Receiver
Wrong starting location
you didnt mention it but i assume its not aquiring the satellites. got to the link below and update your unit if you havent already. if you have that already, the link also explains the hard reset.
Aug 07, 2009 | Garmin NUVI 360 GPS Receiver
Nuvi 265t: no sound or bluetooth after update
Your last upgrade fail.
Load V5.00, wich install the bluetooth driver.
http://www.garmin.com/software/nuvi2x5_regionfileonly__500.gcd
Load this one to your nuvi F:\GARMIN\ and rename to GUPDATE.GCD.
After disconnect your nuvi from PC and downgrade firmware test bluetooth and sound. Then retry to update (Manual as above __530, WebUpdater or Garmin-Website).
Good Luck
Jul 29, 2009 | Garmin nuvi 265 Car GPS Receiver
Nuvi 5000 not starting up
Call Garmin customer support at 800-800-1020 and they will talk you through the reset process for FREE! Wait time may be long but worth the free help! Good luck!
Jul 07, 2009 | Garmin nuvi® 5000 Car GPS Receiver
Garmin 310. Bought March 2007, working perfectly until 1100 yesterd, then kept losing satellites, then coming back and so on. By 1200 lost all satellite connection. Satellite screnn shows no activity...
Please read the solution that resolved this problem for someone else. Most likely, you have already tried this.
http://www.fixya.com/support/t1115882-garmin_nuvi_360
If the above procedure does not work for you, the entire antenna assembly will need to be replaced.
The other option is to purchase an external antenna for your Nuvi and plug it into the external antenna port (gold connector) on the Nuvi antenna assembly.
Best wishes,
- Jim
Nov 03, 2008 | Garmin GPS
I should have posted this sooner.  I got hold of Garmin about my problem with the nuvi 360.  They were very nice about it and had me send the unit to them and they sent me a new one.  It was that simple.  I never found out what the problem was but the explanation from the other guy makes sense...... that the internal battery wore out and had to be replaced.  I am very happy with Garmin products and am glad everything worked out.
Feb 08, 2008 | Garmin Nuvi 360 Bilingual GPS Navigator...
Garmin Nuvi takes a long time to Acquire satellite
No. 98% of the time it took 45-56 seonds for your NUVI 660. Thats the compagny set up time acquisition and it did very well.
Be sur you had your flip antenna parallel to earth surface.
660 has THE BEST SIRF Chipset for acquiring satellite.
I had 2 NUVI 660 since 2 years. It work much better than those new 7xx series who it really took 2-3 minutes to acquire satellite.
Be sure you update your version to the last one.
----> https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00540-00&cID=134&pID=400
Best regards
Jan 12, 2008 | Garmin Nuvi 660 GPS Receiver
GPS Logo
117 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
