Question about Hotpoint Ultima WF840 Front Load Washer / Dryer
Hotpoint WF840P washing machine
Hi
We have a washing machine which doesnt seem to ant to drain any water?? I have checked the drain line which appears clear, blown thru the pressure switch ( I can hear the water bubbling in the drum) but still the machine will not drain?? I am reluctant to take out the cover as we may be moving abroad in a couple of months, the machine is a Hotpoint WF840P washing machine. Any advice would be appreciated.
  • joe duff May 11, 2010
    have you cleaned out the filter?
  • 24 Answers
The pump is blocked... at the bottom back there is a plastic cover, remove this and the pump is located on the back right hand side.
tilt washer far forward, place a bucket under to catch water and remove pipes.
once cleared, test again, if still no joy then you just need a new pump, but this part is a work horse so i would assume it is blocked with something like a baby wipe or babies sock (usual suspects)
Posted on Apr 18, 2009
We have hotpoint wma63 on draining and spinning water on floor seems to appear
well I would look for a loose or damages hose fitting while it is working .
Feb 22, 2015 | Hotpoint Washing Machines
Water wont pump out code f-05
Clogged drain pump.
Check the drain pump filter. Use a flashligth and you will se if the impeller is stuck on something. If not check the hose from the drum to the drainpump housing. May be clogged.
If not, replace drainpump
Apr 14, 2014 | Hotpoint Washing Machines
Hotpoint wma30. Drum not draining water. Have
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 31, 2010 | Hotpoint WMA30 Front Load Washer
Wash machine pump doesnt work
Hiya,
some machines have a filter at the front of the machine it will be right down the bottom behind the trim this trim normally just pulls to open & if so you will see a small circle if you unscrew that some water will come out & if blocked will have some stuff in that you can remove,
Hope this helps
Apr 20, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
My Hotpoint Aqualtis AQXXD 169 PM is adding time to the was cycle, taking longer to wash through the cycle? ant ideas?
the time is a generic time and will adjust accordingly as goes through programe-for example it allows a certain time to heat in the winter your cold supply may be colder so the machine needs longer to heat water-load size-if its adding more than 30 mins then check filter
Nov 11, 2009 | Washing Machines
HOTPOINT WF840P SHOWS TEST IN DISPLAY AND WILL NOT OPERATE
turn on while pressing the on and start buttons at the same time until 'dOFF' appears.
Feb 24, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WM64 doesnt seem to be taking in enough water
Close your faucet valve & unscrew your hoses to check screens on hoses & machine. Clean out well. Refit, check for leaks. Water shd be in good pressure. If this is not the problem change your inlet valve, it is easily done. Suggestion: use powders for front loaders.
May 08, 2008 | Hotpoint WMA32 Front Load Washer
Hotpoint Aquarius WMA 32
please check the outlet hose of the detergent drawer. it could be clogged with soap.
Feb 13, 2008 | Hotpoint WMA32 Front Load Washer
Hotpoint aquarius extra wma46
The first question you need to ask yourself is, "is the drain pump running?" If you can hear the drain pump running when it tries to drain, then more than likely you have a clogged drain pump, or drain line. Here's how you can determine which one: You can check the drain line by seeing if it collapses when the pump starts to run. If it does, then you know you have a clogged line somewhere BEFORE the pump. This usually means an article of clothing has gotten between the wash basket and outer tub and is stuck in the line. If the line is full of water and doesn't seem to be going anywhere, hook up a wet/dry shop vac to the drain hose in the rear of the machine to see if you can pull water from the tub, through lines, and through the pump. If you can't, you know you probably have a clogged pump, or drain line AFTER the pump. If the drain pump does not come on, you may have a pump failure. In either case, you need to drain the water from the tub. A wet/dry shop vac does a great job at pulling water from the tub, so you don't have to bail. Let me know if this helps.
Jul 22, 2007 | Hotpoint WMA46 Front Load Washer
Hotpoint Ultima WF840 Front Load Washer / Dryer Logo
187 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
