Question about Canon PIXMA iP4300 InkJet Photo Printer
Canon Pixma IP4300 printing problem
Colour printing has suddenly deteriorated, particularly when using non-ordinary paper. On ordinary paper there is slight streaking but colours are more or less OK.
BUT when non-ordinary paper is used - inkjet colour or photographic etc -less or no streaking - but colours go peculiar, becoming much more orange.
I have tried cleaning and deep cleaning and replacing cartridges, but that has not made any real difference. Is it a software problem? BUt I have tried deinstalling and reinstalling the driver - no difference.
  • 2 more comments
  • Alexyxx Jun 23, 2008
    Same cartidges are used for all papers in this printer, and were working perfectly OK for all papers a week or two ago. If I stick to ordinary paper setting, colour is more or less OK for higher quality paper. But if I change the paper setting - or even move to high quality printing on ordinary paper - the colour goes peculiar.
    I certainly have tried both different settings and different papers - inkjet colour and glossy photo paper, in one case resupting in blue going to pink. But so far the only way to get the colours more or less right is to use standard quality printing setting to standard white paper setting - then it prints more or less OK to all types of matte paper ( but not at all well for glossy photo paper)
    The printer is a bit more than one year old. Your suggestion of a problem with the print head sounds possible. though I would guess in the controlling software rather than the actual head? Can the head be replaced for less than the cost of a new printer?
    Why has the earlier and better solution proposal disappeared? where is it? how can I get back to it? should there not be a complete thread available? Anyway, best solution so far appears to be to replace the printhead, so questions are is this easy to do at home? where can one get the part? will it cost more than buying a new printer?
    Yes, more or less, though did not address the question of whether I would be able to do at home in the first place.
  • 2,071 Answers
It seems the problem in your print head nozzle holes there.The holes there it is big already that why splatter little by little that cause peculiarity to what you print,,it needs to changed head nozzle .call repairman to do the change and cleaning,.
Posted on Jun 23, 2008
    Master:
  • 638 Answers
Deep cleaning is required on ur head to function properly.otherwise replace ur head with new 1.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
    Champion:
  • 214 Answers
Hi, your head nozzle is damaged or require thorough cleaning. that may be the reason it doesnt give a high resolution print. go for an expert cleaning, and if it doesnt work, no other choice, you will have to purchase a new head. now a days going for a new printer is advisable rather than purchasing a new canon head, becoz head will take 3/4th of the new printer cost.
  • Rabby V V
    Rabby V V Jun 23, 2008
    hi, first of all thank you very much for accepting the solution.
    on cleaning the head, we need solutions like iso-propyl or 2- propanol, cotton or yellow cloth and some expertise for doing the work. dip the cotton lightly in the solution and try rub the nozzle lightley in one direction and next in the opposite till all the clogged ink on the nozzle get dissolved. take care not to give excessive pressure. but more or less head may get more damaged if done in a wrong way. once again thank u for the support
    Genius:
  • 1,665 Answers
    Sergeant:
    Champion:
  • 248 Answers
Sounds like its a color management issue. check canon`s website for any updated icc profile. What application are you printing from? and what operating system are you printing from?
  • Paulito Manuel
    Paulito Manuel Jun 23, 2008
    if canon doesn`t have any icc profiles to provide, check your printer settings particularly the color management section.
  • Paulito Manuel
    try also checking the alignment of the head or it could also be because of incorrect insertion of the paper.
    Thanks!
  • Canon Master
  • 19,396 Answers
It is a problem with print heads, you may need to replace them, print heads are located underneath cartridges.
  • Ginko
    Ginko Jun 23, 2008
    The part is not expensive you can order it here for $10 or so.
    If the printer is less than 12 months old you can have it replaced it for free from Canon.
  • Canon Master
  • 13,433 Answers
It seems like a paper / ink problem, are you useing ink carts ment for photo paper?
  • 3 more comments
  • Ekse Jun 23, 2008
    Also on your computer - in print preferences try changeing the paper and quality setting and do a few tests to see if it improves.
    How old is this printer? it may be a problem in the printer head controlling the cartridges and releaseing incorrect amounts of ink.
  • Ekse Jun 23, 2008
    You can also use this page
    http://www.usa.canon.com/consumer/contro...
    type in the search field, print quality, you get 30 topics about print quality problems.
  • Ekse Jun 23, 2008
    Let me know if you need anything else
    Thank you,
    Ekse
  • Ekse Jun 23, 2008
    You might have to send it in for service.
  • Ekse Jun 23, 2008
    Ginko, he can't see my comments anymore due to the new system.
    Issue: How can I purchase a replacement Print Head?
    Solution: Purchasing a Print Head - iP4300
    You may purchase a print head* for this printer by calling 1-800-828-4040 Monday-Sunday 8:00 a.m. - 12:00 midnight. EST, excluding holidays. When calling, speak the term "order parts" when the speech routing system asks the reason for your call. You will immediately be routed to the Parts Desk for assistance. Be sure to have your model number (iP4300) or part number (QY6-0061-010) ready for the sales person.
    * Please be aware that the part is not returnable.
I have a Canon Pixma ip4300. I replaced the 5 PGBK (the large non-photo black) cartridge and I went to print. A piece of paper got jammed, so I pulled that out and since then, that brand new cartridge...
Hi I think you may find a very small bit of paper may jammed under the print head, try removing the cartridge and have a close inspection, it only takes a tiny piece to cause the problem cheers Terry
Feb 26, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Hi, I have a Canon Pixma iP4300 printer and the Yellow ink is not printing. I have changed the cartridge and all other colours are working except Yellow. I would appreciate any solutions you may be able...
I have a Canon Pixma iP4300 printer and the Yellow ink is not printing. I have changed the particular cartridge and all other colours are working except Yellow. I have cleansed the printer several times and tried with new Yellow ink cartridges with new chips, but nothing helps.
What should I do?
Jan 25, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
When I try to print pdf's, word doc's, etc. from my MacBook to my Canon ip4300, they come out squished into the upper right corner of the paper. The paper size is set to "US letter" on the computer. How...
I'm not sure how to get at it using MAC software, but you need to get into the printer preferences.
I'm running Linux, which has some similarities, and to get at my printer preferences I click on System - Admin - Printing - RMB on the required printer and select Properties.
You may also be able to get at it via your programmes folder.
All you have to do is change the paper size from us letter to A4 or the particular size you require.
Jul 19, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Canon ip4300 printer says paper output tray is closed. wont prin
Its a defective printer you have that cant get out of paper output tray is close or that the paper output tray is not properly placed into the printer.
Try to reseat the output tray and let me know. If it does not work, you may need to send printer to repairs.
Mar 19, 2010 | Canon PIXMA™ iP4300 InkJet Photo Printer
In switching from plain paper to glossy photo the output is almost completely magenta. I've changed carts and on regular paper it looks okay . I've deep cleaned with no improvement This is a Canon ip4300
Find the printer properties menu and check the settings for glossy paper. You may have to set the colour controls to manual when using some types of photo papers.
Feb 11, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
I have ms xl & canon ip4300. I would like to
You need to go to canon.com and download the printing software there. That software has the options to print the way you describe.
Nov 05, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
"Paper Output Slot Jammed" Canon Pixma iP4300
These printers are FULL of very sensitive sensors, and chances are that one of them may have a small piece of paper blocking them. If you can get the covers off by finding the "Triangle" arrow markers, you can inspect all these sensors.
Good luck!!!
Mar 12, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
HI, I have a Canon IP4300. The image colour looks great on computer but when I print a paper print, the colour comes out exagerated so everything is over-bright and gaudy. How can I adjust the colour...
Assuming that your printer drivers have been loaded correctly to your computer it is likely that the ink cartidges are the cause of the problem. They are either dirty or low on ink (a particular colour if you have multiple cartridges). Have you tried someone else's printer perhaps?
Apr 27, 2008 | Cameras
Canon PIXMA  iP4300 InkJet Photo Printer Logo
old marine
old marine
Corne Viljoen
