Question about Jwin JV-DTV37 37 in. HDTV-Ready LCD Television
JWIN 37IN TV
I turn on TV however it "initalizes DTV" forever and will not do anything other then that
How to reset mintek dtv-265-d telivision after replacing power supply
MINTEK DTV-373-D OWNER'S MANUAL Pdf Download.
www.manualslib.com > ... > TV DVD Combo > DTV-373-D
View and Download Mintek DTV-373-D owner's manual online. Mintek DTV-373-D OWNER'S MANUAL 37''. DTV-373-D TV DVD Combo pdf manual download.
Mintek DTV-265-D 26 in. LCD TV Factory reset - Questions ...
www.fixya.com > ... > Mintek > Mintek DTV-265-D 26 in. LCD TV
...factory reset to this TV. It will make all to factory settings. There are two types ofreset to TVs. The first is simple to do; a Hard Reset. The other is somewhat ...
Mintek reset button location Combination Televisions ... - Fixya
Dec 07, 2015 | Mintek DTV-263 26 in. LCD Television
Problem with a LG 37in lcd when i turn it on it takes forever for it to show up a picture on the screen the green light comes on and then i gotta wait
Have the power supply checked out. I've worked on your particular model with the same problem. Turned out to be bad capacitors in the power supply.
Oct 19, 2012 | LG 37LC7D 37 in. LCD HDTV
Inital tv remote codes
try programming your tv onto your direct tv if it works, otherwise, try contacting direct tv and see if they can give you a code that will work. or go buy a universal remote that controls your sat and tv
Apr 07, 2009 | Initial DTV-262 26 in. HD-Ready LCD TV/DVD...
Vizio LCD DTV 32 inch. Model L32. I can't 'scan' for digital channels. When I go to DTV, then Menu and scroll right or left to "TV tuner setup' I get a blue screen and nothing else. No key on the...
Follow up on No DTV tuner after unplugging it a month for vacation. After I let it set plugged in for about 2-3 days it started working normally again and has been fine ever since. I hope this may help someone else. Genez 6-7-09
Mar 23, 2009 | Vizio L32 32 in. LCD HDTV
LG 37in HD LCD tv not responding to any pressed buttons.
Based on your description, it appears that you have main board issues with your unit since your controls do not work and some inputs are NG.
Apr 24, 2017 | LG 37LP1D 37 in. LCD Television
Will not boot- Sits at searching for sat forever and does not get past this point
I had this same issue recently. Unplug the receiver, for approx 30 seconds and after you plug it back in, it should receive the signal and boot up when you turn it on.
Mar 19, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Initial DTV-171 Schematic
try to find it on :www.eserviceinfo.com
Feb 28, 2008 | Initial DTV-171 17 in. TV/DVD Combo
Need help
ensure the tv is in analogue mode, not dtv and turn it off. with the remote: press info then, menu, then mute then power. these buttons need to be pressed sequentially not all at the same time and in quick succession. a menu will appear on the tv. navigate to the reset option and press the left arrow key on the remote (or press the enter/ok button) the tv will reset itself and turn off. turn the tv back on & it'll re tune all its channels. DTV should be working again.
Aug 23, 2007 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Jwin JV-DTV37 37 in. HDTV-Ready LCD Television Logo
27 people viewed this question
Top Jwin Televison & Video Experts
Henry  Thomas
Henry Thomas
Jaime Hernandez
romy sibug
romy sibug
Are you a Jwin Televison and Video Expert? Answer questions, earn points and help others
