Question about Whirlpool Duet GHW9150P Front Load Washer
There is no power to my washer
Tood off the front panel to see if anything was stuck. Nothing. What do you sugguest I do
  • PUCK01 Jun 27, 2008
    have a Whirlpool washer model number GHW9100LW2,SER# CSR2021497.
    asher Control Panel, and Control Board.
    Washer will not power up, pwr is on ckt. Also how to check to see if bad, repair.
  • 639 Answers
Hello friend,
ngfam1 at your service
Call these guys!
I use them for my customers and we are in the appliance business for 65 years!
They are nation wide and open to make appointments 24/7A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Bless you
Neil
Please rate me as good before signing off!!
Posted on Aug 30, 2008
Why won't it start?
the code f2 e1 is stuck key
this code is for models with digital display
one or more keys on the user interface were actuated for 15 seconds or longer. If a key is stuck and cannot be freed up then the user interface control will need to be replaced
replace the interface control
I would suggest that a technician be call for a diagnosis of the problem and a quote be obtained for the repairs first
Dec 31, 2015 | Whirlpool Cabrio WTW5600XW Top Load Washer
44921300 elite kenmore owner manuals
http://downloadfreemanuals.com/kenmore-washer-manual/
Apr 25, 2013 | Kenmore Elite 45986 Front Load Washer
My tv which is a PT-60LCX64 will not turn on. It blink green several times and will not show a picture. The set is 6 years old. I tried unplugging and plugging back up but nothing happened. Have any...
First thing is to check the lamp it is located either in the back of the set or the front there is a panel that u will have to remove to access the lamp.
Sep 27, 2011 | Panasonic PT-60LCX64 Television
Making loud banging noises. Sounds like something is inside, but nothing is. Something seems to be between the basin(?) and its casing.
It is very common for an item to get stuck between the basin and casing. You can drain the washer and spin the basin manually a few times in either direction. It should spin smoothly, but with some resistance. You may need to remove the front cover by typically lifting the top enough the loosen the front panel, then inspect the perimeter of the basin and the condition of the belt and motor. Remove anything that doesn't belong (i.e. a sock or zipper!)
Hope this helps! Rate my solution!
Jan 05, 2010 | Kenmore 44102 Front Load Washer
Washer won't drain or spin, get F2 error
Hello hernandez160,
The "F2" error is referring to excessive drain time. Unplug machine before working on it. Remove screws on bottom of lower panel and remove panel. The drain pump is behind the panel, It has a large round door on it, turn counter clock wise by hand to access pump clean out. Have lots of towels ready. Remove anything from pump (usually kids socks or small clothing articles). If nothing in pump clean out remove suction boot from drain pump and check there. If nothing there blow through the drain hose from the pump side to check if anything is stuck in the hose. If that's clear check the electrical connection on the pump, make sure nothing is loose or broken at the connection. If all this checks out good and it still wont work you probably have a bad pump and it will need to be replaced. If you do find something was blocked or clogged due to small clothing articles I would recommend a garment/lingerie bag to keep all the small stuff together during the wash cycle. Hope this helps to fix your problem. Please remember to rate this and every solution you get.
Thanks,
edgin96
May 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door locked on compact Whirlpool front-load washer
This worked for me. I turned off the washer and hit the area on the washer directly to the right of the door handle (not hard enough to break something or cause a dent). It popped right open.
Apr 09, 2009 | Whirlpool WFC7500VW Washer
How do you restart washing machine?
plug in power and turn program button at off(0),then open water and choose a program
Feb 17, 2009 | Kenmore Elite 45986 Front Load Washer
Frigidaire front load washer no spin
sounds as if theres something stuck in your drain pump, youll need to remove the lower acess panel(2 screws across the bottom front of unit) you'll see teh pump in the rigth hand corner. i would remove as much water as possible before trying to remove the hose to the pump or you will get soaking wetaferer removig the hose youll be able tro see what trapped in oyu pump preventing free draining.. VERY common problem.DISCONNECT POWER THE DRAIN PUMP IS ALWAYS LIVE!!!!!!!!
Oct 19, 2008 | Frigidaire GLTR1670A Front Load Washer
Kenmore Washing Machine
check the lock switch on the front load washer sometime it gets stuck
Mar 18, 2008 | Kenmore 44042 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
54 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
