Question about Panasonic Televison & Video
Having just bought a Panasonic TX-37LZD80 television and a panasonic sc-pt460EB-K home cinema system, I connected the 2 together using a HDMI Cable and all works well except that I cannot get the sound from the television to play through the television, I have followed the instruction manual as follows. From the television go to Menu/Viera Link/Sound and change from speakers to Home Cinema. This then automatically turns on the home cinema system and displays AUX. All I get then is silence, I have called the suppliers and am told that the only way this can be fixed is to send a Engineer out, this sounds a little drastic?
When I purchased the television iI was told that I would only need a HDMI cable to connect the devices together, this is not true as the HDMI only provides 1 way transmission, to get the sound to go from the television back to the home cinema you need to use either a Phono Lead or Optical lead, plug them in and Hey Presto it works.
Posted on Jun 25, 2008
How do I connect a Panasonic TX-50A300B (TV) to a Panasonic SC-HTB20 Home Audio System?
The audio system sports both a HDMI input AND an Optical input - one can use either. The TV has both of those as outputs so you truly can use either!
You'll need a HDMI to HDMI cable or an Optical to optical TOSlink cable.
Feb 16, 2015 | Panasonic Audio Players & Recorders
Home theater / tv hook up
An HDMI cable would give you digital audio. At the very least, use probably have a left and right analog audio input.
For more information or repair, please visit my website at audioservceclinic.com.
Thank you.
Feb 24, 2014 | Panasonic Televison & Video
Panasonic home cinema connection issues
What other audio/video outputs does the TV have? Does it have an HDMI port? If so, connect TV to your home theater using HDMI to HDMI.
Jun 07, 2013 | Panasonic SC-BTT490 5.1 3D Home Theater...
Connecting Panasonic SC-PT550 to TX-L42E5B
I have a pansonic tv that i brougt last winter ,All you have to do to get audio from it is use a optical cable,
Nov 26, 2012 | Audio Players & Recorders
I am having trouble connecting my Panasonte SC-BT230 to my cable box and my TV. Do i connect my cable box to SC-Bt230 than to my TV or my SC-BT230 to cable box than to TV
Here are a few ways to go about this.
connect the cable box hdmi (if Capable) to the panasonic hdmi input. Then connect panasonic hdmi out to tv hdmi in. The easy thing about this setup is that you only need the two hdmi cables because they carry both audio and video.
If your cable box or tv are not hdmi compatible, Then connect video output from cable box directly to your tv, and send an audio feed from your cable box to the panasonic.
Hope this helps,
Good Luck
Jan 07, 2011 | Panasonic Home Theater System System
How to connect Panasonic TV, DVD Recorder & Home Theater together
missing one connection connect stereo rca jacks behind tv labelled audio out then connect to any available input in home theater receiver i dont think you need the optic cable connected to anything
Jan 27, 2009 | Panasonic Home Theater System System
Sharp television and panasonic cinema system with hdmi connection
Ok, here's the deal. You can have sound being putout from hdmi coming from one of those sharp units, but it just depends on how you are connected. If you are using a digital audio output, from the tv, it wont push out the sound the way that it should. You will have to downgrade to using audio composite cables to connect to your external speaker system from the audio ouputs, not the digital audio outputs. Its not designed to push out sound from an hdmi cable. The BEST way to have this setup is to run your sound directly from the cinema to the external audio source(leaving the hdmi cable in the tv).
Nov 17, 2008 | Sharp Aquos LC-32D40U Television
Hook up
well u cannot hook almost any devices with the SC-HT500.
I have this homecinema system for 5 years now, and i had to buy another stand alone DivX player to hook it up, but can't get the sound in dolby from the standalone player since the panasonic SC-HT500 has only 2 analog stereo RCA ports (audio in) in the back and a scart (A/V out) and component video (Video out).
At that time it was a very good system, but since i have bought a Full HD LCD tv with 1080p capabilities, I realised that my home cinema system i.e the Panasonic SC-HT500 is kind of useless, in the sense that you cannot even change the player for another one since the whole spaker and power connections are made trhough a special cable from the subwoofer. :(
best solution is that put the system back in a corner and get a new system which is not an all-in-one system. Preferrable get home cinema systems that come with a receiver, separate dvd player and speakers and subwoofer hooked to the receiver.
you asked how to hook these devices to your tv,, well the panasonic dvd recorder is better if you connect it via HDMI cable if you can. In the other case, connecting them with a scart cable would be another solution.
Dec 02, 2007 | Panasonic SC-HT500 System
Televison & Video Logo
108 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
